Concatenate and string
I have an environment variable named ip-address and can assign access it using ${ip-address}.
For example I assign it to a dashboard text node label or use it in a change node to set a message field.
I use it because the rig I have moves around and it used with different networks so I change the variable and it is reflected on may nodes.
But I would like to be able to simplify matters even further.
If I set ip-address ro just the first three octets, ie 192.168.1. then I can use it to change further nodes.
For example, I have three nodes that are set to 192.168.1.11, 192.168.1.12, 192.168.1.13.
I could then assign something like ${ip-address} + "1", ${ip-address} + "2", ${ip-address} + "3" to set them accordingly.
Rather than change 3 (or more) places, then I change just one.
Unfortunately I cannot figure out the syntax, the + "1" does not work. Is it possible to do?
As per the docs:
This only works if it replaces the entire property - it cannot be used to substitute just part of the value. For example, it is not possible to use CLIENT-${HOST} .
However, if the field where you are using it is a TypedInput (where it has the $ env selection) then it is possible e.g. ${ip-address}1
The only other option is to use a change node, function node, or other node to do the string concatenation.
Example Function:
msg.ip = env.get('ip-address') + '1'
return msg
The change node appears to accept a typed input (see test1 below) but then adding suffixes, whether with no concatenate characters or a plus symbol does not work.
(Note that I am only assigning to a flow variable because it is very quick and easy to monitor the resulting values)
Try using the env type input
As Steve noted
Thank you, that works in a change node perfectly.
How can I also make it work in a standard text field that accepts typed inputs?
I tried ${ip-address} which is fine but ${ip-address}1 or even ${ip-address}${another-var} both fail.
You cannot
Instead, you would need to do it in a function or change node using JSONata
or
in a template node
{{env.ip_prefix}}1
As per the docs
Ah, I missed that!
So, I am trying another tactic, because it better suits my workflow (I get the details that way): an array of addresses, ie ["192.168.1.1","192.168.1.2","192.168.1.3"] which I assign as a JSON string
Trouble is trying to access the elements, ${ip-address[0]} was my guess, which is incorrect. How far off is my syntax?
You would not us env input.
You would use msg input
msg. ip-address[0]
If the json is in a env var, then first set it to a msg var.
So would require two rules.
set
msg. ìp-address
to
$ ip-address
then
set
msg. ip-address
to
msg. ip-address[0]
Or
with one rule use JSONata input
set
msg. ip-address
to
J: $env("ip-address")[0]
