And this is part 2:
[{"id":"44b73686.20b328","type":"function","z":"4e139d26.c717a4","name":"create request","func":"APIkey = flow.get('APIkey');\nvar auth = APIkey+':';\nmsg.ResourceID = flow.get('ressourceID');\nmsg.headers = {\n \"Authorization\": 'Basic ' + new Buffer(auth).toString('base64')\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"// Code added here will be run once\n// whenever the node is started.\n\nflow.set('APIkey',\"kr4xMBTh9cMrToNnYNs0yZkTMHsQ-h4J\");\nflow.set('ressourceID',\"1bcd-81cf-8823-ac4f\");","finalize":"","libs":[],"x":340,"y":980,"wires":[["560ddd10.f28bfc","624210f6782e5609"]]},{"id":"be9ab89.9edd3c8","type":"inject","z":"4e139d26.c717a4","d":true,"name":"now","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"date","x":90,"y":1180,"wires":[["c3bc5a73.b7e838"]]},{"id":"560ddd10.f28bfc","type":"http request","z":"4e139d26.c717a4","name":"fetch solcast","method":"GET","ret":"obj","paytoqs":"ignore","url":"https://api.solcast.com.au/rooftop_sites/{{{ResourceID}}}/forecasts?format=json","tls":"","persist":false,"proxy":"","authType":"","x":540,"y":980,"wires":[["decd550.b8ce6a8","c1c7663590e07e5a"]]},{"id":"decd550.b8ce6a8","type":"function","z":"4e139d26.c717a4","name":"extract 49h forecast values","func":"// fill array solCast with 49 hours worth of energy forecasts in kWh\n// Input: from solcast.com array with 30min forecast elements in kW\n// Output: array[0..48] with 60min forecast elements in kW (corresponds to produced kWh during that hour)\n\nvar solCastMsg = {};\nvar solCast=[];\nvar statusColour;\nvar statusCode = msg.statusCode;\n\nif (msg.statusCode == 200) {\n statusColour = \"green\";\n for (i=0; i<=48; i++) {\n solCast[i] = (msg.payload.forecasts[2*i].pv_estimate + msg.payload.forecasts[2*i+1].pv_estimate)/2;\n }\n solCastMsg.solCast = solCast;\n node.send(solCastMsg);\n} else {\n statusColour = \"red\";\n}\nnode.status({fill:statusColour,shape:\"dot\",text:statusCode});\n\nreturn;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":760,"y":980,"wires":[["47e84efa.a7094","b8e15b9c1693ad04","1cd2863e.55dfa2"]]},{"id":"518f9ab2.e6568c","type":"link out","z":"4e139d26.c717a4","name":"","links":["907c80c1.54e128"],"x":1195,"y":960,"wires":[]},{"id":"bc8b503c.d34fe8","type":"function","z":"4e139d26.c717a4","name":"set tariff48","func":"// fill an array with the tariff information for the next 48h\n\n//msg.payload contains a string \"weekday hour\"\nconst temp = msg.payload.split(' ');\n//node.warn(temp);\nconst weekday = parseInt(temp[0])-1;\n//node.warn(weekday);\nconst hour = parseInt(temp[1]);\n//node.warn(hour);\nvar baseTime = weekday * 24 + hour;\n//node.warn(baseTime);\n\nvar i;\nvar tariff48=[];\nfor (i=0;i<48;i++) {\n if (baseTime + i > 167) baseTime = 0;\n tariff48[i] = msg.tariff[baseTime + i];\n}\nmsg.tariff48 = tariff48;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":850,"y":1100,"wires":[["ab86107.aa9d27"]]},{"id":"cab3dc94.91a388","type":"moment","z":"4e139d26.c717a4","name":"weekday hour","topic":"","input":"time","inputType":"msg","inTz":"Europe/Zurich","adjAmount":0,"adjType":"days","adjDir":"add","format":"E H","locale":"en-GB","output":"payload","outputType":"msg","outTz":"Europe/Zurich","x":460,"y":1100,"wires":[["d2da9e67.4702d8"]]},{"id":"ab86107.aa9d27","type":"change","z":"4e139d26.c717a4","name":"store","rules":[{"t":"set","p":"#:(storeInFile)::dataStatus.grid.tariff48","pt":"global","to":"tariff48","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1030,"y":1100,"wires":[["bb1aaa50.966c7","c697d7ab.d7b858"]]},{"id":"d2da9e67.4702d8","type":"change","z":"4e139d26.c717a4","name":"get tariff","rules":[{"t":"set","p":"tariff","pt":"msg","to":"#:(storeInFile)::dataStatus.grid.tariffZone","tot":"global"},{"t":"set","p":"solCast","pt":"msg","to":"#:(storeInFile)::dataStatus.solar.solCast","tot":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":660,"y":1100,"wires":[["bc8b503c.d34fe8"]]},{"id":"bb1aaa50.966c7","type":"debug","z":"4e139d26.c717a4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1190,"y":1100,"wires":[]},{"id":"47e84efa.a7094","type":"change","z":"4e139d26.c717a4","name":"-> data/solar/solCast","rules":[{"t":"set","p":"payload","pt":"msg","to":"solCast","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"data/solar/solCast","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1040,"y":960,"wires":[["518f9ab2.e6568c"]]},{"id":"4b6c9be7.3be0cc","type":"comment","z":"4e139d26.c717a4","name":"msg.