Function Code Help in concatenating
I need a liitle help in converting the below Change node to a function node.
I have many such nodes to be deployed, and hence would like to know how to do it using a function node, where replication and correction is easier.
the below change node is working for me, however, i need 20 of such nodes to be deployed and if i have to change a little i need to do that again for all those nodes..
requirement; concatenate several payloads into a string by adding a delimitor and a line break after every three payload.
I am using a change node with Jsonata with following expression and it works.
payload[0].M00&"-"&payload[1].M00&"-"&payload[2].M00 &'<br>'&payload[3].M00&"-"&payload[4].M00&"-"&payload[5].M00 &'<br>'&payload[6].M00&"-"&payload[7].M00&"-"&payload[8].M00 &'<br>'&payload[9].M00&"-"&payload[10].M00&"-"&payload[11].M00 &'<br>'&payload[12].M00&"-"&payload[13].M00&"-"&payload[14].M00
Inject node with example data
[{"id":"53210fd7a90bf482","type":"inject","z":"8aeac5104f2cecfe","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"2\",\"M04\":\"23\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"19\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"15\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"20\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"}]","payloadType":"json","x":2560,"y":3260,"wires":[[]]}]
[{"id":"b0126124c78c8e09","type":"change","z":"8aeac5104f2cecfe","name":"","rules":[{"t":"set","p":"lmm00","pt":"flow","to":"payload[0].M00&\"-\"&payload[1].M00&\"-\"&payload[2].M00 &'<br>'&payload[3].M00&\"-\"&payload[4].M00&\"-\"&payload[5].M00 &'<br>'&payload[6].M00&\"-\"&payload[7].M00&\"-\"&payload[8].M00 &'<br>'&payload[9].M00&\"-\"&payload[10].M00&\"-\"&payload[11].M00 &'<br>'&payload[12].M00&\"-\"&payload[13].M00&\"-\"&payload[14].M00\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":2160,"y":3100,"wires":[[]]}]
You could simply link call to the change node or function node or template node. then you would only need to edit one node.
[{"id":"7eb9d0e6bcd5828c","type":"link out","z":"d1395164b4eec73e","name":"link out 10","mode":"return","links":[],"x":585,"y":5820,"wires":[]},{"id":"ac6113c688c46110","type":"link call","z":"d1395164b4eec73e","name":"","links":["df2ac56e3f59eacc"],"linkType":"static","timeout":"30","x":470,"y":5920,"wires":[["301a4a0e6e49af13"]]},{"id":"53210fd7a90bf482","type":"inject","z":"d1395164b4eec73e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"2\",\"M04\":\"23\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"19\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"15\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"20\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"}]","payloadType":"json","x":290,"y":5920,"wires":[["ac6113c688c46110"]]},{"id":"7ed5527956e06e37","type":"inject","z":"d1395164b4eec73e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"2\",\"M04\":\"23\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"19\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"15\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"20\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"}]","payloadType":"json","x":310,"y":5980,"wires":[["b8d2089c6fb69cd7"]]},{"id":"b8d2089c6fb69cd7","type":"link call","z":"d1395164b4eec73e","name":"","links":["df2ac56e3f59eacc"],"linkType":"static","timeout":"30","x":490,"y":5980,"wires":[["37e8274009b7e6a0"]]},{"id":"37e8274009b7e6a0","type":"debug","z":"d1395164b4eec73e","name":"debug 2558","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":670,"y":5980,"wires":[]},{"id":"301a4a0e6e49af13","type":"debug","z":"d1395164b4eec73e","name":"debug 2557","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":650,"y":5920,"wires":[]},{"id":"df2ac56e3f59eacc","type":"link in","z":"d1395164b4eec73e","name":"concat_node","links":[],"x":175,"y":5820,"wires":[["b0126124c78c8e09"]]},{"id":"b0126124c78c8e09","type":"change","z":"d1395164b4eec73e","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload[0].M00&\"-\"&payload[1].M00&\"-\"&payload[2].M00 &'<br>'&payload[3].M00&\"-\"&payload[4].M00&\"-\"&payload[5].M00 &'<br>'&payload[6].M00&\"-\"&payload[7].M00&\"-\"&payload[8].M00 &'<br>'&payload[9].M00&\"-\"&payload[10].M00&\"-\"&payload[11].M00 &'<br>'&payload[12].M00&\"-\"&payload[13].M00&\"-\"&payload[14].M00\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":400,"y":5820,"wires":[["7eb9d0e6bcd5828c"]]}]
Concat in a function uses + so simply change & to + and add msg. to your vars, but this is the perfect job for a template node.
