We want to call the POSK function payload into function payload and insert it into SQL.
the yellow Highlighted number needs to combine with the second payload msg into the POSK column.
can you please assist?
Have a look in the node-red cookbook, notably https://cookbook.nodered.org/basic/join-streams for an example of how to do this.
Are you still building SQL in the function node? (you stopped replying on your other thread)
Post your flow and I will show you how to do this properly.
is there any limitation for SQL connection, when we connect more 2 insert Db function to MSSQL server it show error " msg : error
"ConnectionError: Connection is closed."
Are you using mssql-plus?
thanks, sorry overlook, it is working with SQL-plus.
Do we have any limitation of connection with MSSQL-PLUS?
What on earth are all those nodes doing?
Can you export your flow and past it in a reply?
Also capture a sample of data from the output of the JSON node
I think you are not structuring this correctly.
flow
[{"id":"4b3f21a3.ba434","type":"tab","label":"Redlion-main-L16","disabled":false,"info":""},{"id":"ce8063fd.fd102","type":"mqtt in","z":"4b3f21a3.ba434","name":"","topic":"L16/#","qos":"0","datatype":"auto","broker":"b611955e.b00bf8","x":70,"y":80,"wires":[["f0325971.9c3e08","869fa08d.3ba1"]]},{"id":"f0325971.9c3e08","type":"json","z":"4b3f21a3.ba434","name":"","property":"payload","action":"","pretty":true,"x":210,"y":80,"wires":[["8c518462.0d7dc8","18dd9195.a7e43e","1ccf50a1.44f08f"]]},{"id":"4caf64e4.edd2ac","type":"mosca in","z":"4b3f21a3.ba434","mqtt_port":1883,"mqtt_ws_port":"8000","name":"","username":"red","password":"red","dburl":"10.104.32.105","x":110,"y":20,"wires":[[]]},{"id":"8c518462.0d7dc8","type":"function","z":"4b3f21a3.ba434","name":"L16_POS1","func":"d = new Date,\ndformat = [d.getMonth()+1,\n d.getDate(),\n d.getFullYear()].join('/')+' '+\n [d.getHours(),\n d.getMinutes(),\n d.getSeconds()].join(':');\n \ndformat1 = [d.getMonth()+1,\n d.getDate(),\n d.getFullYear()].join('')+''+\n [d.getHours(),\n d.getMinutes(),\n d.getSeconds()].join('');\n\ndtstmp = new Date().toString();\n\n\npld = \"INSERT INTO [RedlionMQTT].[dbo].[Pos1_L16] \"\npld = pld + \"(DateTime, POD, Pos1_op, Pos1_ETA, Pos1_Weight, Pos1_rdy,Pos1_Length,Pos1_1_2_cut,Pos1_All_cut,Pos1_DD,Detex,Number_Ply,POSK) \"\npld = pld + \"VALUES ('\"+ dformat+\"','\" +msg.payload.POD+ \"', '\" + msg.payload.Pos1_op + \"','\" + msg.payload.Pos1_ETA + \"','\" + msg.payload.Pos1_Weight + \"','\" + msg.payload.Pos1_rdy + \"','\" + msg.payload.Pos1_Length + \"','\" + msg.payload.Pos1_1_2_cut + \"','\" + msg.payload.Pos1_All_cut + \"','\" + msg.payload.Pos1_DD + \"','\" + msg.payload.Detex + \"','\" + msg.payload.Number_Ply + \"','\"+ 'L16POS1'+dformat1+\"')\"\n\nmsg.topic = ''\nmsg.payload = pld\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":310,"y":160,"wires":[["542238be.840fe8","edd22648.9fe2d8"]]},{"id":"869fa08d.3ba1","type":"debug","z":"4b3f21a3.ba434","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":370,"y":80,"wires":[]},{"id":"542238be.840fe8","type":"debug","z":"4b3f21a3.ba434","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":590,"y":120,"wires":[]},{"id":"18dd9195.a7e43e","type":"function","z":"4b3f21a3.ba434","name":"L16_POS2","func":"d = new Date,\ndformat = [d.getMonth()+1,\n d.getDate(),\n d.getFullYear()].join('/')+' '+\n [d.getHours(),\n d.getMinutes(),\n d.getSeconds()].join(':');\n \ndformat1 = [d.getMonth()+1,\n d.getDate(),\n d.getFullYear()].join('')+''+\n [d.getHours(),\n d.getMinutes(),\n d.getSeconds()].join('');\n\ndtstmp = new Date().toString();\n\n\npld = \"INSERT INTO [RedlionMQTT].