* documentation","info":"at this stage the msg contains\nmsg.solCast with 48h solar energy forecast\nmsg.tariff48 with 48h of tariff zone information\nmsg.chargeState with Tesla battery data\nmsg.chargeLevel : the battery should be charged to this level\nmsg.chargeNeeded : difference between chargeLevel and actual batteryLevel in kWh\nmsg.chargeTime : time it takes to charge with 2 kW to the chargeLevel requested by the chargeGoal selected. If the value is 48 hours then there is a good chance, that the goal can't be reached.\nmsg.chargeAvailable : usually corresponds to chargeNeeded. It might be lower than that if two days are not enough to reach the desired level with the selected goal\nmsg.chargeNow : 1 to enable charging, 0 to stop it.","x":300,"y":1940,"wires":[]},{"id":"c697d7ab.d7b858","type":"tesla-api","z":"4e139d26.c717a4","teslaConfig":"cca88314.8bcf68","command":"chargeState","name":"getChargeState","x":280,"y":1260,"wires":[["9dd20cd8.39a0b","d9b6574b.b51ea8"]]},{"id":"8e92651a.d83678","type":"debug","z":"4e139d26.c717a4","name":"not chargeable","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":500,"y":1340,"wires":[]},{"id":"6724007f.4b733","type":"switch","z":"4e139d26.c717a4","name":"plugged in?","property":"payload.charging_state","propertyType":"msg","rules":[{"t":"eq","v":"Disconnected","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":270,"y":1400,"wires":[["8e92651a.d83678","dc59f574.d9aed"],["542838fd.c2a42"]]},{"id":"cfa0473.e578fb8","type":"change","z":"4e139d26.c717a4","name":"-> batteryLevel","rules":[{"t":"set","p":"payload","pt":"msg","to":"chargeState.battery_level","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"data/tesla/batteryLevel","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":740,"y":1220,"wires":[["90b5900f.e9dd68"]]},{"id":"90b5900f.e9dd68","type":"link out","z":"4e139d26.c717a4","name":"","links":["907c80c1.54e128"],"x":895,"y":1260,"wires":[]},{"id":"4fb8a85e.6c33d","type":"change","z":"4e139d26.c717a4","name":"-> chargeState","rules":[{"t":"set","p":"payload","pt":"msg","to":"chargeState.charger_power","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"data/tesla/chargeState","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":740,"y":1260,"wires":[["90b5900f.e9dd68"]]},{"id":"570ce501.d8c1c4","type":"change","z":"4e139d26.c717a4","name":"-> chargeLimit","rules":[{"t":"set","p":"payload","pt":"msg","to":"chargeState.charge_limit_soc","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"data/tesla/chargeLimit","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":740,"y":1300,"wires":[["90b5900f.e9dd68"]]},{"id":"a53a73bc.53a5f","type":"switch","z":"4e139d26.c717a4","name":"charge needed?","property":"chargeState.battery_level","propertyType":"msg","rules":[{"t":"gte","v":"chargeLevel","vt":"msg"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":750,"y":1420,"wires":[["fe45fca9.dc1a58","c4553f26.900888"],["3c6f9bbf.4a6d4c"]]},{"id":"9dd20cd8.39a0b","type":"change","z":"4e139d26.c717a4","name":"msg.chargeState","rules":[{"t":"move","p":"payload","pt":"msg","to":"chargeState","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":510,"y":1260,"wires":[["cfa0473.e578fb8","4fb8a85e.6c33d","570ce501.d8c1c4","6724007f.4b733"]]},{"id":"fe45fca9.dc1a58","type":"debug","z":"4e139d26.c717a4","name":"no charge needed","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1010,"y":1400,"wires":[]},{"id":"3c6f9bbf.4a6d4c","type":"function","z":"4e139d26.c717a4","name":"msg.chargeNeeded","func":"// msg.chargeLevel