Controlling zigbee switch
Hello
I am running nodered with a CONBEE II gateway and connecting via deconz. I have paired a 2 gang switch with the CONBEE II. It for some reason identifies it as a "smart plug", who knows why.
Anyways when I address the light switch using the following flow, I can only toggle one of the 2 switches on the 2 gang light switch.
I am not sure how to get to the other one. Is there a way I can find out how to address the 2nd switch?
This is the flow:
The switch node is as follows:
The out node is as follows:
Solved it, switched zigbee2mqtt which is far superior to deconz in terms of debug information.
