OK I did another testrun without charts for about 1h.
Still the same problem. After some time (starting at around 10 min.) I get the "connection lost" popup, screen turns black and immediately comes back. All gauges regain their values starting from 0.
i tried to catch it on a screencast.
Whats strange is that the data drops are at different times for every sensor and seem to appear totally random. Also not consistent with the "connection lost" problem. It looks like the data is stored into my txt files even the connection is lost. So there might be two different problems here.
Looking at the log file, nothing unusual happening there.
What changed when i removed the chart was the crash of the chromium browser. Browser remaind stable during the whole testrun.
29 Nov 13:52:54 - [info] Node-RED version: v1.2.2
29 Nov 13:52:54 - [info] Node.js version: v12.19.0
29 Nov 13:52:54 - [info] Linux 5.4.72-v7+ arm LE
29 Nov 13:52:55 - [info] Loading palette nodes
29 Nov 13:53:01 - [info] Dashboard version 2.23.4 started at /ui
29 Nov 13:53:02 - [info] Settings file : /home/pi/.node-red/settings.js
29 Nov 13:53:02 - [info] Context store : 'default' [module=memory]
29 Nov 13:53:02 - [info] User directory : /home/pi/.node-red
29 Nov 13:53:02 - [warn] Projects disabled : editorTheme.projects.enabled=false
29 Nov 13:53:02 - [info] Flows file : /home/pi/.node-red/flows_raspberrypi.j son
29 Nov 13:53:02 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
29 Nov 13:53:02 - [info] Starting flows
29 Nov 13:53:02 - [info] Started flows
29 Nov 13:53:02 - [info] serial port /dev/ttyUSB0 opened at 115200 baud 8N1