[dbo].[POS2_L16] \"\npld = pld + \"(DateTime, POD, Pos2_op, Pos2_ETA, Pos2_Weight, Pos2_rdy,Pos2_Length,Pos2_1_2_cut,Pos2_All_cut,Pos2_DD,Detex,Number_Ply,POSK) \"\npld = pld + \"VALUES ('\"+ dformat+\"','\" +msg.payload.POD+ \"', '\" + msg.payload.Pos2_op + \"','\" + msg.payload.Pos2_ETA + \"','\" + msg.payload.Pos2_Weight + \"','\" + msg.payload.Pos2_rdy + \"','\" + msg.payload.Pos2_Length + \"','\" + msg.payload.Pos2_1_2_cut + \"','\" + msg.payload.Pos2_All_cut + \"','\" + msg.payload.Pos2_DD + \"','\" + msg.payload.Detex + \"','\" + msg.payload.Number_Ply + \"','\"+ 'L16Pos2'+dformat1+\"')\"\n\nmsg.topic = ''\nmsg.payload = pld\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":310,"y":200,"wires":[["edd22648.9fe2d8"]]},{"id":"1ccf50a1.44f08f","type":"function","z":"4b3f21a3.ba434","name":"L16_POS3","func":"d = new Date,\ndformat = [d.getMonth()+1,\n d.getDate(),\n d.getFullYear()].join('/')+' '+\n [d.getHours(),\n d.getMinutes(),\n d.getSeconds()].join(':');\n \ndformat1 = [d.getMonth()+1,\n d.getDate(),\n d.getFullYear()].join('')+''+\n [d.getHours(),\n d.getMinutes(),\n d.getSeconds()].join('');\n\ndtstmp = new Date().toString();\n\n\npld = \"INSERT INTO [RedlionMQTT].[dbo].[POS3_L16] \"\npld = pld + \"(DateTime, POD, Pos3_op, Pos3_ETA, Pos3_Weight, Pos3_rdy,Pos3_Length,Pos3_1_2_cut,Pos3_All_cut,Pos3_DD,Detex,Number_Ply,POSK) \"\npld = pld + \"VALUES ('\"+ dformat+\"','\" +msg.payload.POD+ \"', '\" + msg.payload.Pos3_op + \"','\" + msg.payload.Pos3_ETA + \"','\" + msg.payload.Pos3_Weight + \"','\" + msg.payload.Pos3_rdy + \"','\" + msg.payload.Pos3_Length + \"','\" + msg.payload.Pos3_1_2_cut + \"','\" + msg.payload.Pos3_All_cut + \"','\" + msg.payload.Pos3_DD + \"','\" + msg.payload.Detex + \"','\" + msg.payload.Number_Ply + \"','\"+ 'L16Pos3'+dformat1+\"')\"\n\nmsg.topic = ''\nmsg.payload = pld\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":310,"y":240,"wires":[["edd22648.9fe2d8"]]},{"id":"65dd2a5d.84d244","type":"function","z":"4b3f21a3.ba434","name":"L16_POS16","func":"d = new Date,\ndformat = [d.getMonth()+1,\n d.getDate(),\n d.getFullYear()].join('/')+' '+\n [d.getHours(),\n d.getMinutes(),\n d.getSeconds()].join(':');\n \ndformat1 = [d.getMonth()+1,\n d.getDate(),\n d.getFullYear()].join('')+''+\n [d.getHours(),\n d.getMinutes(),\n d.getSeconds()].join('');\n\ndtstmp = new Date().toString();\n\n\npld = \"INSERT INTO [RedlionMQTT].[dbo].