Contrib puppeteer new
Hello!
Has anyone ever tried Node-red-contrib-puppeteer-new?
Is there an example flow?
Do I have to install something additional?
Not tried that one but I've never had to install additional stuff when I've used a puppeteernode
I found them to be quite unreliable though
Hello!
Thanks for the answer.
Is there another solution otherwise?
I would like to select something on a homepage and enter the email and then click OK.
If you do the action manually in a web browser with devtools open on the network tab, you will see exactly what it POSTs and what headers etc are set. Simply recreate that with the built in http request node.
Hello!
Do you have an example?
As I've said - not found a reliable one :frowning:
Works fantastic, needs something like chromium running in the background.
