Command to install
command to install the grovepi nodes for npm version 8.11.0
when installing the nodes, an error occurs
Please copy/paste the full install log. Not screen shot please.
To begin...seems you are in your home dir, not in .node-red
Hello
npm ERR! code 1
npm ERR! path /home/pi/node_modules/buffertools
npm ERR! command failed
npm ERR! command sh -c node-gyp rebuild
npm ERR! make: Entering directory '/home/pi/node_modules/buffertools/build'
npm ERR! CXX(target) Release/obj.target/buffertools/buffertools.o
npm ERR! make: Leaving directory '/home/pi/node_modules/buffertools/build'
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp info using node-gyp@9.0.0
npm ERR! gyp info using node@16.15.1 | linux | arm
npm ERR! gyp info find Python using Python version 3.7.3 found at "/usr/bin/python3"
npm ERR! gyp info spawn /usr/bin/python3
npm ERR! gyp info spawn args [
npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
npm ERR! gyp info spawn args 'binding.gyp',
npm ERR! gyp info spawn args '-f',
npm ERR! gyp info spawn args 'make',
npm ERR! gyp info spawn args '-I',
npm ERR! gyp info spawn args '/home/pi/node_modules/buffertools/build/config.gypi',
npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
npm ERR! gyp info spawn args '/home/pi/.cache/node-gyp/16.15.1/include/node/common.gypi',
npm ERR! gyp info spawn args '-Dlibrary=shared_library',
npm ERR! gyp info spawn args '-Dvisibility=default',
npm ERR! gyp info spawn args '-Dnode_root_dir=/home/pi/.cache/node-gyp/16.15.1',
npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
npm ERR! gyp info spawn args '-Dnode_lib_file=/home/pi/.cache/node-gyp/16.15.1/<(target_arch)/node.lib',
npm ERR! gyp info spawn args '-Dmodule_root_dir=/home/pi/node_modules/buffertools',
npm ERR! gyp info spawn args '-Dnode_engine=v8',
npm ERR! gyp info spawn args '--depth=.',
npm ERR! gyp info spawn args '--no-parallel',
npm ERR! gyp info spawn args '--generator-output',
npm ERR! gyp info spawn args 'build',
npm ERR! gyp info spawn args '-Goutput_dir=.'
npm ERR! gyp info spawn args ]
npm ERR! gyp info spawn make
npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
npm ERR! ../buffertools.cc:32:11: error: ‘v8::Handle’ has not been declared
npm ERR! using v8::Handle;
npm ERR! ^~~~~~
npm ERR! ../buffertools.cc: In member function ‘v8::Localv8::Value {anonymous}::UnaryAction::operator()(const v8::FunctionCallbackInfov8::Value&)’:
npm ERR! ../buffertools.cc:141:34: error: no matching function for call to ‘v8::Value::ToObject()’
npm ERR! target = args[0]->ToObject();
npm ERR! ^
npm ERR! In file included from /home/pi/.cache/node-gyp/16.15.1/include/node/node.h:63,
npm ERR! from ../buffertools.cc:17:
npm ERR! /home/pi/.cache/node-gyp/16.15.1/include/node/v8.h:3060:44: note: candidate: ‘v8::MaybeLocalv8::Object v8::Value::ToObject(v8::Localv8::Context) const’
npm ERR! V8_WARN_UNUSED_RESULT MaybeLocal ToObject(
npm ERR! ^~~~~~~~
npm ERR! /home/pi/.cache/node-gyp/16.15.1/include/node/v8.h:3060:44: note: candidate expects 1 argument, 0 provided
npm ERR! ../buffertools.cc:77:65: error: no matching function for call to ‘v8::Exception::TypeError(v8::MaybeLocalv8::String)’
npm ERR! type(v8::String::NewFromUtf8(args.GetIsolate(), message)));
npm ERR! ^
npm ERR! ../buffertools.cc:143:7: note: in expansion of macro ‘UNI_THROW_EXCEPTION’
npm ERR! UNI_THROW_EXCEPTION(Exception::TypeError,
npm ERR! ^~~~~~~~~~~~~~~~~~~
npm ERR! /home/pi/.cache/node-gyp/16.15.1/include/node/v8.h:7525:23: note: candidate: ‘static v8::Localv8::Value v8::Exception::TypeError(v8::Localv8::String)’
npm ERR! static Local TypeError(Local message);
npm ERR! ^~~~~~~~~
npm ERR! /home/pi/.cache/node-gyp/16.15.1/include/node/v8.h:7525:23: note: no known conversion for argument 1 from ‘v8::MaybeLocalv8::String’ to ‘v8::Localv8::String’
npm ERR! ../buffertools.cc: In member function ‘v8::Localv8::Value {anonymous}::BinaryAction::operator()(const v8::FunctionCallbackInfov8::Value&)’:
npm ERR! ../buffertools.cc:169:34: error: no matching function for call to ‘v8::Value::ToObject()’
npm ERR! ^
npm ERR! ^~~~~~~~
npm ERR! ^
npm ERR! ../buffertools.cc:171:7: note: in expansion of macro ‘UNI_THROW_EXCEPTION’
npm ERR! ^~~~~~~~~
npm ERR! ../buffertools.cc:187:56: error: no matching function for call to ‘v8::Value::ToObject()’
npm ERR! Local other = args[args_start]->ToObject();
npm ERR! ^
npm ERR! ^~~~~~~~
npm ERR! ^
npm ERR! ../buffertools.cc:196:5: note: in expansion of macro ‘UNI_THROW_EXCEPTION’
npm ERR! ^~~~~~~~~
npm ERR! ../buffertools.cc: In member function ‘v8::Localv8::Value {anonymous}::FillAction::apply(v8::Localv8::Object, const v8::FunctionCallbackInfov8::Value&, uint32_t)’:
npm ERR! ../buffertools.cc:256:44: error: no matching function for call to ‘v8::Value::Int32Value()’
npm ERR! int c = args[args_start]->Int32Value();
npm ERR! ^
npm ERR! /home/pi/.cache/node-gyp/16.15.1/include/node/v8.h:3107:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Localv8::Context) const’
npm ERR! V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local context) const;
npm ERR! ^~~~~~~~~~
npm ERR! /home/pi/.cache/node-gyp/16.15.1/include/node/v8.h:3107:40: note: candidate expects 1 argument, 0 provided
npm ERR! ../buffertools.cc:261:43: error: no matching function for call to ‘v8::String::Utf8Value::Utf8Value(v8::Localv8::Value)’
npm ERR! String::Utf8Value s(args[args_start]);
npm ERR! ^
npm ERR! /home/pi/.cache/node-gyp/16.15.1/include/node/v8.h:3581:5: note: candidate: ‘v8::String::Utf8Value::Utf8Value(v8::Isolate*, v8::Localv8::Value)’
npm ERR! Utf8Value(Isolate* isolate, Localv8::Value obj);
npm ERR! ^~~~~~~~~
npm ERR! /home/pi/.cache/node-gyp/16.15.1/include/node/v8.h:3581:5: note: candidate expects 2 arguments, 1 provided
npm ERR! ../buffertools.cc:266:56: error: no matching function for call to ‘v8::Value::ToObject()’
npm ERR! ^
npm ERR! ^~~~~~~~
npm ERR! ^
npm ERR! ../buffertools.cc:272:5: note: in expansion of macro ‘UNI_THROW_EXCEPTION’
npm ERR! ^~~~~~~~~
npm ERR! ../buffertools.cc: In member function ‘v8::Localv8::Value {anonymous}::IndexOfAction::apply(v8::Localv8::Object, const uint8_t*, size_t, const v8::FunctionCallbackInfov8::Value&, uint32_t)’:
npm ERR! ../buffertools.cc:329:54: error: no matching function for call to ‘v8::Value::Int32Value()’
npm ERR! int32_t start = args[args_start + 1]->Int32Value();
npm ERR! ^
npm ERR! ^~~~~~~~~~
npm ERR! ../buffertools.cc: In function ‘v8::Localv8::Value {anonymous}::decodeHex(const uint8_t*, size_t, const v8::FunctionCallbackInfov8::Value&, uint32_t)’:
npm ERR! ../buffertools.cc:77:65: error: no matching function for call to ‘v8::Exception::Error(v8::MaybeLocalv8::String)’
npm ERR! ^
npm ERR! ../buffertools.cc:363:5: note: in expansion of macro ‘UNI_THROW_EXCEPTION’
npm ERR! UNI_THROW_EXCEPTION(Exception::Error,
npm ERR! /home/pi/.cache/node-gyp/16.15.1/include/node/v8.h:7529:23: note: candidate: ‘static v8::Localv8::Value v8::Exception::Error(v8::Localv8::String)’
npm ERR! static Local Error(Local message);
npm ERR! ^~~~~
npm ERR! /home/pi/.cache/node-gyp/16.15.1/include/node/v8.h:7529:23: note: no known conversion for argument 1 from ‘v8::MaybeLocalv8::String’ to ‘v8::Localv8::String’
npm ERR! ^
npm ERR! ../buffertools.cc:381:7: note: in expansion of macro ‘UNI_THROW_EXCEPTION’
npm ERR! UNI_THROW_EXCEPTION(Exception::Error, "This is not hexadecimal data.");
npm ERR! ^~~~~
npm ERR! ../buffertools.cc: In member function ‘v8::Localv8::Value {anonymous}::ToHexAction::apply(v8::Localv8::Object, const v8::FunctionCallbackInfov8::Value&, uint32_t)’:
npm ERR! ../buffertools.cc:67:41: error: ‘kNormalString’ is not a member of ‘v8::String’
npm ERR! v8::String::kNormalString,
npm ERR! ../buffertools.cc:419:12: note: in expansion of macro ‘UNI_STRING_NEW’
npm ERR! return UNI_STRING_NEW(s.c_str(), s.size());
npm ERR! ../buffertools.cc: In function ‘void {anonymous}::Concat(const v8::FunctionCallbackInfov8::Value&)’:
npm ERR! ../buffertools.cc:449:29: error: no matching function for call to ‘v8::Value::ToString()’
npm ERR! size += arg->ToString()->Utf8Length();
npm ERR! ^
npm ERR! /home/pi/.cache/node-gyp/16.15.1/include/node/v8.h:3048:44: note: candidate: ‘v8::MaybeLocalv8::String v8::Value::ToString(v8::Localv8::Context) const’
npm ERR! V8_WARN_UNUSED_RESULT MaybeLocal ToString(
npm ERR! ^~~~~~~~
npm ERR! /home/pi/.cache/node-gyp/16.15.1/include/node/v8.h:3048:44: note: candidate expects 1 argument, 0 provided
npm ERR! ../buffertools.cc:452:50: error: no matching function for call to ‘v8::Value::ToObject()’
npm ERR! size += node::Buffer::Length(arg->ToObject());
npm ERR! ^
npm ERR! ^~~~~~~~
npm ERR! ../buffertools.cc:72:67: error: no matching function for call to ‘v8::Exception::TypeError(v8::MaybeLocalv8::String)’
npm ERR! ^
npm ERR! ../buffertools.cc:460:7: note: in expansion of macro ‘UNI_THROW_AND_RETURN’
npm ERR! UNI_THROW_AND_RETURN(Exception::TypeError, errmsg);
npm ERR! ^~~~~~~~~~~~~~~~~~~~
npm ERR! ^~~~~~~~~
npm ERR! ../buffertools.cc:470:30: error: no matching function for call to ‘v8::String::Utf8Value::Utf8Value(v8::Localv8::Value&)’
npm ERR! String::Utf8Value v(arg);
npm ERR! ^
npm ERR! ^~~~~~~~~
npm ERR! ../buffertools.cc:475:39: error: no matching function for call to ‘v8::Value::ToObject()’
npm ERR! Local b = arg->ToObject();
npm ERR! ^
npm ERR! ^~~~~~~~
npm ERR! ../buffertools.cc:72:67: error: no matching function for call to ‘v8::Exception::Error(v8::MaybeLocalv8::String)’
npm ERR! ^
npm ERR! ../buffertools.cc:482:7: note: in expansion of macro ‘UNI_THROW_AND_RETURN’
npm ERR! UNI_THROW_AND_RETURN(Exception::Error,
npm ERR! ^~~~~
npm ERR! ../buffertools.cc: At global scope:
npm ERR! ../buffertools.cc:492:21: error: variable or field ‘RegisterModule’ declared void
npm ERR! void RegisterModule(Handle target) {
npm ERR! ^~~~~~
npm ERR! ../buffertools.cc:492:21: error: ‘Handle’ was not declared in this scope
npm ERR! ../buffertools.cc:492:21: note: suggested alternative: ‘rand_r’
npm ERR! ^~~~~~
npm ERR! rand_r
npm ERR! ../buffertools.cc:492:34: error: expected primary-expression before ‘>’ token
npm ERR! ^
npm ERR! ../buffertools.cc:492:36: error: ‘target’ was not declared in this scope
npm ERR! ^~~~~~
npm ERR! ../buffertools.cc:492:36: note: suggested alternative: ‘tzset’
npm ERR! ^~~~~~
npm ERR! tzset
npm ERR! In file included from ../buffertools.cc:17:
npm ERR! ../buffertools.cc:506:26: error: ‘RegisterModule’ was not declared in this scope
npm ERR! NODE_MODULE(buffertools, RegisterModule)
npm ERR! /home/pi/.cache/node-gyp/16.15.1/include/node/node.h:847:36: note: in definition of macro ‘NODE_MODULE_X’
npm ERR! (node::addon_register_func) (regfunc),
npm ERR! ^~~~~~~
npm ERR! ../buffertools.cc:506:1: note: in expansion of macro ‘NODE_MODULE’
npm ERR! ../buffertools.cc:506:26: note: suggested alternative: ‘register_t’
npm ERR! ^~~~~~~
npm ERR! ../buffertools.cc: In instantiation of ‘v8::Localv8::Value {anonymous}::BinaryAction::operator()(const v8::FunctionCallbackInfov8::Value&) [with Derived = {anonymous}::CompareAction]’:
npm ERR! ../buffertools.cc:432:1: required from here
npm ERR! ../buffertools.cc:177:25: error: no matching function for call to ‘v8::String::Utf8Value::Utf8Value(v8::Localv8::Value)’
npm ERR! ^
npm ERR! ^~~~~~~~~
npm ERR! ../buffertools.cc: In instantiation of ‘v8::Localv8::Value {anonymous}::BinaryAction::operator()(const v8::FunctionCallbackInfov8::Value&) [with Derived = {anonymous}::EqualsAction]’:
npm ERR! ../buffertools.cc:433:1: required from here
npm ERR! ^
npm ERR! ^~~~~~~~~
npm ERR! ../buffertools.cc: In instantiation of ‘v8::Localv8::Value {anonymous}::BinaryAction::operator()(const v8::FunctionCallbackInfov8::Value&) [with Derived = {anonymous}::IndexOfAction]’:
npm ERR! ../buffertools.cc:436:1: required from here
npm ERR! ^
npm ERR! ^~~~~~~~~
npm ERR! ../buffertools.cc:441:23: warning: ‘void {anonymous}::Concat(const v8::FunctionCallbackInfov8::Value&)’ defined but not used [-Wunused-function]
npm ERR! UNI_FUNCTION_CALLBACK(Concat) {
npm ERR! ^~~~~~
npm ERR! ../buffertools.cc:55:10: note: in definition of macro ‘UNI_FUNCTION_CALLBACK’
npm ERR! void name(const v8::FunctionCallbackInfov8::Value& args)
npm ERR! ^~~~
npm ERR! ../buffertools.cc:438:3: warning: ‘void {anonymous}::ToHex(const v8::FunctionCallbackInfov8::Value&)’ defined but not used [-Wunused-function]
npm ERR! V(ToHex)
npm ERR! ^~~~~
npm ERR! ^~~~
npm ERR! ../buffertools.cc:438:1: note: in expansion of macro ‘V’
npm ERR! V(ToHex)
npm ERR! ^
npm ERR! ../buffertools.cc:437:3: warning: ‘void {anonymous}::Reverse(const v8::FunctionCallbackInfov8::Value&)’ defined but not used [-Wunused-function]
npm ERR! V(Reverse)
npm ERR! ^~~~~~~
npm ERR! ^~~~
npm ERR! ../buffertools.cc:437:1: note: in expansion of macro ‘V’
npm ERR! V(Reverse)
npm ERR! ^
npm ERR! ../buffertools.cc:436:3: warning: ‘void {anonymous}::IndexOf(const v8::FunctionCallbackInfov8::Value&)’ defined but not used [-Wunused-function]
npm ERR! V(IndexOf)
npm ERR! ^~~~~~~
npm ERR! ^~~~
npm ERR! ../buffertools.cc:436:1: note: in expansion of macro ‘V’
npm ERR! V(IndexOf)
npm ERR! ^
npm ERR! ../buffertools.cc:435:3: warning: ‘void {anonymous}::FromHex(const v8::FunctionCallbackInfov8::Value&)’ defined but not used [-Wunused-function]
npm ERR! V(FromHex)
npm ERR! ^~~~~~~
npm ERR! ^~~~
npm ERR! ../buffertools.cc:435:1: note: in expansion of macro ‘V’
npm ERR! V(FromHex)
npm ERR! ^
npm ERR! ../buffertools.cc:434:3: warning: ‘void {anonymous}::Fill(const v8::FunctionCallbackInfov8::Value&)’ defined but not used [-Wunused-function]
npm ERR! V(Fill)
npm ERR! ^~~~
npm ERR! ^~~~
npm ERR! ../buffertools.cc:434:1: note: in expansion of macro ‘V’
npm ERR! V(Fill)
npm ERR! ^
npm ERR! ../buffertools.cc:433:3: warning: ‘void {anonymous}::Equals(const v8::FunctionCallbackInfov8::Value&)’ defined but not used [-Wunused-function]
npm ERR! V(Equals)
npm ERR! ^~~~~~
npm ERR! ^~~~
npm ERR! ../buffertools.cc:433:1: note: in expansion of macro ‘V’
npm ERR! V(Equals)
npm ERR! ^
npm ERR! ../buffertools.cc:432:3: warning: ‘void {anonymous}::Compare(const v8::FunctionCallbackInfov8::Value&)’ defined but not used [-Wunused-function]
npm ERR! V(Compare)
npm ERR! ^~~~~~~
npm ERR! ^~~~
npm ERR! ../buffertools.cc:432:1: note: in expansion of macro ‘V’
npm ERR! V(Compare)
npm ERR! ^
npm ERR! ../buffertools.cc:431:3: warning: ‘void {anonymous}::Clear(const v8::FunctionCallbackInfov8::Value&)’ defined but not used [-Wunused-function]
npm ERR! V(Clear)
npm ERR! ^~~~~
npm ERR! ^~~~
npm ERR! ../buffertools.cc:431:1: note: in expansion of macro ‘V’
npm ERR! V(Clear)
npm ERR! ^
npm ERR! make: *** [buffertools.target.mk:109: Release/obj.target/buffertools/buffertools.o] Error 1
npm ERR! gyp ERR! build error
npm ERR! gyp ERR! stack Error: make failed with exit code: 2
npm ERR! gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:527:28)
npm ERR! gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)
npm ERR! gyp ERR! System Linux 5.10.103-v7+
npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
npm ERR! gyp ERR! cwd /home/pi/node_modules/buffertools
npm ERR! gyp ERR! node -v v16.15.1
npm ERR! gyp ERR! node-gyp -v v9.0.0
npm ERR! gyp ERR! not ok
npm ERR! /home/pi/.npm/_logs/2022-07-01T14_24_18_745Z-debug-0.log
is it correct that I am on the desktop
Are you trying to install the node-red grovepi node i.e. node-red-contrib-grovepi?
If so, and if you want to install it manually, you want to be in the .node-red sub directory. Try this:
cd $HOME/.node-red
npm install node-red-contrib-grovepi
Good friend I will try
pi@raspberrypi:~ $ cd $HOME/.node-red
pi@raspberrypi:~/.node-red $ npm install node-red-contrib-grovepi
npm ERR! code 1
npm ERR! path /home/pi/.node-red/node_modules/buffertools
npm ERR! make: Entering directory '/home/pi/.node-red/node_modules/buffertools/build'
npm ERR! make: Leaving directory '/home/pi/.node-red/node_modules/buffertools/build'
npm ERR! gyp info spawn args '/home/pi/.node-red/node_modules/buffertools/build/config.gypi',
npm ERR! gyp info spawn args '-Dmodule_root_dir=/home/pi/.node-red/node_modules/buffertools',
npm ERR! ^~~~~~
npm ERR! ^
npm ERR! ^~~~~~~~
npm ERR! ^
npm ERR! ^~~~~~~~~
npm ERR! ^
npm ERR! ^~~~~~~~
npm ERR! ^
npm ERR! ^~~~~~~~~
npm ERR! ^
npm ERR! ^~~~~~~~
npm ERR! ^
npm ERR! ^~~~~~~~~
npm ERR! ^
npm ERR! ^~~~~~~~~~
npm ERR! ^
npm ERR! ^~~~~~~~~
npm ERR! ^
npm ERR! ^~~~~~~~
npm ERR! ^
npm ERR! ^~~~~~~~~
npm ERR! ^
npm ERR! ^~~~~~~~~~
npm ERR! ^
npm ERR! ^~~~~
npm ERR! ^
npm ERR! ^~~~~
npm ERR! ^
npm ERR! ^~~~~~~~