[POS16_L16] \"\npld = pld + \"(DateTime, POD, Pos16_op, Pos16_ETA, Pos16_Weight, Pos16_rdy,Pos16_Length,Pos16_1_2_cut,Pos16_All_cut,Pos16_DD,Detex,Number_Ply,POSK) \"\npld = pld + \"VALUES ('\"+ dformat+\"','\" +msg.payload.POD+ \"', '\" + msg.payload.Pos16_op + \"','\" + msg.payload.Pos16_ETA + \"','\" + msg.payload.Pos16_Weight + \"','\" + msg.payload.Pos16_rdy + \"','\" + msg.payload.Pos16_Length + \"','\" + msg.payload.Pos16_1_2_cut + \"','\" + msg.payload.Pos16_All_cut + \"','\" + msg.payload.Pos16_DD + \"','\" + msg.payload.Detex + \"','\" + msg.payload.Number_Ply + \"','\"+ 'L16Pos16'+dformat1+\"')\"\n\nmsg.topic = ''\nmsg.payload = pld\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":310,"y":1120,"wires":[[]]},{"id":"75bc5b1d.964a34","type":"function","z":"4b3f21a3.ba434","name":"L16_POS16","func":"d = new Date,\ndformat = [d.getMonth()+1,\n d.getDate(),\n d.getFullYear()].join('/')+' '+\n [d.getHours(),\n d.getMinutes(),\n d.getSeconds()].join(':');\n \ndformat1 = [d.getMonth()+1,\n d.getDate(),\n d.getFullYear()].join('')+''+\n [d.getHours(),\n d.getMinutes(),\n d.getSeconds()].join('');\n\ndtstmp = new Date().toString();\n\n\npld = \"INSERT INTO [RedlionMQTT].[dbo].[POS16_L16] \"\npld = pld + \"(DateTime, POD, Pos16_op, Pos16_ETA, Pos16_Weight, Pos16_rdy,Pos16_Length,Pos16_1_2_cut,Pos16_All_cut,Pos16_DD,Detex,Number_Ply,POSK) \"\npld = pld + \"VALUES ('\"+ dformat+\"','\" +msg.payload.POD+ \"', '\" + msg.payload.Pos16_op + \"','\" + msg.payload.Pos16_ETA + \"','\" + msg.payload.Pos16_Weight + \"','\" + msg.payload.Pos16_rdy + \"','\" + msg.payload.Pos16_Length + \"','\" + msg.payload.Pos16_1_2_cut + \"','\" + msg.payload.Pos16_All_cut + \"','\" + msg.payload.Pos16_DD + \"','\" + msg.payload.Detex + \"','\" + msg.payload.Number_Ply + \"','\"+ 'L16Pos16'+dformat1+\"')\"\n\nmsg.topic = ''\nmsg.payload = pld\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":310,"y":1180,"wires":[[]]},{"id":"e8567df0.85b2b","type":"function","z":"4b3f21a3.ba434","name":"L16_POS16","func":"d = new Date,\ndformat = [d.getMonth()+1,\n d.getDate(),\n d.getFullYear()].join('/')+' '+\n [d.getHours(),\n d.getMinutes(),\n d.getSeconds()].join(':');\n \ndformat1 = [d.getMonth()+1,\n d.getDate(),\n d.getFullYear()].join('')+''+\n [d.getHours(),\n d.getMinutes(),\n d.getSeconds()].join('');\n\ndtstmp = new Date().toString();\n\n\npld = \"INSERT INTO [RedlionMQTT].[dbo].[POS16_L16] \"\npld = pld + \"(DateTime, POD, Pos16_op, Pos16_ETA, Pos16_Weight, Pos16_rdy,Pos16_Length,Pos16_1_2_cut,Pos16_All_cut,Pos16_DD,Detex,Number_Ply,POSK) \"\npld = pld + \"VALUES ('\"+ dformat+\"','\" +msg.payload.POD+ \"', '\" + msg.payload.Pos16_op + \"','\" + msg.payload.Pos16_ETA + \"','\" + msg.payload.Pos16_Weight + \"','\" + msg.payload.Pos16_rdy + \"','\" + msg.payload.Pos16_Length + \"','\" + msg.payload.Pos16_1_2_cut + \"','\" + msg.payload.Pos16_All_cut + \"','\" + msg.payload.Pos16_DD + \"','\" + msg.payload.Detex + \"','\" + msg.payload.Number_Ply + \"','\"+ 'L16Pos16'+dformat1+\"')\"\n\nmsg.topic = ''\nmsg.payload = pld\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":310,"y":1240,"wires":[[]]},{"id":"f00b28db.d276c8","type":"function","z":"4b3f21a3.ba434","name":"L16_POS16","func":"d = new Date,\ndformat = [d.getMonth()+1,\n d.getDate(),\n d.getFullYear()].join('/')+' '+\n [d.getHours(),\n d.getMinutes(),\n d.getSeconds()].join(':');\n \ndformat1 = [d.getMonth()+1,\n d.getDate(),\n d.getFullYear()].join('')+''+\n [d.getHours(),\n d.getMinutes(),\n d.getSeconds()].join('');\n\ndtstmp = new Date().toString();\n\n\npld = \"INSERT INTO [RedlionMQTT].