and msg.chargeState.battery_level ar in %\n// 3% correspond roughly to 2 kWh\n// msg.chargeNeeded is in kWh\n\nmsg.chargeNeeded = (msg.chargeLevel - msg.chargeState.battery_level) / 3 * 2;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":300,"y":1580,"wires":[["b68345c3.7198b8","3c5f605d.3450b8"]]},{"id":"542838fd.c2a42","type":"change","z":"4e139d26.c717a4","name":"chargeLevel","rules":[{"t":"set","p":"chargeLevel","pt":"msg","to":"#:(storeInFile)::dataStatus.tesla.chargeLevel","tot":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":490,"y":1420,"wires":[["a53a73bc.53a5f"]]},{"id":"b68345c3.7198b8","type":"switch","z":"4e139d26.c717a4","name":"chargeGoal?","property":"#:(storeInFile)::dataStatus.tesla.chargeGoal","propertyType":"global","rules":[{"t":"eq","v":"solar","vt":"str"},{"t":"eq","v":"cheap","vt":"str"},{"t":"eq","v":"fast","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":4,"x":500,"y":1580,"wires":[["2934f72a.be205"],["6945cd83.0db554"],["54fc0948.ffc2f8"],[]]},{"id":"2934f72a.be205","type":"function","z":"4e139d26.c717a4","name":"msg.chargeTime (solar)","func":"// calculate needed charging time based on solar forecast\n// if more than 2.5 kWh are produced in the next hour,\n// then 2kWh are used to charge the car.\n\nvar chargeAvailable = 0;\nvar chargeTime = 0;\n\nwhile (chargeAvailable < msg.chargeNeeded){\n if (msg.solCast[chargeTime] > 2.5) {\n chargeAvailable += 2;\n }\n chargeTime++;\n if (chargeTime >= 48) break;\n}\nif (msg.solCast[0]>2.5) {\n msg.chargeNow = 1;\n} else {\n msg.chargeNow = 0;\n}\n\nmsg.chargeAvailable = chargeAvailable;\nmsg.chargeTime = chargeTime;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":770,"y":1540,"wires":[["b79ba3c5.a4c3b"]]},{"id":"6945cd83.0db554","type":"function","z":"4e139d26.c717a4","name":"msg.chargeTime (cheap)","func":"// calculate needed charging time based on solar forecast\n// if more than 2.5 kWh are produced in the next hour,\n// then 2kWh are used to charge the car.\n// If this is not the case, but the grid offers the power to a low tariff, then this is used instead\n\nvar chargeAvailable = 0;\nvar chargeTime = 0;\n\nwhile (chargeAvailable < msg.chargeNeeded){\n if ((msg.solCast[chargeTime] > 2.5) || (msg.tariff48[chargeTime] == 2)) {\n chargeAvailable += 2;\n }\n chargeTime++;\n if (chargeTime >= 48) break;\n}\n\nif ((msg.solCast[0]>2.5) || (msg.tariff48[0] == 2)) {\n msg.chargeNow = 1;\n} else {\n msg.chargeNow = 0;\n}\n\nmsg.chargeAvailable = chargeAvailable;\nmsg.chargeTime = chargeTime;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":770,"y":1580,"wires":[["b79ba3c5.a4c3b"]]},{"id":"54fc0948.ffc2f8","type":"function","z":"4e139d26.c717a4","name":"msg.chargeTime (fast)","func":"// charging starts immediately with 2 kW\n\nmsg.chargeAvailable = msg.chargeNeeded;\nmsg.chargeTime = parseInt(msg.chargeNeeded / 2 + 1);\nmsg.chargeNow = 1;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":770,"y":1620,"wires":[["b79ba3c5.a4c3b"]]},{"id":"9769d5f5.d2ee1","type":"comment","z":"4e139d26.c717a4","name":"check every hour if charge is needed and act according settings","info":"","x":250,"y":1060,"wires":[]},{"id":"b79ba3c5.a4c3b","type":"change","z":"4e139d26.c717a4","name":"bg color","rules":[{"t":"set","p":"background","pt":"msg","to":"#3FADB5","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":980,"y":1580,"wires":[["55aac22e.2a9204","d03245a4.e7a21","6e1eb9c1.7605d","8256768b.1d5108"]]},{"id":"55aac22e.2a9204","type":"ui_button","z":"4e139d26.c717a4","name":"chargeTime","group":"a778a4f8.f945f8","order":3,"width":0,"height":0,"passthru":false,"label":"Charge Time: {{chargeTime}}h","tooltip":"","color":"","bgcolor":" {{background}}","icon":"","payload":"100","payloadType":"num","topic":"data/tesla/chargeTime","topicType":"str","x":1170,"y":1540,"wires":[[]]},{"id":"d03245a4.e7a21","type":"change","z":"4e139d26.c717a4","name":"-> data/tesla/chargeTime","rules":[{"t":"set","p":"payload","pt":"msg","to":"chargeTime","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"data/tesla/chargeTime","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1220,"y":1580,"wires":[["eb4163a0.aebe6"]]},{"id":"eb4163a0.aebe6","type":"link