Your flow is corrupt due to not posting code in the correct way
code goes here
icon.
What is the response you get from the http resquest node?
Did you try what I said?
[edit]
The browser is a GET request but you set the http request to POST.
To append the query string mag.payload needs to be a object.
You do not require the JSON node, unless you want a JSON(string) returned rather than a Javascript object.
example flow
[{"id":"076b0c640872f1aa","type":"inject","z":"d1395164b4eec73e","name":"On","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Switch","payload":"{\"oid\":\"b05dd514\",\"prop\":\"command\",\"value\":\"off\"}","payloadType":"json","x":450,"y":5800,"wires":[["06748d9fc38754f0"]]},{"id":"06748d9fc38754f0","type":"http request","z":"d1395164b4eec73e","name":"Switch Extra","method":"GET","ret":"obj","paytoqs":"query","url":"http://192.168.1.118/iungo/api_request/object_prop_set","tls":"","persist":false,"proxy":"","insecureHTTPParser":true,"authType":"","senderr":false,"headers":[],"x":630,"y":5800,"wires":[["a69505ee9895d0ec","9ed11ab460e04bc0"]]},{"id":"a69505ee9895d0ec","type":"debug","z":"d1395164b4eec73e","name":"debug 8","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":880,"y":5720,"wires":[]},{"id":"9ed11ab460e04bc0","type":"debug","z":"d1395164b4eec73e","name":"debug 1","active":true,"tosidebar":false,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1000,"y":5800,"wires":[]}]
What you call headers are properties of the query string. headers are a completely different thing.