[dbo].[POS16_L16] \"\npld = pld + \"(DateTime, POD, Pos16_op, Pos16_ETA, Pos16_Weight, Pos16_rdy,Pos16_Length,Pos16_1_2_cut,Pos16_All_cut,Pos16_DD,Detex,Number_Ply,POSK) \"\npld = pld + \"VALUES ('\"+ dformat+\"','\" +msg.payload.POD+ \"', '\" + msg.payload.Pos16_op + \"','\" + msg.payload.Pos16_ETA + \"','\" + msg.payload.Pos16_Weight + \"','\" + msg.payload.Pos16_rdy + \"','\" + msg.payload.Pos16_Length + \"','\" + msg.payload.Pos16_1_2_cut + \"','\" + msg.payload.Pos16_All_cut + \"','\" + msg.payload.Pos16_DD + \"','\" + msg.payload.Detex + \"','\" + msg.payload.Number_Ply + \"','\"+ 'L16Pos16'+dformat1+\"')\"\n\nmsg.topic = ''\nmsg.payload = pld\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":310,"y":1300,"wires":[[]]},{"id":"1bd6f607.fb877a","type":"function","z":"4b3f21a3.ba434","name":"L16_POS16","func":"d = new Date,\ndformat = [d.getMonth()+1,\n d.getDate(),\n d.getFullYear()].join('/')+' '+\n [d.getHours(),\n d.getMinutes(),\n d.getSeconds()].join(':');\n \ndformat1 = [d.getMonth()+1,\n d.getDate(),\n d.getFullYear()].join('')+''+\n [d.getHours(),\n d.getMinutes(),\n d.getSeconds()].join('');\n\ndtstmp = new Date().toString();\n\n\npld = \"INSERT INTO [RedlionMQTT].[dbo].[POS16_L16] \"\npld = pld + \"(DateTime, POD, Pos16_op, Pos16_ETA, Pos16_Weight, Pos16_rdy,Pos16_Length,Pos16_1_2_cut,Pos16_All_cut,Pos16_DD,Detex,Number_Ply,POSK) \"\npld = pld + \"VALUES ('\"+ dformat+\"','\" +msg.payload.POD+ \"', '\" + msg.payload.Pos16_op + \"','\" + msg.payload.Pos16_ETA + \"','\" + msg.payload.Pos16_Weight + \"','\" + msg.payload.Pos16_rdy + \"','\" + msg.payload.Pos16_Length + \"','\" + msg.payload.Pos16_1_2_cut + \"','\" + msg.payload.Pos16_All_cut + \"','\" + msg.payload.Pos16_DD + \"','\" + msg.payload.Detex + \"','\" + msg.payload.Number_Ply + \"','\"+ 'L16Pos16'+dformat1+\"')\"\n\nmsg.topic = ''\nmsg.payload = pld\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":310,"y":1360,"wires":[[]]},{"id":"edd22648.9fe2d8","type":"MSSQL","z":"4b3f21a3.ba434","mssqlCN":"867426f7.2f6538","name":"","outField":"payload","returnType":0,"throwErrors":1,"query":"","modeOpt":"queryMode","modeOptType":"query","queryOpt":"payload","queryOptType":"editor","paramsOpt":"queryParams","paramsOptType":"none","params":[],"x":970,"y":200,"wires":[[]]},{"id":"b611955e.b00bf8","type":"mqtt-broker","z":"","name":"mosca","broker":"10.104.32.105","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"867426f7.2f6538","type":"MSSQL-CN","z":"","name":"TCTME-TST","server":"10.104.32.107","encyption":true,"database":"RedlionMQTT"}]
JSON format output
INSERT INTO [RedlionMQTT].[dbo].[Pos1_L16] (DateTime, POD, Pos1_op, Pos1_ETA, Pos1_Weight, Pos1_rdy,Pos1_Length,Pos1_1_2_cut,Pos1_All_cut,Pos1_DD,Detex,Number_Ply,POSK) VALUES ('10/1/2020 22:41:44','EXT037897', '72.609','41','12.63262','OFF','11.868','OFF','OFF','OFF','0','0','L16POS11012020224144')
Ok, lets step back a second. Basic SQL insert design is that 1 BIG insert is better than many small ones. This means you stage data, and then push to SQL database in one large commit. There are many reasons to do this, for example connection creation is expensive in terms of SQL server resources.
