Communication with multiple node with id
hi hello every one .
I have a question : in the node red can I send a message from node to another node using only the id of the node ???
some time I need to reset the value of the node from multiple place that's why .
and thanx.
Just wire the nodes up using the normal method and send the reset message. To tidy the wiring you can use Link nodes.
Not really, that isn't the way it is designed to work.
You should connect a node to 1 or more other nodes via a wire or via a link-out/link-in node pair.
