Hi folks,
I'm trying to develop a dashboard node that shows a popup context menu, that can be displayed at specified X/Y positions in the Node-RED dashboard (on top of the other content).
Based on this tutorial I generate a div tag with following style properties:
position: relative
left: my X position
top: my Y position
The one (and most important) thing that I cannot get solved, is the position of the context menu
The damn thing always appears BELOW my other content (like the new floorplan UI node), instead of ON TOP of it:
I 'assume' this is because it is INSIDE an md-card tag (or does that have nothing to do with my issue???):
Have been searching around a bit, and it seems that Angular materials has its own menu that can be showed at a specific position. But I 'assume' I cannot use that, since the md-card is generated by the dashboard around my custom UI contribution?? No idea to be honest ...
Does anybody have an idea how I can solve this??
Thanks !!!
Bart
Have you tried setting a high value z-index property so its stack order will be on top of other elements?
@hugobox,
Thanks for responding!
Last night I found a solution that seemed to work. Simplified:
function HTML(config) {
var html = String.raw`
<style>
.menu {
position: fixed;
z-index: 99000 !important;
</style>
<div class="menu";>
<ul class="menu-options">
</ul>
</div>
return html;
With position "absolute" it still remained below my floorplan. Don't know why ...
But the look-and-feel of this context menu wasn't really great:
So I searched for a nicer alternative on the web (with nicer styling), found one, and integrated it into my custom ui node code. Simplified:
<style>
.menu {
position: fixed;
-webkit-transform: translate(0, 15px) scale(.95);
transition: transform 0.1s ease-out, opacity 0.1s ease-out;
</style>
<div>
<ul class="menu">
</ul>
</div>
return html;
Now the context menu looks much better, but it is again below my floorplan (both for position "fixed" or "absolute"):
In the codepen example you can see that the position is "absolute".
My god, I get frustrated from all that CSS stuff ...
In case anybody would like to look at the (experimental) code containing the css styling: node-red-contrib-ui-contextmenu(branch "Based-on-codepen-example") .
Hi Bart, to close this topic and in case anyone else gets stuck on this, I updated the repo to set the left and top properties of the ul instead of its container div
See here ....
Thanks a lot partner!
Steve figured out that I had to set left/top on the 'ul' element instead of on the 'div' element ...
I am fresher for node-red, please explain the what is context menu and how is it work in step by step...
Hi, it is a dashboard node. read the extensive and helpful readme & give it a go if you find it is what you need. If you get stuck, start a new thread of the forum.
