Hi everybody,
I search to control VLC in node red.
I've vidéo needs to be play in loop mode. to make this i use a trigger to send go at the video end.
"id": "60e7fec1d0aab87d",
"type": "exec",
"z": "b3a4f8600535e6f2",
"command": "export DISPLAY=:0 && vlc /home/timoxy/Desktop/boucledef.mp4",
"addpay": "",
"append": "",
"useSpawn": "false",
"timer": "0",
"winHide": false,
"oldrc": false,
"name": "Video boucle",
"x": 3830,
"y": 1300,
"id": "6ed2b9fa8d8ce8cf",
"type": "trigger",
"name": "Boucle vidéo 88 s",
"op1": "1",
"op2": "0",
"op1type": "str",
"op2type": "str",
"duration": "-88",
"extend": false,
"overrideDelay": false,
"units": "s",
"reset": "stop",
"bytopic": "all",
"topic": "topic",
"outputs": 1,
"x": 3610,
"y": 1300,
"60e7fec1d0aab87d"
"id": "3718eef95a9b8ed4",
"type": "inject",
"name": "Auto start boucle",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": true,
"onceDelay": 0.1,
"topic": "",
"payload": "1",
"payloadType": "num",
"x": 3370,
"y": 1300,
"6ed2b9fa8d8ce8cf"
This is ok.
Now i need to launch an other vidéo at the end of the game.
And for this i use it :
"type": "exec",
"addpay": "",
"append": "",
"timer": "0",
"winHide": false,
"oldrc": false,
"x": 3830,
"y": 1300,
"type": "trigger",
"op1": "1",
"op2": "0",
"op1type": "str",
"op2type": "str",
"duration": "-88",
"extend": false,
"units": "s",
"reset": "stop",
"bytopic": "all",
"topic": "topic",
"outputs": 1,
"x": 3610,
"y": 1300,
"60e7fec1d0aab87d"
"id": "01e6ec691f86fe25",
"type": "exec",
"command": "export DISPLAY=:0 && vlc /home/timoxy/Desktop/perdudef.mp4",
"addpay": "",
"append": "",
"timer": "0",
"winHide": false,
"oldrc": false,
"name": "Video perdu",
"x": 3370,
"y": 1420,
"id": "b12896a6c43edfde",
"type": "ui_button",
"name": "Vidéo perdu",
"group": "c610de28f5057fa3",
"order": 2,
"width": 6,
"height": 1,
"passthru": false,
"label": "Video perdu",
"tooltip": "",
"color": "",
"bgcolor": "{{background}}",
"className": "",
"icon": "",
"payload": "stop",
"payloadType": "str",
"topic": "stop",
"topicType": "msg",
"x": 3010,
"y": 1400,
"01e6ec691f86fe25",
"86defcd86817f1a2",
"87e55050e6fa4486",
"16da204e4edf1eb3"
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": true,
"onceDelay": 0.1,
"topic": "",
"payload": "1",
"x": 3370,
"y": 1300,
"6ed2b9fa8d8ce8cf"
"id": "c7edae2312bfc3fc",
"type": "change",
"name": "Vert",
"rules": [
"t": "set",
"p": "background",
"pt": "msg",
"to": "Green",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 2890,
"y": 1520,
"b12896a6c43edfde"
"id": "02f34dceb093a3b9",
"type": "change",
"name": "Rouge",
"rules": [
"t": "set",
"p": "background",
"pt": "msg",
"to": "red",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 3110,
"y": 1520,
"b12896a6c43edfde"
"id": "87e55050e6fa4486",
"type": "delay",
"name": "Delai passage vert",
"pauseType": "delay",
"timeout": "0.5",
"timeoutUnits": "seconds",
"rate": "1",
"nbRateUnits": "1",
"rateUnits": "second",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": false,
"allowrate": false,
"outputs": 1,
"x": 2910,
"y": 1460,
"c7edae2312bfc3fc",
"1d084d36709c99b6"
"id": "1d084d36709c99b6",
"type": "delay",
"name": "Délai rouge",
"timeout": "60",
"timeoutUnits": "minutes",
"rate": "1",
"nbRateUnits": "1",
"randomFirst": "1",
"randomLast": "5",
"drop": false,
"allowrate": false,
"outputs": 1,
"x": 3110,
"y": 1460,
"02f34dceb093a3b9"
"id": "16da204e4edf1eb3",
"type": "change",
"name": "Stop boucle ",
"rules": [
"t": "change",
"p": "payload",
"pt": "msg",
"from": "0",
"fromt": "num",
"to": "stop",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "COURT",
"fromt": "str",
"to": "stop",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "stop",
"fromt": "str",
"to": "stop",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 3370,
"y": 1360,
"6ed2b9fa8d8ce8cf"
"id": "c610de28f5057fa3",
"type": "ui_group",
"name": "Fin",
"tab": "cb8fc504867904ea",
"order": 5,
"disp": true,
"width": "6",
"collapse": false,
"className": ""
"id": "cb8fc504867904ea",
"type": "ui_tab",
"name": "Salle INDIANA",
"icon": "dashboard",
"order": 1,
"disabled": false,
"hidden": false
Problem, i can ear the sound, but my vidéo loop don't stop. I try with an exec node when i push on "vidéo perdu" and the msg.kill but nothing too. My vidéo loop stay play.
What is your purpose to male this correctly ?
thanks in advance.
