C:\Windows\system32>node-red
23 Mar 20:29:32 - [info]
Welcome to Node-RED
23 Mar 20:29:32 - [info] Node-RED version: v1.0.4
23 Mar 20:29:32 - [info] Node.js version: v13.11.0
23 Mar 20:29:32 - [info] Windows_NT 10.0.18363 x64 LE
23 Mar 20:29:33 - [info] Loading palette nodes
Initializing chat-platform lib, you should see this only once
Running at: C:\Users\User.node-red\node_modules\chat-platform Version: 1.0.13
node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
In the future, you will have to enable it yourself.
See https://github.com/yagop/node-telegram-bot-api/issues/319. internal\modules\cjs\loader.js:1147:30
23 Mar 20:29:41 - [info] RedBot version: 0.18.15 (node-red-contrib-chatbot)
Running at: C:\Users\User.node-red\node_modules\node-red-contrib-chatbot-discord\node_modules\chat-platform Version: 1.0.9
Missing ENV var CONFIG_PATH
23 Mar 20:29:53 - [info] Dashboard version 2.19.4 started at /ui
23 Mar 20:29:53 - [warn] ------------------------------------------------------
23 Mar 20:29:53 - [warn] [node-red-contrib-file-function-ext/file-function] Type already registered
23 Mar 20:29:53 - [warn] [node-red-contrib-firebase-admin/flow-to-rtdb] Error: Cannot find module 'node-red'
Require stack:
- C:\Users\User.node-red\node_modules\node-red-contrib-firebase-admin\rtdb\flow-to-rtdb.js
- C:\Users\User\AppData\Roaming\npm\node_modules\node-red\node_modules@node-red\registry\lib\loader.js
- C:\Users\User\AppData\Roaming\npm\node_modules\node-red\node_modules@node-red\registry\lib\index.js
- C:\Users\User\AppData\Roaming\npm\node_modules\node-red\node_modules@node-red\runtime\lib\nodes\index.js
- C:\Users\User\AppData\Roaming\npm\node_modules\node-red\node_modules@node-red\runtime\lib\index.js
- C:\Users\User\AppData\Roaming\npm\node_modules\node-red\lib\red.js
- C:\Users\User\AppData\Roaming\npm\node_modules\node-red\red.js
23 Mar 20:29:53 - [warn] [node-red-contrib-firebase-admin/rtdb-to-flow] Error: Cannot find module 'node-red'
Require stack: - C:\Users\User.node-red\node_modules\node-red-contrib-firebase-admin\rtdb\rtdb-to-flow.js
23 Mar 20:29:53 - [warn] [node-red-contrib-firebase-messaging/firebaseAdmin] Type already registered
23 Mar 20:29:53 - [warn] [node-red-contrib-firebase-realtime-database/firebaseAdmin] Type already registered
23 Mar 20:29:53 - [warn] [node-red-contrib-mqtt-dynamictopic/mqtt-dynamic] Type already registered
23 Mar 20:29:53 - [warn] [node-red-contrib-mqtt-env/mqtt-env] Error: Cannot find module 'C:\Users\User\AppData\Roaming\npm\node_modules\node-red/red/red'
Require stack: - C:\Users\User.node-red\node_modules\node-red-contrib-mqtt-env\lib\mqttConnectionPool.js
- C:\Users\User.node-red\node_modules\node-red-contrib-mqtt-env\mqtt-env.js
23 Mar 20:29:53 - [warn] [node-red-contrib-viseo-amazon/amazon-alexa] TypeError: Cannot read property 'contextLRU' of undefined (line:115)
23 Mar 20:29:53 - [warn] [node-red-contrib-viseo-bot-wrapper/bot-wrapper] Type already registered
23 Mar 20:29:53 - [warn] [node-red-contrib-viseo-iadvize/server-iadvize] TypeError: Cannot read property 'contextLRU' of undefined (line:258)
23 Mar 20:29:53 - [warn] [node-red-firebase/firebase_modify] Type already registered
23 Mar 20:29:53 - [info] Settings file : \Users\User.node-red\settings.js
23 Mar 20:29:53 - [info] Context store : 'default' [module=memory]
23 Mar 20:29:53 - [info] User directory : \Users\User.node-red
23 Mar 20:29:53 - [warn] Projects disabled : editorTheme.projects.enabled=false
23 Mar 20:29:53 - [info] Flows file : \Users\User.node-red\flows_DESKTOP-QO4K8M4.json
23 Mar 20:29:53 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
23 Mar 20:29:53 - [info] Starting flows
23 Mar 20:29:54 - [info] Started flows
What problem cause it shutdown?
