On a later re-run I did get an error - but related to the flow variable to the file
context store:
Welcome to Node-RED
6 Dec 22:18:29 - [info] Node-RED version: v3.0.2
6 Dec 22:18:29 - [info] Node.js version: v16.18.1
6 Dec 22:18:29 - [info] Linux 5.15.74.2-microsoft-standard-WSL2 x64 LE
6 Dec 22:18:29 - [info] Loading palette nodes
6 Dec 22:18:29 - [info] Settings file : /home/julian/nrlive/data/settings.js
6 Dec 22:18:29 - [info] HTTP Static : /home/julian/nrlive/public > /
6 Dec 22:18:29 - [info] Context store : 'default' [module=memory]
6 Dec 22:18:29 - [info] Context store : 'file' [module=localfilesystem]
6 Dec 22:18:29 - [info] Context store : 'altFile' [module=localfilesystem]
6 Dec 22:18:29 - [info] User directory : /home/julian/nrlive/data
6 Dec 22:18:29 - [warn] Projects disabled : editorTheme.projects.enabled=false
6 Dec 22:18:29 - [info] Flows file : /home/julian/nrlive/data/flows.json
6 Dec 22:18:29 - [info] Server now running at http://127.0.0.1:1881/red/
6 Dec 22:18:29 - [info] Starting flows
6 Dec 22:18:29 - [info] Started flows
6 Dec 22:18:49 - [info] Stopping flows
6 Dec 22:18:49 - [info] Stopped flows
6 Dec 22:18:49 - [info] Updated flows
6 Dec 22:18:49 - [info] Starting flows
6 Dec 22:18:49 - [info] Started flows
6 Dec 22:19:22 - [error] Error writing context: Error: ENOENT: no such file or directory, rename '/home/julian/nrlive/data/context/8f633713fe222323/flow.json.1670365162017.tmp' -> '/home/julian/nrlive/data/context/8f633713fe222323/flow.json'
And here is what I found in the file:
"test2": "This is the file store - a flow var"
} "test3": "This is the altFile store - a flow var - 2"
Oops!
I had changed the node-red settings to this (and restarted):
contextStorage: {
default: {
module:'memory',
file: {
module: 'localfilesystem',
// config: {
// flushInterval: '10', // default is 30s
altFile: {
dir: '/home/julian/nrAltFileStore',
base: 'context',
cache: false,
flushInterval: 1,
