VLC multimedia player con Node Red
How can i run VLC CLI commands on rc ,like stop pause etc. ,when music is playing ?
On the linux console jus i have to write pause stop next , after >
did someone work in this kind os situations?
one way would be to use an exec node to send those commands.
hello zenofmud ,
i work with exec node and plays music ok
runinng play folder with
vlc -z random/..../folder name (linux command)
but this kind of commands ,called CLI commands runs in rc port or service,
the result is : rc error in the bottom of exec node,
+----[ CLI commands ]
| add XYZ . . . . . . . . . . . . . . . . . . . . add XYZ to playlist
| enqueue XYZ . . . . . . . . . . . . . . . . . queue XYZ to playlist
| playlist . . . . . . . . . . . . . show items currently in playlist
| search [string] . . search for items in playlist (or reset search)
| delete . . . . . . . . . . . . . . . . delete item X in playlist
| move [Y] . . . . . . . . . . . . move item X in playlist after Y
| sort key . . . . . . . . . . . . . . . . . . . . . sort the playlist
| sd [sd] . . . . . . . . . . . . . show services discovery or toggle
| play . . . . . . . . . . . . . . . . . . . . . . . . . . play stream
| stop . . . . . . . . . . . . . . . . . . . . . . . . . . stop stream
| next . . . . . . . . . . . . . . . . . . . . . . next playlist item
| prev . . . . . . . . . . . . . . . . . . . . previous playlist item
| goto, gotoitem . . . . . . . . . . . . . . . . . goto item at index
| repeat [on|off] . . . . . . . . . . . . . . toggle playlist repeat
| loop [on|off] . . . . . . . . . . . . . . . . toggle playlist loop
| random [on|off] . . . . . . . . . . . . . . toggle playlist random
| clear . . . . . . . . . . . . . . . . . . . . . clear the playlist
| status . . . . . . . . . . . . . . . . . . . current playlist status
| title . . . . . . . . . . . . . . set/get title in current item
| title_n . . . . . . . . . . . . . . . . next title in current item
| title_p . . . . . . . . . . . . . . previous title in current item
| chapter . . . . . . . . . . . . set/get chapter in current item
| chapter_n . . . . . . . . . . . . . . next chapter in current item
| chapter_p . . . . . . . . . . . . previous chapter in current item
| seek X . . . . . . . . . . . seek in seconds, for instance `seek 12'
| pause . . . . . . . . . . . . . . . . . . . . . . . . toggle pause
| fastforward . . . . . . . . . . . . . . . . . . set to maximum rate
| rewind . . . . . . . . . . . . . . . . . . . . . set to minimum rate
| faster . . . . . . . . . . . . . . . . . . faster playing of stream
| slower . . . . . . . . . . . . . . . . . . slower playing of stream
| normal . . . . . . . . . . . . . . . . . . normal playing of stream
| rate [playback rate] . . . . . . . . . . set playback rate to value
| frame . . . . . . . . . . . . . . . . . . . . . play frame by frame
| fullscreen, f, F [on|off] . . . . . . . . . . . . toggle fullscreen
| info . . information about the current stream (or specified id)
| stats . . . . . . . . . . . . . . . . show statistical information
| get_time . . . . . . . . . seconds elapsed since stream's beginning
| is_playing . . . . . . . . . . . . 1 if a stream plays, 0 otherwise
| get_title . . . . . . . . . . . . . the title of the current stream
| get_length . . . . . . . . . . . . the length of the current stream
| volume . . . . . . . . . . . . . . . . . . set/get audio volume
| volup . . . . . . . . . . . . . . . raise audio volume X steps
| voldown . . . . . . . . . . . . . . lower audio volume X steps
| achan . . . . . . . . . . . . set/get stereo audio output mode
| atrack . . . . . . . . . . . . . . . . . . . set/get audio track
| vtrack . . . . . . . . . . . . . . . . . . . set/get video track
| vratio . . . . . . . . . . . . . . . set/get video aspect ratio
| vcrop, crop . . . . . . . . . . . . . . . . set/get video crop
| vzoom, zoom . . . . . . . . . . . . . . . . set/get video zoom
| vdeinterlace . . . . . . . . . . . . . set/get video deinterlace
| vdeinterlace_mode . . . . . . . set/get video deinterlace mode
| snapshot . . . . . . . . . . . . . . . . . . . . take video snapshot
| strack . . . . . . . . . . . . . . . . . set/get subtitle track
| vlm . . . . . . . . . . . . . . . . . . . . . . . . . load the VLM
| description . . . . . . . . . . . . . . . . . describe this module
| help, ? [pattern] . . . . . . . . . . . . . . . . . a help message
| longhelp [pattern] . . . . . . . . . . . . . . a longer help message
| lock . . . . . . . . . . . . . . . . . . . . lock the telnet prompt
| logout . . . . . . . . . . . . . . exit (if in a socket connection)
| quit . . . . . . . . quit VLC (or logout if in a socket connection)
| shutdown . . . . . . . . . . . . . . . . . . . . . . . shutdown VLC
+----[ end of help ]
If you are using the rc interface then the commands need to come in via stdin... luckily you can do that if you use the node-red-node-daemon node as that runs commands like exec but uses the input wire for stdin.
muchas gracias dceejay voy a probarlo