Why do you need to do so many things in explicit parallel? Maybe explain the logic of the design, before we qualify the flows for said design? I think you may want to define the problem better before we jump to a solution?
If you ask why I am asking this? Well, in a 30+ year career in IT, I have supported may DB environments, even designed DB infrastructure, etc. So I am suggesting the above based on my considered experience with data queueing and forwarding as well as DB instructure.
Ok, so now i see what your issue is - it is a poor SQL table desgn that is forcing you to generate separate SQL insert statements.
table 1 - [Pos1_L16] "
table 2 - [POS2_L16] "
table 3 - [POS3_L16] "
field names for table Pos1_L16 - DateTime, POD, Pos1_op, Pos1_ETA, Pos1_Weight, etc etc etc
field names for table Pos2_L16 - DateTime, POD, Pos2_op, Pos2_ETA, Pos2_Weight, etc etc etc
DateTime, POD, op, ETA, Weight, etc etc etc
POS field to identify the POSDateTime, POS, POD, op, ETA, Weight, etc etc etc
Some questions...
Could you please provide data as captured from the JSON node...
Yes , i can change the SQL structure.
JSON format:
{"topic":"L16/","payload":"{\"connected\":1,\"Detex\":0,\"Number_Ply\":0,\"POD\":\"EXT037897\",\"Pos10_1_2_cut\":\"OFF\",\"Pos10_All_Cut\":\"OFF\",\"Pos10_DD\":\"OFF\",\"Pos10_ETA\":14,\"Pos10_Length\":14.74913,\"Pos10_op\":90.426,\"Pos10_Rdy\":\"OFF\",\"Pos10_Weight\":14.53442,\"Pos11_1_2_cut\":\"OFF\",\"Pos11_All_Cut\":\"OFF\",\"Pos11_DD\":\"OFF\",\"Pos11_ETA\":17,\"Pos11_Length\":14.51609,\"Pos11_op\":88.979,\"Pos11_Rdy\":\"OFF\",\"Pos11_Weight\":14.38062,\"Pos12_1_2_cut\":\"OFF\",\"Pos12_All_Cut\":\"OFF\",\"Pos12_DD\":\"OFF\",\"Pos12_ETA\":17,\"Pos12_Length\":14.46599,\"Pos12_op\":88.672,\"Pos12_Rdy\":\"OFF\",\"Pos12_Weight\":14.34755,\"Pos13_1_2_cut\":\"OFF\",\"Pos13_All_Cut\":\"OFF\",\"Pos13_DD\":\"OFF\",\"Pos13_ETA\":15,\"Pos13_Length\":14.69537,\"Pos13_op\":90.251,\"Pos13_Rdy\":\"OFF\",\"Pos13_Weight\":14.49894,\"Pos14_1_2_cut\":\"OFF\",\"Pos14_All_Cut\":\"OFF\",\"Pos14_DD\":\"OFF\",\"Pos14_ETA\":15,\"Pos14_Length\":14.66638,\"Pos14_op\":89.917,\"Pos14_Rdy\":\"OFF\",\"Pos14_Weight\":14.47981,\"Pos15_1_2_cut\":\"OFF\",\"Pos15_All_Cut\":\"OFF\",\"Pos15_DD\":\"OFF\",\"Pos15_ETA\":14,\"Pos15_Length\":14.73197,\"Pos15_op\":90.302,\"Pos15_Rdy\":\"OFF\",\"Pos15...","qos":0,"retain":false,"_msgid":"d07f3000.d48ab"}
2 things.
