Zigbee switch not working
Although I've read the post below, I still have a non working situation.
https://discourse.nodered.org/t/howto-set-a-zigbee-switch/45227/2
I installed MQTTexplorer and this is what I see
My goal is to have the switches working in HA without the zigbee2MQTT addon.
I don't know about HA (few here do) but if you configure an MQTT In node with that topic you will instantly have access to the data.
I am on my phone so have not looked at your flow.
Unfortunately your flow is not importable. In order to make flow importable it is important to surround your code with three backticks
like this
When pasting the flow you can use the </> button to add the backticks.
You can edit and correct your post by clicking the pencil icon.
Looking at the text of the flow you posted, even though it is not importable, I see that you are sending data to the mqtt topic cmnd/home/ZbSend, I thought you were trying to get the current state from the switch.
Can you post a link to the docs describing what you have to send to that switch to control it?
Also are you able to see control the switch by any other means?
[{"id":"434ba335.1c8b7c","type":"tab","label":"Zigbee","disabled":false,"info":""},{"id":"41e6870f.95be88","type":"mqtt out","z":"434ba335.1c8b7c","name":"TestZigbee","topic":"","qos":"2","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"fdf8e6cc.83733","x":510,"y":440,"wires":[]},{"id":"1338adea.a0c8d2","type":"inject","z":"434ba335.1c8b7c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"cmnd/home/ZbSend","payload":"{\"device\":\"light.sonoff_01minizb_62b7e9fe_on_off\",\"send\":{\"Power\":\"Toggle\"}}","payloadType":"json","x":170,"y":440,"wires":[["41e6870f.95be88","6d573cbe.79f4d4"]]},{"id":"6d573cbe.79f4d4","type":"debug","z":"434ba335.1c8b7c","name":"debug","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":310,"y":340,"wires":[]},{"id":"fdf8e6cc.83733","type":"mqtt-broker","name":"MQTT","broker":"core-mosquitto","port":"1883","clientid":"","usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
I used the info as discussed in the link a the top of this post and I want to control the zigbee switch (on/off) based on the provided input. I can control the switch manually in HA (so it is connected and working).
Meanwhile I used the tip to correct my flow :wink:
I'm using
Program Version	9.5.0(zbbridge)
Build Date & Time	2021-06-17T08:27:09
Core/SDK Version	2_7_4_9/2.2.2-dev(38a443e)
it works for me.
The topic you are using does not seem to be anything like the one in the post you linked to.
Communicating is always a tricky thing. In my situation I'm trying to switch on (or off) a zigbee device in my network via node-red. Maybe I'm too new to node-red to understand that my situation is different than I mentioned as a reference in my openings post. IF so, can someone explain the difference so I can learn :wink:
I have the same firmware, but in ZHABridge mode. Is my issue that I need to reconfigure the sonoff to zbbridge mode ? And can you provide a simple example that I can try ?
No, you have version 9.5.0.8
Your inject node seems to be ok, here an example I'm using:
	"topic": "cmnd/zigbeeBridge/ZbSend",
	"payload": "{"Device":"moesActuator","Send":{"Power":"Toggle"}}",
	"payloadType": "json",
So you are using this firmware ?
Correct, actually there is a new Tasmota v10.0.0 Norman.
Just "downgraded" to 9.5.0
No improvement yet. Not sure what device name to use...
Can you confirm that your Sonoff is in ZHA-bridge mode (or are you using a different mode?)
Module_type:
thnx, will give it a try tonight :wink:
To test your device you can also use the zigbee commands in the console.
https://tasmota.github.io/docs/Commands/#zigbee
Moved to Hardware category as this is more about Tasmota than Node-RED. :slight_smile:
Thanks for your help again. I can confirm that it is working after I found the correct device name, based on the fact that I was able to determine my switch from this list (only device with an "off" indication)..
I'm still looking for a way to "find" the user-friendly name that I can use in Node-red, but that is a new question :wink:
