Client network socket disconnected before secure TLS connection was established
Hi,
I am experiencing the error message Client network socket disconnected before secure TLS connection was established, when I open the Editor UI (okay) and I click on "Sign In" button (error).
I run nodered as follow:
  1. protected by Keycloack (Auth, both Editor UI and HTTP endpoints)
  2. docker container
  3. hosted on aws ec2 instance, with a load balancer on top owning the ssl certificate.
So the ssl certificate is on top of the ec2/docker/nodered and transparent for them...
In nodered, the settings.js section related to ssl is commented out like this:
    //https: {
    //    key: fs.readFileSync('privatekey.pem'),
    //    cert: fs.readFileSync('certificate.pem')
I don't get where the error message comes form... no output in logs.
More over, I had a look to this repo (node-red on aws) linked from the nodered ufficial docs: GitHub - guysqr/node-red-ha-on-aws: Node-RED on AWS with EFS to enable horizontal scaling. Uses Elastic Beanstalk to create additional instances into a load-balanced auto-scaling group as required. and I see the settings.js there pretty similar to mine... ssl commented out.
Any suggestion is very appreciated.
Thanks, F.
