Okay. I'll do that now.
Also, here is the flow:
[{"id":"86f3c0fa.c76ac","type":"tab","label":"Test","disabled":false,"info":""},{"id":"8e081889.c375d8","type":"ui_tab","z":"","name":"Home","icon":"dashboard","order":3,"disabled":false,"hidden":false},{"id":"e72205df.cc91d8","type":"ui_group","z":"","name":"Default","tab":"8e081889.c375d8","order":1,"disp":false,"width":12,"collapse":false},{"id":"a2f70c7.0082ff","type":"ui_base","theme":{"name":"theme-dark","lightTheme":{"default":"#0094CE","baseColor":"#000000","baseFont":"Century Gothic,CenturyGothic,AppleGothic,sans-serif","edited":true,"reset":false},"darkTheme":{"default":"#097479","baseColor":"#000000","baseFont":"Century Gothic,CenturyGothic,AppleGothic,sans-serif","edited":true,"reset":false},"customTheme":{"name":"Untitled Theme 1","default":"#4B7930","baseColor":"#4B7930","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif"},"themeState":{"base-color":{"default":"#097479","value":"#000000","edited":true},"page-titlebar-backgroundColor":{"value":"#000000","edited":false},"page-backgroundColor":{"value":"#111111","edited":false},"page-sidebar-backgroundColor":{"value":"#000000","edited":false},"group-textColor":{"value":"#262626","edited":false},"group-borderColor":{"value":"#555555","edited":false},"group-backgroundColor":{"value":"#333333","edited":false},"widget-textColor":{"value":"#eeeeee","edited":false},"widget-backgroundColor":{"value":"#000000","edited":false},"widget-borderColor":{"value":"#333333","edited":false},"base-font":{"value":"Century Gothic,CenturyGothic,AppleGothic,sans-serif"}},"angularTheme":{"primary":"indigo","accents":"blue","warn":"red","background":"grey"}},"site":{"name":"Node-RED Dashboard","hideToolbar":"true","allowSwipe":"false","lockMenu":"false","allowTempTheme":"true","dateFormat":"DD/MM/YYYY","sizes":{"sx":48,"sy":48,"gx":6,"gy":6,"cx":6,"cy":6,"px":0,"py":0}}},{"id":"feac0a27.436768","type":"ui_group","z":"","name":"Default","tab":"","order":1,"disp":true,"width":"6","collapse":false},{"id":"b659f685.ff9238","type":"ui_group","z":"","name":"logo","tab":"8e081889.c375d8","order":2,"disp":false,"width":"6","collapse":false},{"id":"3bc4e4e7.26b33c","type":"ui_tab","z":"","name":"Main","icon":"dashboard","order":1,"disabled":false,"hidden":false},{"id":"e73e6ad5.5f3e78","type":"ui_tab","z":"","name":"asd","icon":"dashboard","order":2,"disabled":false,"hidden":false},{"id":"8b8572af.73a04","type":"ui_group","z":"","name":"Default","tab":"e73e6ad5.5f3e78","order":1,"disp":false,"width":"6","collapse":false},{"id":"8a04adcd.f502e","type":"ui_media","z":"86f3c0fa.c76ac","group":"8b8572af.73a04","name":"logo","width":0,"height":0,"order":1,"category":"","file":"logo.jpg","layout":"center","showcontrols":false,"loop":false,"onstart":false,"scope":"local","tooltip":"","x":310,"y":80,"wires":[[]]},{"id":"a8123b53.7fb768","type":"inject","z":"86f3c0fa.c76ac","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"logo/logo.jpg","payloadType":"str","x":150,"y":80,"wires":[["8a04adcd.f502e"]]},{"id":"26e4480a.bebb18","type":"rpi-gpio out","z":"86f3c0fa.c76ac","name":"","pin":"11","set":true,"level":"0","freq":"50","out":"out","x":980,"y":180,"wires":[]},{"id":"a46b5c55.96659","type":"ui_switch","z":"86f3c0fa.c76ac","name":"","label":"Başlat/Durdur","tooltip":"","group":"b659f685.ff9238","order":2,"width":3,"height":1,"passthru":true,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"mi-power_settings_new ","oncolor":"black","offvalue":"false","offvalueType":"bool","officon":"mi-power_settings_new ","offcolor":"yellow","x":780,"y":180,"wires":[["26e4480a.bebb18"]]},{"id":"76db95e9.32a61c","type":"inject","z":"86f3c0fa.c76ac","name":"","props":[{"p":"payload","v":"+1","vt":"str"},{"p":"topic","v":"","vt":"string"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"+1","payloadType":"str","x":130,"y":140,"wires":[["ad7744ff.e250b8"]]},{"id":"ad7744ff.e250b8","type":"delay","z":"86f3c0fa.c76ac","name":"","pauseType":"delay","timeout":"3","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":320,"y":140,"wires":[["cb654a21.c88848"]]},{"id":"cb654a21.c88848","type":"ui_ui_control","z":"86f3c0fa.c76ac","name":"","events":"all","x":520,"y":140,"wires":[[]]},{"id":"ebb07f1b.58d57","type":"switch","z":"86f3c0fa.c76ac","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"40","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":210,"y":540,"wires":[["2b994417.6d29ac"]]},{"id":"2b994417.6d29ac","type":"ui_toast","z":"86f3c0fa.c76ac","position":"top right","displayTime":"3","highlight":"","sendall":true,"outputs":0,"ok":"OK","cancel":"","raw":false,"topic":"KAZAN - YÜKSEK SICAKLIK! Derece:","name":"","x":390,"y":540,"wires":[]},{"id":"7fd6a9df.410be8","type":"switch","z":"86f3c0fa.c76ac","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"40","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":210,"y":660,"wires":[["dd04a634.1e6e48"]]},{"id":"dd04a634.1e6e48","type":"ui_toast","z":"86f3c0fa.c76ac","position":"top right","displayTime":"3","highlight":"","sendall":true,"outputs":0,"ok":"OK","cancel":"","raw":false,"topic":"KASK-2 - YÜKSEK SICAKLIK! Derece:","name":"","x":390,"y":660,"wires":[]},{"id":"eb242e94.01bc1","type":"switch","z":"86f3c0fa.c76ac","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"40","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":210,"y":720,"wires":[["e4c4bda5.e3979"]]},{"id":"e4c4bda5.e3979","type":"ui_toast","z":"86f3c0fa.c76ac","position":"top right","displayTime":"3","highlight":"","sendall":true,"outputs":0,"ok":"OK","cancel":"","raw":false,"topic":"KASK-3 - YÜKSEK SICAKLIK! Derece:","name":"","x":390,"y":720,"wires":[]},{"id":"461d6294.b5cf6c","type":"switch","z":"86f3c0fa.c76ac","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"40","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":210,"y":600,"wires":[["e1dbe886.22f1a8"]]},{"id":"e1dbe886.22f1a8","type":"ui_toast","z":"86f3c0fa.c76ac","position":"top right","displayTime":"3","highlight":"","sendall":true,"outputs":0,"ok":"OK","cancel":"","raw":false,"topic":"KASK-1 - YÜKSEK SICAKLIK! Derece:","name":"","x":390,"y":600,"wires":[]},{"id":"449a07c7.752208","type":"ui_media","z":"86f3c0fa.c76ac","group":"b659f685.ff9238","name":"logo","width":0,"height":0,"order":1,"category":"","file":"logo.jpg","layout":"center","showcontrols":false,"loop":false,"onstart":false,"scope":"local","tooltip":"","x":650,"y":80,"wires":[[]]},{"id":"6bbc799e.8fcc58","type":"inject","z":"86f3c0fa.c76ac","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"logo/logo.jpg","payloadType":"str","x":490,"y":80,"wires":[["449a07c7.752208"]]},{"id":"3efc4824.754798","type":"rpi-gpio out","z":"86f3c0fa.c76ac","name":"","pin":"3","set":false,"level":"0","freq":"msg.payload","out":"pwm","x":1100,"y":480,"wires":[]},{"id":"aee673f7.9deb5","type":"range","z":"86f3c0fa.c76ac","minin":"0","maxin":"1","minout":"100","maxout":"0","action":"scale","round":false,"property":"payload","name":"","x":940,"y":480,"wires":[["3efc4824.754798"]]},{"id":"92820805.9e75d8","type":"PID","z":"86f3c0fa.c76ac","name":"","setpoint":"35","pb":1,"ti":"1800","td":"3","integral_default":0.5,"smooth_factor":3,"max_interval":600,"enable":1,"disabled_op":0,"x":780,"y":480,"wires":[["aee673f7.9deb5"]]},{"id":"c918d062.da081","type":"ui_gauge","z":"86f3c0fa.c76ac","name":"","group":"e72205df.cc91d8","order":4,"width":6,"height":6,"gtype":"gage","title":"Kask-3","label":"derece","format":"{{value | number:1}}","min":"-35","max":"35","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":940,"y":380,"wires":[]},{"id":"4cbefa4b.d50b74","type":"ui_gauge","z":"86f3c0fa.c76ac","name":"","group":"e72205df.cc91d8","order":3,"width":6,"height":6,"gtype":"gage","title":"Kask-2","label":"derece","format":"{{value | number:1}}","min":"-35","max":"35","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":940,"y":340,"wires":[]},{"id":"c293c347.d303f","type":"ui_gauge","z":"86f3c0fa.c76ac","name":"","group":"e72205df.cc91d8","order":2,"width":6,"height":6,"gtype":"gage","title":"Kask-1","label":"derece","format":"{{value | number:1}}","min":"-35","max":"35","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":940,"y":300,"wires":[]},{"id":"58b37b3b.1dcf54","type":"ui_gauge","z":"86f3c0fa.c76ac","name":"","group":"e72205df.cc91d8","order":1,"width":6,"height":6,"gtype":"gage","title":"Kazan","label":"derece","format":"{{value | number:1}}","min":"-35","max":"35","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":930,"y":260,"wires":[]},{"id":"68d3cc85.d843d4","type":"sensor-ds18b20","z":"86f3c0fa.c76ac","name":"","topic":"","sensorid":"28-012019d65680","timer":"1","repeat":true,"x":350,"y":260,"wires":[["ebb07f1b.58d57","58b37b3b.1dcf54"]]},{"id":"77f2d61f.336898","type":"sensor-ds18b20","z":"86f3c0fa.c76ac","name":"","topic":"","sensorid":"28-0300a2790a56","timer":"1","repeat":true,"x":350,"y":300,"wires":[["461d6294.b5cf6c","c293c347.d303f"]]},{"id":"dce60654.7540f8","type":"sensor-ds18b20","z":"86f3c0fa.c76ac","name":"","topic":"","sensorid":"28-0300a279f0d6","timer":"1","repeat":true,"x":350,"y":340,"wires":[["7fd6a9df.410be8","4cbefa4b.d50b74"]]},{"id":"9408bf94.12566","type":"sensor-ds18b20","z":"86f3c0fa.c76ac","name":"","topic":"","sensorid":"28-0300a279dceb","timer":"1","repeat":true,"x":350,"y":380,"wires":[["92820805.9e75d8","eb242e94.01bc1","c918d062.da081"]]},{"id":"1d6c599f.cf56d6","type":"ui_button","z":"86f3c0fa.c76ac","name":"","group":"8b8572af.73a04","order":2,"width":0,"height":0,"passthru":false,"label":"Geç","tooltip":"","color":"","bgcolor":"","icon":"","payload":"+1","payloadType":"num","topic":"","x":310,"y":180,"wires":[["cb654a21.c88848"]]},{"id":"cf89716b.c14b9","type":"ui_dropdown","z":"86f3c0fa.c76ac","name":"","label":"Süreyi Seçiniz:","tooltip":"","place":"Select option","group":"b659f685.ff9238","order":5,"width":0,"height":0,"passthru":false,"multiple":false,"options":[{"label":"10 dakika","value":15,"type":"num"},{"label":"30 dakika","value":"30","type":"str"},{"label":"45 dakika","value":"45","type":"str"},{"label":"60 dakika","value":"60","type":"str"}],"payload":"","topic":"","x":740,"y":580,"wires":[["cbe110fb.7591a"]]},{"id":"cbe110fb.7591a","type":"ui_switch","z":"86f3c0fa.c76ac","name":"","label":"Alarm/Sıfırla","tooltip":"","group":"b659f685.ff9238","order":3,"width":3,"height":1,"passthru":true,"decouple":"false","topic":"msg.payload","style":"","onvalue":"true","onvalueType":"bool","onicon":"mi-alarm","oncolor":"yellow","offvalue":"false","offvalueType":"bool","officon":"mi-cache","offcolor":"black","x":950,"y":580,"wires":[["b53e0700.8e4c78"]]},{"id":"b53e0700.8e4c78","type":"ui_text","z":"86f3c0fa.c76ac","group":"b659f685.ff9238","order":4,"width":0,"height":0,"name":"","label":"Sayaç:","format":"{{msg.payload}}","layout":"row-center","x":1130,"y":580,"wires":[]}]
