No, they are in the change node.
But here's a copy where they have been sanitized, which won't of course work.
[{"id":"fe89dd5d43b6ba32","type":"inject","z":"1543d308b342690a","name":"","props":[{"p":"payload","v":"","vt":"date"},{"p":"topic","v":"","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":240,"y":2410,"wires":[["c8e007f9979e333b"]],"l":false},{"id":"c8e007f9979e333b","type":"change","z":"1543d308b342690a","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"excludeParameterMetadata\":false,\"includeLocationName\":true,\"latitude\":52.4729210,\"longitude\":-1.0567790}","tot":"json"},{"t":"set","p":"headers","pt":"msg","to":"{\"accept\":\"application/json\",\"x-ibm-client-secret\":\"eb284bCXXXXXXXX3bc\",\"x-ibm-client-id\":\"5f6c295abXXXXXXXXXXXXXXc8b8\"}","tot":"json"},{"t":"set","p":"url","pt":"msg","to":"https://api-metoffice.apiconnect.ibmcloud.com/metoffice/production/v0/forecasts/point/hourly","tot":"str"},{"t":"set","p":"method","pt":"msg","to":"GET","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":300,"y":2410,"wires":[["26566e0283a11c41"]],"l":false,"info":"[https://metoffice.apiconnect.ibmcloud.com/metoffice/production/api](https://metoffice.apiconnect.ibmcloud.com/metoffice/production/api)"},{"id":"26566e0283a11c41","type":"http request","z":"1543d308b342690a","name":"Doesn't work","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":525,"y":2430,"wires":[["da17a2650e86e8df"]]},{"id":"f820f20109811d05","type":"http request","z":"1543d308b342690a","name":"Works","method":"use","ret":"obj","paytoqs":"query","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":506,"y":2394,"wires":[["da17a2650e86e8df"]]},{"id":"da17a2650e86e8df","type":"debug","z":"1543d308b342690a","name":"debug 22","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":695,"y":2410,"wires":[]}]
