Struggling with sending HTTP requests to the "http in" node
Hi colleagues,
I'm currently learning web development based on HTTP/JS.
Node-RED: 1.2.9
My current problem/challenge is the following:
I want to transfer a simple JSON object from HTTP/JS code in my browser via the http-in node into a node-red function node for further processing:
JS snippet executed in Browser
 const myInit = {
  method: 'POST',
  headers: {"Header":"MyHeader"},
  mode: 'no-cors',
  cache: 'default',
  body: {"Body":"MyBody"}
 data=fetch('https://nodered/ButtonReceiver?Name=123456',myInit)
On the Node-Red Server side I've set the following
http-in node is configured as "POST" and the URL above.
Executing the js script provides no errors, ( HTTP:200)
but:
the payload coming from the node's output is always "[object ] [object]", and I can't resolve these objects.
The parameters after the "?" are transferred instead correctly
I'd appreciate to get some hints or an example, what's wrong with my approach.
And: how would I get data back into my JS from an http send node ?
Thanks in advance,
Regards Thomas
Show us how you've set up the http-in node and how it's wired to the function node.
Also have you attached a debug node to the http-in node to see exactly what is being sent?
Yes debug node is included:
[{"id":"e2fcc8b37c222ede","type":"debug","z":"f6f2187d.f17ca8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":900,"y":340,"wires":[]},{"id":"86ea9e9c9abe64d8","type":"http response","z":"f6f2187d.f17ca8","name":"output","statusCode":"","headers":{},"x":990,"y":280,"wires":[]},{"id":"5ad3d4e0ed235613","type":"template","z":"f6f2187d.f17ca8","name":"Template","field":"payload","fieldType":"msg","format":"html","syntax":"mustache","template":"<html>\n    <head></head>\n    <body>\n        <h1>GET: ButtonReceived</h1>\n    </body>\n</html>","output":"str","x":730,"y":280,"wires":[["86ea9e9c9abe64d8"]]},{"id":"8c2d3262.4f0a5","type":"http in","z":"f6f2187d.f17ca8","name":"HTTP IN","url":"/ButtonReceiver","method":"post","upload":false,"swaggerDoc":"","x":480,"y":340,"wires":[["e2fcc8b37c222ede","5ad3d4e0ed235613"]]}]
Thanks for taking care and: is the import of JS OK for debugging ?
Regards Thomas
I think that's possibly because you havent set the correct Headers in your request
Try doing your fetch call like this :
let requestOptions = {
  method: 'POST',
  headers: { 'Content-Type':'application/json'},
  body: { "Body": "MyBody"},
fetch("http://<yourip>:1880/ButtonReceiver", requestOptions)
  .then(response => response.json())
  .then(result => console.log(result))
  .catch(error => console.log('error', error));
also because fetch takes some time to complete (asynchronous) it always returns a Promise
so in order to get the response you need to tag on a .then.
Now if your ButtonReceiver endpoint replies back with a json that needs to be parsed response.json()
but because .json can also take some time that also returns a Promise .. yea i know :wink: .. and you need a second .then to return the actual data.
Modified the flow a bit to return a json and set your debug node to Complete msg.
[{"id":"e2fcc8b37c222ede","type":"debug","z":"4895ea10b4ee9ead","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":410,"y":940,"wires":[]},{"id":"86ea9e9c9abe64d8","type":"http response","z":"4895ea10b4ee9ead","name":"output","statusCode":"","headers":{},"x":670,"y":1020,"wires":[]},{"id":"8c2d3262.4f0a5","type":"http in","z":"4895ea10b4ee9ead","name":"HTTP IN","url":"/ButtonReceiver","method":"post","upload":false,"swaggerDoc":"","x":270,"y":1020,"wires":[["e2fcc8b37c222ede","6cd9b824e2102efa"]]},{"id":"6cd9b824e2102efa","type":"function","z":"4895ea10b4ee9ead","name":"","func":"msg.statusCode = 200\nmsg.payload = {\n    \"message\": \"Message Received\",\n    \"data\": msg.payload\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":460,"y":1020,"wires":[["86ea9e9c9abe64d8"]]}]
Some reading material and examples on Fetch
OK, I implemented your proposal, but it doesn't properly work:
There's still no content in the payload and the async reply leads to a syntax error:
JSON.parse: unexpected end of data at line 1 column 1 of the JSON data
which I would interpret as no data is delivered and therefore the parsing fails ?
the code i shared was untested.
use body: JSON.stringify({ "Body": "MyBody" }), in requestOptions to be sure we are sending json
I've checked it and "hurray" it's working. Just to be sure: body has to be a string, not a JSON ?
Because: if I define body as "
body: '({ "Body": "MyBody" })'
I get the same result. Is my conclusion correct ?
What's missing is the return value, as I still only an get empty reply.
yes exactly .. Basically JSON is a string
( a string with a special syntax that can be later parsed and used as a Javascript object )
and i believe because we have the 'application/json' headers in our request thats why node-red's http parses it as such.
What do you mean ?
Its up to you to structure the reply message .. it can be anything.
For example you can post some data to your endpoint .. the http-in node receives it in payload .. you process it .. maybe get some data from a db etc .. and then send it back to the user with the http-response node.
Thanks for the clarification !
Blockquote
Exactly that one is my problem: I can send back what ever I like and the content of my response from fetch is always empty
Simply saying ...
... makes it a little difficult to understand what could be the problem.
Show us the code :wink:
.. share the index.html or any js files you have for the front-end
and share also the Node-red flow to test so we can try to replicate it and help.
