Conversion and display milliseconds in the format "dd hh mm ss"
I have a problem with converting and displaying milliseconds in the format dd hh mm ss.
I have 3 phases L1 L2 L3 and I want to add them together. This works so far, but with the conversion into the time format with display I have my problems.
Enclosed is the flow
[{"id":"a1ebb142b4c16134","type":"hourglass","z":"ab223f70ef9714e4","name":"","persistId":"","humanizeLocale":"de","x":700,"y":240,"wires":[["172a6aae37c048b7","8412c739ddf6844c","8b080acf89328693"]]},{"id":"7c58b0ce0bfb8638","type":"change","z":"ab223f70ef9714e4","name":"{command:'reset'}","rules":[{"t":"set","p":"command","pt":"msg","to":"reset","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":413,"y":340,"wires":[["1f6bc49396a41d57","a1ebb142b4c16134"]]},{"id":"dc825e0cf24a40da","type":"change","z":"ab223f70ef9714e4","name":"{command:'start'}","rules":[{"t":"set","p":"command","pt":"msg","to":"start","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":411,"y":240,"wires":[["1f6bc49396a41d57","a1ebb142b4c16134"]]},{"id":"6d1064821703a422","type":"change","z":"ab223f70ef9714e4","name":"{command:'stop'}","rules":[{"t":"set","p":"command","pt":"msg","to":"stop","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":411,"y":280,"wires":[["1f6bc49396a41d57","a1ebb142b4c16134"]]},{"id":"172a6aae37c048b7","type":"debug","z":"ab223f70ef9714e4","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"elapsed.millis","targetType":"msg","x":930,"y":240,"wires":[]},{"id":"1f6bc49396a41d57","type":"debug","z":"ab223f70ef9714e4","name":"last command","active":false,"tosidebar":false,"console":false,"tostatus":true,"complete":"command","targetType":"msg","x":710,"y":300,"wires":[]},{"id":"f03307ba4aa80b17","type":"inject","z":"ab223f70ef9714e4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":199,"y":280,"wires":[["6d1064821703a422"]]},{"id":"9496e44d13b49be8","type":"inject","z":"ab223f70ef9714e4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":199,"y":340,"wires":[["7c58b0ce0bfb8638"]]},{"id":"f367d10cf563c135","type":"inject","z":"ab223f70ef9714e4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":199,"y":240,"wires":[["dc825e0cf24a40da"]]},{"id":"2d29725919667220","type":"inject","z":"ab223f70ef9714e4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":199,"y":380,"wires":[["d4a7783041f5f5ee"]]},{"id":"d4a7783041f5f5ee","type":"change","z":"ab223f70ef9714e4","name":"{command:'status'}","rules":[{"t":"set","p":"command","pt":"msg","to":"status","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":411,"y":380,"wires":[["a1ebb142b4c16134","1f6bc49396a41d57"]]},{"id":"f10939ec9446df40","type":"hourglass","z":"ab223f70ef9714e4","name":"","persistId":"","humanizeLocale":"de","x":700,"y":520,"wires":[["63158f84c75c4952","5213156e8a852b9a","72a02534cde2d5a5"]]},{"id":"745039475fb5a097","type":"change","z":"ab223f70ef9714e4","name":"{command:'reset'}","rules":[{"t":"set","p":"command","pt":"msg","to":"reset","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":413,"y":620,"wires":[["e65a918d600b05a6","f10939ec9446df40"]]},{"id":"996e60d24b66c754","type":"change","z":"ab223f70ef9714e4","name":"{command:'start'}","rules":[{"t":"set","p":"command","pt":"msg","to":"start","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":411,