Help to reduce these two nodes please (appending time to payload)
Hi all,
I feel I am getting the syntax wrong when trying to combine these two nodes into one function node.
The first node sets the payload to JSON $moment().tz("Europe/London").format("ddd DD/MM/YYYY HH:mm:ss")
The second function node appends the message:
msg.payload = (msg.payload + " Battery level at 75% "); return msg;
I'd like to reduce clutter and make it work with only one function node.
But this does not work:
msg.payload = (($moment().tz("Europe/London").format("ddd DD/MM/YYYY HH:mm:ss")) + " Battery level at 75% "); return msg;
Flow exported:
[{"id":"476ec4eb.518bdc","type":"function","z":"3b92f612.6f7b5a","name":"Battery level 75%","func":"msg.payload = (msg.payload + \" Battery level at 75% \");\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1770,"y":1830,"wires":[["b3a323f1.d0188"]]},{"id":"e3b25975.cd1ec8","type":"change","z":"3b92f612.6f7b5a","name":"Add time","rules":[{"t":"set","p":"payload","pt":"msg","to":"$moment().tz(\"Europe/London\").format(\"ddd DD/MM/YYYY HH:mm:ss\")","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1580,"y":1830,"wires":[["476ec4eb.518bdc"]]}]
Any help would be appreciated.
Try this, just using the change node (or do you really want to use a function node??);
[{"id":"e3b25975.cd1ec8","type":"change","z":"b3b413d1.05b1b","name":"Add time","rules":[{"t":"set","p":"payload","pt":"msg","to":"$moment().tz(\"Europe/London\").format(\"ddd DD/MM/YYYY HH:mm:ss\")","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"payload&\" Battery level at 75% \"","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":1295,"wires":[["e531186332827979"]]},{"id":"e531186332827979","type":"debug","z":"b3b413d1.05b1b","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":495,"y":1295,"wires":[]},{"id":"d896b492c537fb01","type":"inject","z":"b3b413d1.05b1b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":85,"y":1295,"wires":[["e3b25975.cd1ec8"]]}]
time
I would suggest using the change node, because AFAIK, the moment library is not available in the function node, and you would have to load the library as an external module.
Yes that works thanks! I just assumed I would need a function node.
If I wanted to dynamically replace the text with another message e.g. msg.payload.info, would it work if that second "Set" became payload& msg.payload.info ?
I would tend to use a topic to define the text - just personal preference.
so msg.level = "10" and the jsonata would be payload&" Battery level at "&level&"%" would give you "Sat 24/07/2021 20:39:19 Battery level at 10%"
It will also work if the level is a number - msg.level = 10
Excellent thank you very much Paul :+1:
