Hi all,
I am new to node-red, although in the past I have used SMC gateways which use the same type of workflows.
What I would like to do is connect a Motorola Mototrbo radio to node red via USB so I can then send text messages through a radio system.
example if I had an alarm from a serial port then this would send a text to a radio to alert a user. does anybody know how I would achieve this?
SMC uses the following info to connect a mobile
USB connection
CAI Prefix – The CAI (Common Air Interface)
Radio ID
IP address of the mobile
Let me know if you require anymore information.
Bungouk
Node-RED makes available quite a few ways of potentially doing what you want but as I don't know your hardware, it is very difficult to guess which is best.
The first place to look is on the Flows site (link is in the menu at the top of this forum) to see if anyone has already created a node.
Possibly the next thing to look at is, because you say there is an IP address, that implies that the device has a TCP/IP or HTTP API interface - if so, you will need to investigate that API and work out what you can do with it. Node-RED can easily communicate with such interfaces.
The next option would be an existing Node.js package. The place to look is on the npm site. There you should look for a node.js package that lets you communicate with your kit.
If that doesn't show anything, the next thing to look at is whether there are command-line tools that will let you communicate with the kit.
Node-RED can work with either of these options in various ways and I'm sure that people will help once you have more information.
Good hunting.
I was browsing Github and come across the following Moto_XCMP_XNL package which says it allows sending data across radio wave.
Problem I have is i’m not sure what to do with it, would you know what needs to be done to get it working with Node-Red?
Bungouk
It is written in Java and doesn't have any releases so unless you know Java, I think you will struggle. I suggest you reach out to the developer and discuss your needs with them.
