Hi all,
I am new here, so please excuse me if i'm posting this in the wrong topic.
I am using node-red to interface with my blockchain and need to pass the following arguments:
[2021-05-13T22:29:44.150] [DEBUG] BasicNetwork - channelName : mychannel
[2021-05-13T22:29:44.151] [DEBUG] BasicNetwork - chaincodeName : Multicontracts_cc
[2021-05-13T22:29:44.151] [DEBUG] BasicNetwork - fcn : CreateSensData
[2021-05-13T22:29:44.151] [DEBUG] BasicNetwork - args : {"id":"4","name":"test2","temp":21,"time": 2021:05:11 20:00:00}
And i'm using the following code:
temp = msg.payload.d.ambientTemp;
var date = new Date();
var options = { timeZone: 'Europe/Malta', year: 'numeric', month: '2-digit', day: '2-digit', hour: '2-digit', minute: '2-digit', second: '2-digit' };
var time = date.toLocaleDateString('tr-TR', options);
msg.payload = {"fcn": "CreateSensData",
"chaincodeName":"Multicontracts_cc",
"channelName": "mychannel",
"args": ["{\"id\":\"4\",\"name\":\"test2\",\"addedAt\":1600065054,\"temp\": temp, \"time\": time"]};
msg.headers = {'content-type':'application/json'};
Any ideas how can i pass the temp and time variables to the abive msg payload please?
Thanks!
Ranki
2
Hi Krisbarb,
Why do you escape all the parameters in args?
You can create the object args first (the same way you do it with the msg.payload object) and assign it afterwards directly with „args“: args
Edit: Ah, or do you need the JSON-String inside? Check this: JSON.stringify() - JavaScript | MDN
Cheers
Ranki
Ranki
4
I edited my entry; have a look here: JSON.stringify() - JavaScript | MDN
Appreciate it mate! Let me have a look at this function
@Ranki do you have experience with this function, can i ask you how would you use it with my above code?
Thanks once again for your help
E1cid
7
You can add time var string to the msg.payload string like below
"args": ["{\"id\":\"4\",\"name\":\"test2\",\"addedAt\":1600065054,\"temp\": temp, \"time\": \"" + time +"\""]};
you can also add temp
"args": ["{\"id\":\"4\",\"name\":\"test2\",\"addedAt\":1600065054,\"temp\": \"" + temp + "\", \"time\": \"" + time +"\""]};```
Thanks, will give it a try tonight. much appreciate it
E1cid
9
also you can do this using single quotes around string.
"args": ['{"id":"4","name":"test2","addedAt":1600065054,"temp": "' + temp + '", "time": "' + time + '"']};
or this using backticks around string and use ${var}
"args": [`{"id":"4","name":"test2","addedAt":1600065054,"temp": "${temp}", "time": "${time}"`]};
Ranki
10
Hi @krisbarb,
I implemented your code and adjusted it with the stringify-function:
var temp = 23;
var args = {"id":"4","name":"test2","addedAt":1600065054,"temp": temp, "time": time};
"args": JSON.stringify(args)};
The result looks like this; I think this is, what you wanted to achive, isn't it?
Cheers
Ranki