[edit]
Or a lowcode way, with two split and join nodes. You can even pass the property key you wish to use.
[{"id":"301a4a0e6e49af13","type":"debug","z":"d1395164b4eec73e","name":"debug 2557","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":650,"y":5920,"wires":[]},{"id":"df2ac56e3f59eacc","type":"link in","z":"d1395164b4eec73e","name":"concat_node","links":[],"x":125,"y":5780,"wires":[["4a32df112f78397e"]]},{"id":"4a32df112f78397e","type":"split","z":"d1395164b4eec73e","name":"","splt":"\\n","spltType":"str","arraySplt":"3","arraySpltType":"len","stream":false,"addname":"","x":210,"y":5780,"wires":[["b7bf5974c27fcb54"]]},{"id":"b7bf5974c27fcb54","type":"split","z":"d1395164b4eec73e","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":270,"y":5820,"wires":[["e0865c36335cc95f"]]},{"id":"e0865c36335cc95f","type":"change","z":"d1395164b4eec73e","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload[msg.topic]","tot":"msg"},{"t":"set","p":"parts.type","pt":"msg","to":"string","tot":"str"},{"t":"set","p":"parts.ch","pt":"msg","to":"-","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":5820,"wires":[["e4bb4ed58e4f3f6c"]]},{"id":"e4bb4ed58e4f3f6c","type":"join","z":"d1395164b4eec73e","name":"","mode":"auto","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":"false","timeout":"","count":"","reduceRight":false,"x":590,"y":5820,"wires":[["c140c9efad66434d"]]},{"id":"c140c9efad66434d","type":"change","z":"d1395164b4eec73e","name":"","rules":[{"t":"set","p":"parts.type","pt":"msg","to":"string","tot":"str"},{"t":"set","p":"parts.ch","pt":"msg","to":"<br>","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":5860,"wires":[["51a9e78b23e7811f"]]},{"id":"51a9e78b23e7811f","type":"join","z":"d1395164b4eec73e","name":"","mode":"auto","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":"false","timeout":"","count":"","reduceRight":false,"x":470,"y":5860,"wires":[["7eb9d0e6bcd5828c"]]},{"id":"7eb9d0e6bcd5828c","type":"link out","z":"d1395164b4eec73e","name":"link out 10","mode":"return","links":[],"x":745,"y":5860,"wires":[]},{"id":"7ed5527956e06e37","type":"inject","z":"d1395164b4eec73e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"M04","payload":"[{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"2\",\"M04\":\"23\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"19\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"0\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"15\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"},{\"M00\":\"0\",\"M01\":\"0\",\"M02\":\"0\",\"M03\":\"20\",\"M04\":\"24\",\"M05\":\"0\",\"M06\":\"0\",\"M07\":\"0\",\"M08\":\"0\",\"M09\":\"0\",\"M10\":\"0\",\"M11\":\"0\",\"M15\":\"0\",\"M16\":\"0\",\"M18\":\"0\",\"M20\":\"20\",\"M21\":\"0\",\"M22\":\"0\",\"M23\":\"0\"}]","payloadType":"json","x":310,"y":5980,"wires":[["b8d2089c6fb69cd7","ac6113c688c46110"]]},{"id":"ac6113c688c46110","type":"link call","z":"d1395164b4eec73e","name":"","links":["df2ac56e3f59eacc"],"linkType":"static","timeout":"30","x":470,"y":5940,"wires":[["301a4a0e6e49af13"]]},{"id":"b8d2089c6fb69cd7","type":"link call","z":"d1395164b4eec73e","name":"","links":["df2ac56e3f59eacc"],"linkType":"static","timeout":"30","x":490,"y":5980,"wires":[["37e8274009b7e6a0"]]},{"id":"37e8274009b7e6a0","type":"debug","z":"d1395164b4eec73e","name":"debug 2558","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":670,"y":5980,"wires":[]}]
Thank you!!
