Communicate with Ethernet/IP non PLC device
Hi there, I've been using Codesys to communicate with Cube 67 Ethernet/IP from Murr Elektronics, but I want to do it straight from NodeRed.
The problem is that I have no idea how to perform it. I've been trying to find any direction about it without luck.
So far, I know it uses port 44818 to make connection and port 2222 to send data.
It also connect using pccc, however, it fails since I'm not sure if I must add route (if so, which route), and the variable name.
I also tried eth-ip, which is always offline. Probably the slot.
I can also try using python or any other way to reverse it.
Hope anyone can help me.
@gfcittolin and @machadotiago , you are the ones that are behind those packages. Any tips?
