Search Array and output Boolean
Hello All,
I have an array that I would like to be able to search for certain strings.
Here is an example of the array output in the Debug window.
["LA","NJ","NJ-NJ","NJ-NJ","NJ-NJ","NJ-NJ","MS1","WA"]
Then I would like to search for "NJ"
If NJ is found, then the output should say True or 1, else it should say 0 or false.
You can use the javascript array.includes() in a function node to do this. This method return true if a value is in the array. Have a look here:
Johannes
Thank you for the reply.
Sorry I'm new to this and still learning.
So here is my setup.
I have the API dumping out a json file and have it parsed into msg.payload.
Next I have the Switch configured to look at only the states which gets me the array output of
and that is dumping out to msg.cities.
In the function node, I have:
msg.cities.includes("WA");
I am showing a WA in the msg.cities debug. But the function node is still outputting false, or in a normal debug block it shows Undefined.
very close :+1:, try:
const bool = msg.cities.includes("WA");
msg.payload = bool;
the include method doesn’t change the array but is a function that returns a boolean value. so you need to assign that returned value to a var.
Johannes
Thanks Johannes! That worked!
