Configuration node not showing in node
I'm trying to build an own node using a configuration template as described here: https://nodered.org/docs/creating-nodes/config-nodes
In my node's properties only the "name" property appears, not the remote-server setting.
Here is my package.json (part):
"node-red" : {
    "nodes": {
        "remote-server": "remote-server.js",
        "rcpulse": "rcpulse.js"
remote-server.js and remote-server.html are excactely as in documentation.
In my rcpulse.html I added:
defaults: {
            server: {value:"", type:"remote-server", required: true}
In my rcpulse.js I have:
function RCPulseNode(config) {
        RED.nodes.createNode(this,config);
        this.server = RED.nodes.getNode(config.server);
In the palette settings both my own node and the remote-server node appear. What am I missing?
Kind regards
S
do you have added an input tag to your rcpulse.html for the config node?
something like <input type="text" id="node-input-server">
