How to pass variables values to Function node?
I need to use this pass these values in a Function node:
msg.payload = '[{ "time”:”TIMESTAMP”,”entity": "entity1", "type": "living_room", "state": “STATE_VALUE”, "value": "2", "location":"bedroom" }]';
All values in capital letters have to be replaced with the actual values from the previous node. I tried using this, but it won't work:
msg.payload = '[{ "time”:”TIMESTAMP”,”entity": "entity1", "type": "living_room", "state": “{{{click}}}”, "value": "2", "location":"bedroom" }]';
Previous node is setup this way:
org%202019-02-15%2022-19-09
Any ideas? Also, any way to get the timestamp on that?
Thanks!
Hi @Traste
You say all the properties in capital letters need to be replaced, I can see TIMEZONE STATE_VALUE and VALUE - what are the properties of the message you are passing the function that contain those values? msg.payload.TIMEZONE? or something else?
Thanks for replying. So sorry, but I just noticed I did not paste it the data properly. I wanted to write "timestamp" instead of timezone, and only 1 variable more. I edited my message :sweat_smile:
So, I need:
  • TIMESTAMP: a way to add the current time with the timestamp format
  • STATE_VALUE: I get this value from the previous node, from msg.click, as per my image
Thanks!
As you want it to be a JSON String, the easiest way to create the string is to create the javascript object and then convert it to JSON.
var myObject = [
        "time": Date.now(),
        "entity": "entity1",
        "state": msg.click
        "value": "2",
        "location": "bedroom"
msg.payload JSON.stringify(myObject);
You haven't said anything about the required format of the timestamp - I've used Date.now() to get the current time in milliseconds since epoch. If you need a different format, that are countless examples of generating timestamps in JavaScript using the Date object.
That really does sound great! Although I'm getting some kind of syntax error. Sorry, I'm new to coding :-/
org%202019-02-15%2022-53-06
Oops - I missed a comma after msg.click.
Thanks! I got it working with this syntax:
var myObject = [
        "time": new Date().toISOString(),
        "state": msg.click,
        "value": "2",
msg.payload= JSON.stringify(myObject);
You made my day!
As I said, thanks a million!
I would be interested to know why you want it as a JSON string rather than a js object.
I'm using the BigQuery insert node, and that's the output format it needs :slight_smile:
I see you are right, how unusual, normally one would expect to pass in an object not a json string.
