Command prompt from Dashboard with command included
Hello everybody.
I am trying to open a command prompt terminal using a button from Dashboard. Also, when terminal is opening, I want to run alreday a ssh command ( ssh username@ip address).
To open the terminal I used the exec node with this command : start cmd. When I click a button, the exec node runs and my terminal opens. What I want is when terminal opens, to run automatically ssh command ( ssh username@ip address).
I was trying to make a .bat script with the followings :
start cmd
But when I run exec node it only opens the cmd, without ssh command included.
Do you have any idea how can I do this?
Thanks in advance !
I just found the solution. Just type in exec node this command : start cmd /k ssh username@ip adrress .
I leave my post here in case anyone will be interested in the future.
