Hello i'm new to node red and in need of assistance with a current project of mine. Is the first image using a debug node I was generating strings of data with what the CM and status of my sensor are and I want to save those data to a datasheet so I use a gform and get the url and put that to the httprequest node and it works but only shows the timestamps and not the cm and status I want to send, is there something wrong with the code I put in the function node??
code of my function node
var data = {}
data.Percentage = String
data.Status = String
msg.payload = data
