Hi, I am developing a custom node via packaging a subflow as a module, however I am having one problem, inside this subflow I am using the set of Redis nodes and in order to properly use this nodes, a Redis config node is necessary in order to prepare the conectivity to Redis.
When this subflow is still just a subflow everything works fine, however when I package my subflow as a module and import it via "npm i", this config node is not added, even when it is present on the json file of the subflow.
The image indicates that the "server" is the id of the config node present on the json file.
So, how can I package this config node inside my subflow alongside all the other nodes?
