I ve this payload:
"Relay Off 4C:11:AE:0D:4B:48"
I want to use a function node to check if the string contains "On" or "Off" and this is my function which doesnt work. pls help:
if (msg.payload.contains == "Off")
msg.payload = "Light Off";
if (msg.payload.contains == "On")
msg.payload = "Light On";
return null;
I tried "msg.payload.contains("Off")" with double and single quotes ...
Can someone help ? thx!
In JavaScript there is no contains function available on the String object. Instead you can use String.includes:
if (msg.payload.includes("Off"))
MDN provides a useful reference of the available functions on Strings - https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/String
Aha okay ! Thx ... in this case I am wondering why the "contains" keyword is accepted by the editor.
Because the editor isn't doing full type-aware syntax validation. It doesn't know what type of thing msg.payload is, so it doesn't know what properties exist.
As a line of code:
if (msg.payload.contains("Off")) {
is perfectly valid JavaScript syntax. msg.payload might be an object that has a contains function. It is only when it runs the code will it know if that function exists or not.
