Hi there
Another complete node related question.
This flow:
[{"id":"5ae6a7d5d44da483","type":"inject","z":"10642cf9052e8079","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[1,2,3,4]","payloadType":"json","x":460,"y":935,"wires":[["a43bfbe080a30b79"]]},{"id":"70cab6b8dd684978","type":"complete","z":"10642cf9052e8079","name":"","scope":["abc967b029d98d09"],"uncaught":false,"x":928,"y":690,"wires":[["e763535a1e29636d"]]},{"id":"e763535a1e29636d","type":"debug","z":"10642cf9052e8079","name":"debug 394","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"","statusType":"counter","x":1270,"y":531,"wires":[]},{"id":"abc967b029d98d09","type":"join","z":"10642cf9052e8079","name":"","mode":"custom","build":"array","property":"","propertyType":"full","key":"topic","joiner":"\\n","joinerType":"str","useparts":false,"accumulate":false,"timeout":"","count":"4","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":934,"y":935,"wires":[["4f76292218f702a4"]]},{"id":"a43bfbe080a30b79","type":"split","z":"10642cf9052e8079","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","property":"payload","x":712,"y":800,"wires":[["abc967b029d98d09"]]},{"id":"4f76292218f702a4","type":"debug","z":"10642cf9052e8079","name":"debug 395","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"","statusType":"counter","x":1242,"y":783,"wires":[]}]
And the debug output:
The complete node is listening to the join node, the join node is set to manual 4 messages. The complete gets four message from the the join but they just contain the contents of the message it received (i,e, 1, 2, 3, 4). The single message the join actually generates (represented by the output of debug 395) is an array of four objects but this single message of the join isn't sent to the complete node.
Is that a bug or a feature? When is a join node "complete" in the sense that it should send a message to the complete node? I would have thought that the complete node would only receive the array of four objects. If the complete node were to be listening to the split node, then it should receive the 1,2,3,4 messages ....