npm ERR! ^
npm ERR! ^~~~~~~~
npm ERR! ^
npm ERR! ^~~~~~~~~
npm ERR! ^
npm ERR! ^~~~~~~~~
npm ERR! ^
npm ERR! ^~~~~~~~
npm ERR! ^
npm ERR! ^~~~~
npm ERR! ^~~~~~
npm ERR! ^~~~~~
npm ERR! rand_r
npm ERR! ^
npm ERR! ^~~~~~
npm ERR! ^~~~~~
npm ERR! tzset
npm ERR! ^~~~~~~
npm ERR! ^~~~~~~
npm ERR! ^
npm ERR! ^~~~~~~~~
npm ERR! ^
npm ERR! ^~~~~~~~~
npm ERR! ^
npm ERR! ^~~~~~~~~
npm ERR! ^~~~~~
npm ERR! ^~~~
npm ERR! V(ToHex)
npm ERR! ^~~~~
npm ERR! ^~~~
npm ERR! V(ToHex)
npm ERR! ^
npm ERR! V(Reverse)
npm ERR! ^~~~~~~
npm ERR! ^~~~
npm ERR! V(Reverse)
npm ERR! ^
npm ERR! V(IndexOf)
npm ERR! ^~~~~~~
npm ERR! ^~~~
npm ERR! V(IndexOf)
npm ERR! ^
npm ERR! V(FromHex)
npm ERR! ^~~~~~~
npm ERR! ^~~~
npm ERR! V(FromHex)
npm ERR! ^
npm ERR! V(Fill)
npm ERR! ^~~~
npm ERR! ^~~~
npm ERR! V(Fill)
npm ERR! ^
npm ERR! V(Equals)
npm ERR! ^~~~~~
npm ERR! ^~~~
npm ERR! V(Equals)
npm ERR! ^
npm ERR! V(Compare)
npm ERR! ^~~~~~~
npm ERR! ^~~~
npm ERR! V(Compare)
npm ERR! ^
npm ERR! V(Clear)
npm ERR! ^~~~~
npm ERR! ^~~~
npm ERR! V(Clear)
npm ERR! ^
npm ERR! gyp ERR! cwd /home/pi/.node-red/node_modules/buffertools
npm ERR! /home/pi/.npm/_logs/2022-07-01T14_55_29_135Z-debug-0.log
What version of node-red and node.js are you running? You can find this in the node-red startup log.
Also what version of raspberryPi is are you running?
the node-red version and raspberry are as follows
node-red v16.15.1
Raspberry Pi Os (legacy)
Ther latest version of node-red is 3.0.0 beta 4
What you have reported is probably the version of node.js.
Please copy the node-red startup log and paste it in a reply from when it starts to when it says it is ready.
Then run
cat /etc/os-release
And paste the results in the reply
pi@raspberrypi:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="RaspbianForums - Raspbian"
BUG_REPORT_URL="RaspbianBugs - Raspbian"
You have not provided the NR start up log. Run
node-red
and copy and paste this part of the log
30 Jun 11:59:43 - [info]
Welcome to Node-RED
30 Jun 11:59:43 - [info] Node-RED version: v3.0.0-beta.3
30 Jun 11:59:43 - [info] Node.js  version: v14.16.0
30 Jun 11:59:43 - [info] Darwin 21.4.0 x64 LE
30 Jun 11:59:44 - [info] Loading palette nodes
30 Jun 11:59:45 - [info] Worldmap version 2.28.3
30 Jun 11:59:45 - [info] Dashboard version 3.1.7 started at /ui
30 Jun 11:59:45 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
30 Jun 11:59:45 - [info] Settings file  : /Users/Paul/.node-red/settings.js
30 Jun 11:59:45 - [info] HTTP Static    : /Users/Paul/node-red-static > /
30 Jun 11:59:45 - [info] Context store  : 'default' [module=localfilesystem]
30 Jun 11:59:45 - [info] Context store  : 'memory' [module=memory]
30 Jun 11:59:45 - [info] User directory : /Users/Paul/.node-red
30 Jun 11:59:45 - [info] Projects directory: /Users/Paul/.node-red/projects
30 Jun 11:59:45 - [info] Server now running at http://127.0.0.1:1880/
30 Jun 11:59:46 - [info] Active project : NASA-WildFires
30 Jun 11:59:46 - [info] Flows file     : /Users/Paul/.node-red/projects/NASA-WildFires/flow.json
30 Jun 11:59:46 - [warn] Using unencrypted credentials
30 Jun 11:59:46 - [info] Starting flows
30 Jun 11:59:46 - [info] Started flows
I would suggest you open an issue on the node’s GitHub page but you should note that the node has not been updated in over 4 years