out","z":"4e139d26.c717a4","name":"","links":["70cb46f0.581f68","f8d7f4303cd3f838"],"x":1385,"y":1580,"wires":[]},{"id":"996f3d90.908f58","type":"tesla-api","z":"4e139d26.c717a4","teslaConfig":"cca88314.8bcf68","command":"setChargeLimit","name":"setChargeLimit","x":280,"y":1800,"wires":[["8ddf6bf5.1e6708"]]},{"id":"6e1eb9c1.7605d","type":"change","z":"4e139d26.c717a4","name":"set commandArgs","rules":[{"t":"set","p":"commandArgs.amt","pt":"msg","to":"chargeLevel","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":290,"y":1760,"wires":[["996f3d90.908f58"]]},{"id":"8ddf6bf5.1e6708","type":"switch","z":"4e139d26.c717a4","name":"charge now?","property":"chargeNow","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":280,"y":1840,"wires":[["b3780dd4.f6aa88"],["3bec4b1f.b844f4"]]},{"id":"b3780dd4.f6aa88","type":"tesla-api","z":"4e139d26.c717a4","teslaConfig":"cca88314.8bcf68","command":"startCharge","name":"startCharge","x":490,"y":1820,"wires":[["4146c684.33a318"]]},{"id":"3bec4b1f.b844f4","type":"tesla-api","z":"4e139d26.c717a4","teslaConfig":"cca88314.8bcf68","command":"stopCharge","name":"stopCharge","x":490,"y":1860,"wires":[["4146c684.33a318"]]},{"id":"68125061.82b16","type":"change","z":"4e139d26.c717a4","name":"-> batteryLevel","rules":[{"t":"set","p":"payload","pt":"msg","to":"chargeState.battery_level","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"data/tesla/batteryLevel","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1120,"y":1800,"wires":[["152b0c83.6c0f3b"]]},{"id":"152b0c83.6c0f3b","type":"link out","z":"4e139d26.c717a4","name":"","links":["907c80c1.54e128"],"x":1275,"y":1840,"wires":[]},{"id":"9348144e.495758","type":"change","z":"4e139d26.c717a4","name":"-> chargeState","rules":[{"t":"set","p":"payload","pt":"msg","to":"chargeState.charger_power","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"data/tesla/chargeState","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1120,"y":1840,"wires":[["152b0c83.6c0f3b"]]},{"id":"570f53e9.acf364","type":"change","z":"4e139d26.c717a4","name":"-> chargeLimit","rules":[{"t":"set","p":"payload","pt":"msg","to":"chargeState.charge_limit_soc","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"data/tesla/chargeLimit","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1120,"y":1880,"wires":[["152b0c83.6c0f3b"]]},{"id":"9b8a2e4a.7937f","type":"change","z":"4e139d26.c717a4","name":"msg.chargeState","rules":[{"t":"move","p":"payload","pt":"msg","to":"chargeState","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":1840,"wires":[["68125061.82b16","9348144e.495758","570f53e9.acf364","cc8c4e1a.05efd"]]},{"id":"4146c684.33a318","type":"tesla-api","z":"4e139d26.c717a4","teslaConfig":"cca88314.8bcf68","command":"chargeState","name":"getChargeState","x":680,"y":1840,"wires":[["9b8a2e4a.7937f"]]},{"id":"3c5f605d.3450b8","type":"debug","z":"4e139d26.c717a4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":470,"y":1520,"wires":[]},{"id":"8256768b.1d5108","type":"debug","z":"4e139d26.c717a4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1150,"y":1620,"wires":[]},{"id":"cc8c4e1a.05efd","type":"debug","z":"4e139d26.c717a4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1090,"y":1920,"wires":[]},{"id":"d9b6574b.b51ea8","type":"debug","z":"4e139d26.c717a4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":470,"y":1220,"wires":[]},{"id":"c3bc5a73.b7e838","type":"switch","z":"4e139d26.c717a4","name":"enabled?","property":"#:(storeInFile)::dataStatus.tesla.chargeControl","propertyType":"global","rules":[{"t":"eq","v":"enabled","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":260,"y":1120,"wires":[["cab3dc94.91a388"],["4ffb8a3e.31065c"]]},{"id":"e7a96fad.96c508","type":"comment","z":"4e139d26.c717a4","name":"fetch solar forecast 1/h and store values","info":"","x":180,"y":940,"wires":[]},{"id":"f11b864.3858c78","type":"comment","z":"4e139d26.c717a4","name":"TODOs !!!","info":"Farbe charge time auf hell setzen\n\nganzer Status auf n.a. o.