"y":520,"wires":[["e65a918d600b05a6","f10939ec9446df40"]]},{"id":"c5fbf5595e129758","type":"change","z":"ab223f70ef9714e4","name":"{command:'stop'}","rules":[{"t":"set","p":"command","pt":"msg","to":"stop","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":411,"y":560,"wires":[["e65a918d600b05a6","f10939ec9446df40"]]},{"id":"63158f84c75c4952","type":"debug","z":"ab223f70ef9714e4","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"elapsed.millis","targetType":"msg","x":930,"y":520,"wires":[]},{"id":"e65a918d600b05a6","type":"debug","z":"ab223f70ef9714e4","name":"last command","active":false,"tosidebar":false,"console":false,"tostatus":true,"complete":"command","targetType":"msg","x":710,"y":580,"wires":[]},{"id":"193d3e08c95ed53e","type":"inject","z":"ab223f70ef9714e4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":199,"y":560,"wires":[["c5fbf5595e129758"]]},{"id":"64e8fd0d8bda81c2","type":"inject","z":"ab223f70ef9714e4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":199,"y":620,"wires":[["745039475fb5a097"]]},{"id":"0ffc7961b40a3d5f","type":"inject","z":"ab223f70ef9714e4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":199,"y":520,"wires":[["996e60d24b66c754"]]},{"id":"ff4563fd38183709","type":"inject","z":"ab223f70ef9714e4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":199,"y":660,"wires":[["6e2c21a552e5047e"]]},{"id":"6e2c21a552e5047e","type":"change","z":"ab223f70ef9714e4","name":"{command:'status'}","rules":[{"t":"set","p":"command","pt":"msg","to":"status","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":411,"y":660,"wires":[["f10939ec9446df40","e65a918d600b05a6"]]},{"id":"8412c739ddf6844c","type":"function","z":"ab223f70ef9714e4","name":"function 20","func":"// Time HH:MM:SS from number\n// Hours\nvar Hours = ((msg.payload) / 3600);\nvar hours = Math.floor(Hours);\n// Minutes\nvar Minutes = (msg.payload - (Hours * 3600)) / 60;\nvar Minutes = Math.floor(Minutes);\n// Seconds\nvar Seconds = (msg.payload - (Hours* 3600) - (Minutes * 60));\n// Concatenate\nvar Time = ('0' + Hours).slice(-2) + ':' + ('0' + Minutes).slice(-2) + ':' + ('0' + Seconds).slice(-2);\nmsg.payload = Time;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":910,"y":300,"wires":[["4dae37618d67f71e"]]},{"id":"4dae37618d67f71e","type":"ui_text","z":"ab223f70ef9714e4","group":"ca29b1fcd817a3a8","order":2,"width":4,"height":1,"name":"txt L1 GZ","label":"L1","format":"{{msg.elapsed.time.days}}d {{msg.elapsed.time.hours}}h {{msg.elapsed.time.minutes}}m {{msg.elapsed.time.seconds}}s","layout":"row-spread","className":"","x":1180,"y":300,"wires":[]},{"id":"8b080acf89328693","type":"function","z":"ab223f70ef9714e4","name":"variable g_gtL1","func":"var g_gtL1 = global.get('g_gtL1') || 0;\ng_gtL1 = Number(msg.elapsed.millis);\nglobal.set('g_gtL1', g_gtL1)\nmsg.payload = g_gtL1;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":920,"y":360,"wires":[["e360eb2df76f367a"]]},{"id":"e360eb2df76f367a","type":"debug","z":"ab223f70ef9714e4","name":"debug 80","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1180,"y":360,"wires":[]},{"id":"5213156e8a852b9a","type":"function","z":"ab223f70ef9714e4","name":"function 21","func":"// Time HH:MM:SS from number\n// Hours\nvar Hours = ((msg.payload) / 3600);\nvar hours = Math.floor(Hours);\n// Minutes\nvar Minutes = (msg.payload - (Hours * 3600)) / 60;\nvar Minutes = Math.floor(Minutes);\n// Seconds\nvar Seconds = (msg.payload - (Hours* 3600) - (Minutes * 60));\n// Concatenate\nvar Time = ('0' + Hours).slice(-2) + ':' + ('0' + Minutes).slice(-2) + ':' + ('0' + Seconds).slice(-2);\nmsg.payload = Time;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":930,"y":580,"wires":[["1e6012318787337a"]]},{"id":"72a02534cde2d5a5","type":"function","z":"ab223f70ef9714e4","name":"variable g_gtL2","func":"var g_gtL2 = global.get('g_gtL2') || 0;\ng_gtL2 = Number(msg.elapsed.millis);\nglobal.set('g_gtL2', g_gtL2)\nmsg.payload = g_gtL2;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":940,"y":640,"wires":[["b6dba36e0ed0f958"]]},{"id":"b6dba36e0ed0f958","type":"debug","z":"ab223f70ef9714e4","name":"debug 81","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1180,"y":640,"wires":[]},{"id":"1e6012318787337a","type":"ui_text","z":"ab223f70ef9714e4","group":"ca29b1fcd817a3a8","order":4,"width":4,"height":1,"name":"txt L2 GZ","label":"L2","format":"{{msg.elapsed.time.days}}d {{msg.elapsed.time.hours}}h {{msg.elapsed.time.minutes}}m {{msg.elapsed.time.seconds}}s","layout":"row-spread","className":"","x":1180,"y":580,"wires":[]},{"id":"7acb117175fed63d","type":"function","z":"ab223f70ef9714e4","name":"function 22","func":"// Time HH:MM:SS from number\n// Hours\nvar Hours = ((msg.payload) / 3600);\nvar hours = Math.floor(Hours);\n// Minutes\nvar Minutes = (msg.payload - (Hours * 3600)) / 60;\nvar Minutes = Math.floor(Minutes);\n// Seconds\nvar Seconds = (msg.payload - (Hours* 3600) - (Minutes * 60));\n// Concatenate\nvar Time = ('0' + Hours).slice(-2) + ':' + ('0' + Minutes).slice(-2) + ':' + ('0' + Seconds).slice(-2);\nmsg.payload = Time;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":930,"y":840,"wires":[["7acb93fba7392e49"]]},{"id":"322c967ec5d950da","type":"function","z":"ab223f70ef9714e4","name":"variable g_gtL3","func":"var g_gtL3 = global.get('g_gtL3') || 0;\ng_gtL3 = Number(msg.elapsed.millis);\nglobal.set('g_gtL3', g_gtL3)\nmsg.payload = g_gtL3;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":940,"y":900,"wires":[["4b630659327335b3"]]},{"id":"7acb93fba7392e49","type":"ui_text","z":"ab223f70ef9714e4","group":"ca29b1fcd817a3a8","order":6,"width":4,"height":1,"name":"txt L3 GZ","label":"L3","format":"{{msg.elapsed.time.days}}d {{msg.elapsed.time.hours}}h {{msg.elapsed.time.minutes}}m {{msg.elapsed.time.seconds}}s","layout":"row-spread","className":"","x":1180,"y":840,"wires":[]},{"id":"a83e49f9fef76d95","type":"hourglass","z":"ab223f70ef9714e4","name":"","persistId":"","humanizeLocale":"de","x":700,"y":780,"wires":[["96f0b87aec008694","7acb117175fed63d","322c967ec5d950da","94993c411838482b"]]},{"id":"15f31d7dbe3844ba","type":"change","z":"ab223f70ef9714e4","name":"{command:'reset'}","rules":[{"t":"set","p":"command","pt":"msg","to":"reset","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":413,"y":880,"wires":[["8749db4dcd7109cd","a83e49f9fef76d95"]]},{"id":"9d5afa489aadc18b","type":"change","z":"ab223f70ef9714e4","name":"{command:'start'}","rules":[{"t":"set","p":"command","pt":"msg","to":"start","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":411,"y":780,"wires":[["8749db4dcd7109cd","a83e49f9fef76d95"]]},{"id":"1bc4f55112725a18","type":"change","z":"ab223f70ef9714e4","name":"{command:'stop'}","rules":[{"t":"set","p":"command","pt":"msg","to":"stop","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":411,"y":820,"wires":[["8749db4dcd7109cd","a83e49f9fef76d95"]]},{"id":"8749db4dcd7109cd","type":"debug","z":"ab223f70ef9714e4","name":"last