That data is no good - please use the copy button on the debug
Paste the data between backticks
like this
Same way copied:
'''{"topic":"L16/","payload":"{"connected":1,"Detex":0,"Number_Ply":0,"POD":"EXT037897","Pos10_1_2_cut":"OFF","Pos10_All_Cut":"OFF","Pos10_DD":"OFF","Pos10_ETA":14,"Pos10_Length":14.74913,"Pos10_op":90.426,"Pos10_Rdy":"OFF","Pos10_Weight":14.53442,"Pos11_1_2_cut":"OFF","Pos11_All_Cut":"OFF","Pos11_DD":"OFF","Pos11_ETA":17,"Pos11_Length":14.51609,"Pos11_op":88.979,"Pos11_Rdy":"OFF","Pos11_Weight":14.38062,"Pos12_1_2_cut":"OFF","Pos12_All_Cut":"OFF","Pos12_DD":"OFF","Pos12_ETA":17,"Pos12_Length":14.46599,"Pos12_op":88.672,"Pos12_Rdy":"OFF","Pos12_Weight":14.34755,"Pos13_1_2_cut":"OFF","Pos13_All_Cut":"OFF","Pos13_DD":"OFF","Pos13_ETA":15,"Pos13_Length":14.69537,"Pos13_op":90.251,"Pos13_Rdy":"OFF","Pos13_Weight":14.49894,"Pos14_1_2_cut":"OFF","Pos14_All_Cut":"OFF","Pos14_DD":"OFF","Pos14_ETA":15,"Pos14_Length":14.66638,"Pos14_op":89.917,"Pos14_Rdy":"OFF","Pos14_Weight":14.47981,"Pos15_1_2_cut":"OFF","Pos15_All_Cut":"OFF","Pos15_DD":"OFF","Pos15_ETA":14,"Pos15_Length":14.73197,"Pos15_op":90.302,"Pos15_Rdy":"OFF","Pos15...","qos":0,"retain":false,"_msgid":"d07f3000.d48ab"}'''
again:
Only payload msg:
{"connected":1,"Detex":0,"Number_Ply":0,"POD":"EXT037897","Pos10_1_2_cut":"OFF","Pos10_All_Cut":"OFF","Pos10_DD":"OFF","Pos10_ETA":2,"Pos10_Length":16.45928,"Pos10_op":101.112,"Pos10_Rdy":"ON","Pos10_Weight":15.66313,"Pos11_1_2_cut":"OFF","Pos11_All_Cut":"OFF","Pos11_DD":"OFF","Pos11_ETA":1,"Pos11_Length":16.23375,"Pos11_op":99.522,"Pos11_Rdy":"ON","Pos11_Weight":15.51428,"Pos12_1_2_cut":"OFF","Pos12_All_Cut":"OFF","Pos12_DD":"OFF","Pos12_ETA":1,"Pos12_Length":16.18431,"Pos12_op":99.202,"Pos12_Rdy":"ON","Pos12_Weight":15.49117,"Pos13_1_2_cut":"OFF","Pos13_All_Cut":"OFF","Pos13_DD":"OFF","Pos13_ETA":1,"Pos13_Length":16.43628,"Pos13_op":100.657,"Pos13_Rdy":"ON","Pos13_Weight":15.64794,"Pos14_1_2_cut":"OFF","Pos14_All_Cut":"OFF","Pos14_DD":"OFF","Pos14_ETA":1,"Pos14_Length":16.40729,"Pos14_op":100.479,"Pos14_Rdy":"ON","Pos14_Weight":15.62881,"Pos15_1_2_cut":"OFF","Pos15_All_Cut":"OFF","Pos15_DD":"OFF","Pos15_ETA":1,"Pos15_Length":16.48587,"Pos15_op":100.960,"Pos15_Rdy":"ON","Pos15_Weight"...'''
So 1 MAJOR problem I see is ...
you want 68 of these inserts - so I imagine you have tables Pos1_L16 --> Pos68_L16 ?
is that correct ?
HOWEVER - I dont see all the data in your payload. I see "pos10" and Pos11... through to Pos15
Another thing, the payload you are showing is a STRING (JSON) - it needs to be a JS object.
Did you capture this BEFORE or AFTER the JSON node?
This cannot work as it is
Would you be willing to make a single table with an simple field names and an extra column to identify the POS?
e.g...
datetime, pos, pod, op, eta, weight, rdy, [length], etc, etc, etc
If so, I can simplify this to a very small flow.
yes we can try.
ok, so make a new table called L16
and ensure the field names are...
eventtime, pos, pod,
op, eta, [weight], rdy,[length], cut,
all_cut, dd, detex, number_ply, posk
tell me when you have that table ready