ä. setzen falls nicht verbunden oder unbekannt","x":660,"y":1940,"wires":[]},{"id":"c4553f26.900888","type":"change","z":"4e139d26.c717a4","name":"set disabled","rules":[{"t":"set","p":"payload","pt":"msg","to":"disabled","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"data/tesla/chargeControl","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":1440,"wires":[["d1977d99.31a4a"]]},{"id":"d1977d99.31a4a","type":"link out","z":"4e139d26.c717a4","name":"","links":["907c80c1.54e128"],"x":1115,"y":1440,"wires":[]},{"id":"dc59f574.d9aed","type":"change","z":"4e139d26.c717a4","name":"set disabled","rules":[{"t":"set","p":"payload","pt":"msg","to":"disabled","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"data/tesla/chargeControl","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":490,"y":1380,"wires":[["5fe4daf8.84d124"]]},{"id":"5fe4daf8.84d124","type":"link out","z":"4e139d26.c717a4","name":"","links":["907c80c1.54e128"],"x":675,"y":1380,"wires":[]},{"id":"4ffb8a3e.31065c","type":"debug","z":"4e139d26.c717a4","name":"disabled","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":440,"y":1140,"wires":[]},{"id":"1cd2863e.55dfa2","type":"function","z":"4e139d26.c717a4","name":"->influxdb","func":"// input: msg.colCast array with 60min forecast elements in kW\n// output: 49 messages for the influxdb\n// msg.payload = {\"solCast24\":'estimation in 24h'}\n\nfor (i=0; i<=48; i++) {\n var nTag = \"solCast\" + i.toString();\n var newMsg = {};\n newMsg.measurement = \"solar\";\n newMsg.payload = [\n {\n value:msg.solCast[i],\n time:Date.now() + i*3600\n },{\n tag1:nTag\n \n }\n ];\n node.send(newMsg);\n}\n\nreturn;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1010,"y":1000,"wires":[["82756beb.91e8d8"]]},{"id":"82756beb.91e8d8","type":"debug","z":"4e139d26.c717a4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1190,"y":1040,"wires":[]},{"id":"b8e15b9c1693ad04","type":"debug","z":"4e139d26.c717a4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":990,"y":920,"wires":[]},{"id":"0e5507e186ba20f7","type":"cronplus","z":"4e139d26.c717a4","d":true,"name":"1/h","outputField":"payload","timeZone":"","persistDynamic":false,"commandResponseMsgOutput":"output1","outputs":1,"options":[{"name":"schedule1","topic":"schedule1","payloadType":"default","payload":"","expressionType":"cron","expression":"1 0 * * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}],"x":90,"y":980,"wires":[["44b73686.20b328"]]},{"id":"85cc4509673705fa","type":"cronplus","z":"4e139d26.c717a4","d":true,"name":"1/h","outputField":"payload","timeZone":"","persistDynamic":false,"commandResponseMsgOutput":"output1","outputs":1,"options":[{"name":"schedule1","topic":"schedule1","payloadType":"default","payload":"","expressionType":"cron","expression":"10 0 * * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}],"x":90,"y":1120,"wires":[["c3bc5a73.b7e838"]]},{"id":"e6220b02a572c179","type":"inject","z":"4e139d26.c717a4","d":true,"name":"now","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"date","x":90,"y":1020,"wires":[["44b73686.20b328"]]},{"id":"c1c7663590e07e5a","type":"debug","z":"4e139d26.c717a4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":710,"y":920,"wires":[]},{"id":"624210f6782e5609","type":"debug","z":"4e139d26.c717a4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":510,"y":920,"wires":[]},{"id":"cca88314.8bcf68","type":"tesla-config","email":"urs.eppenberger@maremonti.ch"},{"id":"a778a4f8.f945f8","type":"ui_group","name":"Charge State","tab":"cc41f24f.2ab028","order":4,"disp":true,"width":"4","collapse":false},{"id":"cc41f24f.2ab028","type":"ui_tab","name":"Tesla","icon":"dashboard","order":3,"disabled":false,"hidden":false}]
