i have try to use node-red-contrib-mysql2 node
In nodered documentation it is said
mysql nodes for node-red with paramaterization.
npm install node-red-contrib-mysql2
This is a fork to the original node-red-contrib-mysql, but changed the connection from pool to single connection at a time. We can also send the server details using msg.server, without adding those details at node level.
Can you explain how to format msg.server ?
i try this way but it doesn't works
var test= {Host:mariadb_Host,Port:mariadb_Port, Username: mariadb_Username, Password: mariadb_Password, Database: 'test'}
newmsg.Server=test
