i am quite new to JavaScript/Node/NodeRed development but not to coding as it.
I did follow following this tutorial but fail to get an dialog to create a new Configuration Node.
I whould like to have a drop down of all, already created remote-servers and the option to create a new one. How should the html part of the node should look like?
thanks
JGKK
23 June 2020 11:01
2
In the defaults part of your nodes script you need to add this:
yourNodeConfig: {value:"", type: "yourNode-config"},
and than in the html part:
<div class="form-row">
<label for="node-input-yourNodeConfig"><i class="fa fa-cog"></i> Config</label>
<!-- Node-Red will replace this input element by a drop-down (with available configurations) -->
<input type="text" id="node-input-yourNodeConfig">
</div>
I am definitly doing something wrong.
I have the feeling the naming is important.
Here are my files:
First the ConfigNode files:
cdcapinode.html
RED.nodes.registerType('cdcapinode',{
category: 'config',
defaults: {
host: {value:"localhost",required:true},
port: {value:1234,required:true,validate:RED.validators.number()},
label: function() {
return this.host+":"+this.port;
</script>
<script type="text/html" data-template-name="cdcapinode">
<label for="node-config-input-host"><i class="icon-bookmark"></i> Host</label>
<input type="text" id="node-config-input-host">
</div>
<label for="node-config-input-port"><i class="icon.9
-bookmark"></i> Port</label>
<input type="text" id="node-config-input-port">
</div>
</script>
cdcapinode.js
module.exports = function(RED) {
function CdcApiNode(n) {
RED.nodes.createNode(this,n);
this.host = n.host;
this.port = n.port;
RED.nodes.registerType("cdcapinode",CdcApiNode);
Then the nodes that should use it:
lower-case.html
RED.nodes.registerType('lower-case',{
category: 'function',
color: '#a6bbcf',
defaults: {
server: {value:"", type:"cdcapinode"},
prefix: {value:""},
inputs:1,
outputs:1,
icon: "hash.png",
label: function() {
return this.name||"lower-case";
</script>
<script type="text/html" data-template-name="lower-case">
<label for="node-input-cdcapinode"><i class="fa fa-cog"></i> cdcapinode</label>
<input type="text" id="node-input-cdcapinode">
</div>
<label for="node-input-name"><i class="icon-tag"></i> Name</label>
<input type="text" id="node-input-name" placeholder="Name">
</div>
<label for="node-input-prefix"><i class="icon-tag"></i> Prefix</label>
<input type="text" id="node-input-prefix">
</div>
</script>
<script type="text/html" data-help-name="lower-case">
<p>A VERY simple node that converts the message payloads into all lower-case characters</p>
</script>
lower-case.js
function LowerCaseNode(config) {
RED.nodes.createNode(this,config);
var node = this;
node.on('input', function(msg) {
msg.payload = msg.payload.toLowerCase();
node.send(msg);
RED.nodes.registerType("lower-case",LowerCaseNode);
You are right to say the naming of the properties and the html elements is the key to this.
In your lower-case node, you have defined the server property as being the reference to the cdcapinode node.
In the edit dialog, the corresponding input should then have an id of node-input-server - you currently have it set to node-input-cdcapinode which is wrong.
i altered the lower-case.html to:
<input type="text" id="node-input-server">
</div>
and now it works.
as knolleary mentioned i changed
to
Many thanks for the quick replies.
