Context not working for name
It caught me for a while then I remembered the device name is set in the settings.js file.
So, when I look at my `context on a new machine I see this:
Screenshot from 2020-08-05 11-08-31
I'm confused.
This is what the settings.js file looks like:
Why isn't myDeviceName seen in the context?
NR 1.1.2
Stopping and starting Node-Red I see this:
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
5 Aug 11:18:14 - [info]
Welcome to Node-RED
5 Aug 11:18:14 - [info] Node-RED version: v1.1.2
5 Aug 11:18:14 - [info] Node.js  version: v10.22.0
5 Aug 11:18:14 - [info] Linux 4.19.118+ arm LE
5 Aug 11:18:24 - [info] Loading palette nodes
5 Aug 11:18:56 - [info] Dashboard version 2.23.0 started at /ui
5 Aug 11:18:59 - [info] Settings file  : /home/pi/.node-red/settings.js
5 Aug 11:18:59 - [info] HTTP Static    : /home/pi/.node-red/public
5 Aug 11:18:59 - [info] Context store  : 'default' [module=memory]
5 Aug 11:18:59 - [info] User directory : /home/pi/.node-red
5 Aug 11:18:59 - [warn] Projects disabled : editorTheme.projects.enabled=false
5 Aug 11:18:59 - [info] Flows file     : /home/pi/.node-red/flows_LCDPi.json
5 Aug 11:19:01 - [info] Server now running at http://127.0.0.1:1880/
5 Aug 11:19:01 - [warn]
your credentials.
5 Aug 11:19:02 - [info] Starting flows
5 Aug 11:19:06 - [info] Started flows
5 Aug 11:19:06 - [info] [mqtt-broker:MQTT host] Connected to broker: mqtt://192.168.0.99:1883
5 Aug 11:19:08 - [warn] [function:Variable repeat time] Value set
5 Aug 11:19:10 - [error] [gate:7fcdf90.f234588] Invalid command
The last line is work in progress. But nothing to indicate it is not happy with the name.
EDIT: Sorry, forget, I think my example is not relevant to yours
All visible here for me. Doesn't help but just to verify they should
Read the section underneath the part you marked with the red triangle.
// global.keys() returns a list of all properties set in global context.
// This allows them to be displayed in the Context Sidebar within the editor.
// In some circumstances it is not desirable to expose them to the editor. The
// following property can be used to hide any property set in functionGlobalContext
// from being list by global.keys().
// By default, the property is set to false to avoid accidental exposure of
// their values. Setting this to true will cause the keys to be listed.
exportGlobalContextKeys: false,
Change exportGlobalContextKeys to true.
See also the discussion here
I'm guessing this was introduced in a recent update.
Yeah, RTFM.
Thanks.