command","active":false,"tosidebar":false,"console":false,"tostatus":true,"complete":"command","targetType":"msg","x":710,"y":840,"wires":[]},{"id":"a947450bc94f3f81","type":"inject","z":"ab223f70ef9714e4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":199,"y":820,"wires":[["1bc4f55112725a18"]]},{"id":"ea55c5d89546bdaf","type":"inject","z":"ab223f70ef9714e4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":199,"y":880,"wires":[["15f31d7dbe3844ba"]]},{"id":"116f3edac4b6e7aa","type":"inject","z":"ab223f70ef9714e4","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":199,"y":780,"wires":[["9d5afa489aadc18b"]]},{"id":"5f155b6f8f1d707a","type":"inject","z":"ab223f70ef9714e4","name":"","props":[{"p":"payload","v":"","vt":"str"},{"p":"topic","v":"","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":90,"y":920,"wires":[["fc15dd457444f4ed","6db784678c3195df","6e2c21a552e5047e","d4a7783041f5f5ee"]]},{"id":"fc15dd457444f4ed","type":"change","z":"ab223f70ef9714e4","name":"{command:'status'}","rules":[{"t":"set","p":"command","pt":"msg","to":"status","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":411,"y":920,"wires":[["a83e49f9fef76d95","8749db4dcd7109cd"]]},{"id":"96f0b87aec008694","type":"debug","z":"ab223f70ef9714e4","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"elapsed.millis","targetType":"msg","x":930,"y":780,"wires":[]},{"id":"4b630659327335b3","type":"debug","z":"ab223f70ef9714e4","name":"debug 91","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":1180,"y":900,"wires":[]},{"id":"6db784678c3195df","type":"function","z":"ab223f70ef9714e4","name":"Addition L1 L2 L3 gesamt","func":"var g_gtL1 = global.get('g_gtL1');\nvar g_gtL2 = global.get('g_gtL2');\nvar g_gtL3 = global.get('g_gtL3');\nvar msg_gtL123 = Number(g_gtL1) + Number(g_gtL2) + Number(g_gtL3);\nmsg.payload = msg_gtL123;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":670,"y":1120,"wires":[["e26037c6705eeca3","e8227be06fac0bd0"]]},{"id":"e26037c6705eeca3","type":"function","z":"ab223f70ef9714e4","name":"Umrechnung millis in Zeit","func":"// Time HH:MM:SS from number\n// Hours\nvar Hours = ((msg.payload) / 3600);\nvar hours = Math.floor(Hours);\n// Minutes\nvar Minutes = (msg.payload - (Hours * 3600)) / 60;\nvar Minutes = Math.floor(Minutes);\n// Seconds\nvar Seconds = (msg.payload - (Hours* 3600) - (Minutes * 60));\n// Concatenate\nvar Time = ('0' + Hours).slice(-2) + ':' + ('0' + Minutes).slice(-2) + ':' + ('0' + Seconds).slice(-2);\nmsg.payload = Time;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":930,"y":1120,"wires":[["6750bf5c91d7f94d","6dea868ecd29d75f"]]},{"id":"6750bf5c91d7f94d","type":"ui_text","z":"ab223f70ef9714e4","group":"ca29b1fcd817a3a8","order":10,"width":4,"height":1,"name":"txt Gesamt L1/L2/L3","label":"Gesamt L1/L2/L3","format":"{{msg.elapsed.time.days}}d {{msg.elapsed.time.hours}}h {{msg.elapsed.time.minutes}}m {{msg.elapsed.time.seconds}}s","layout":"row-spread","className":"","x":1180,"y":1120,"wires":[]},{"id":"e8227be06fac0bd0","type":"debug","z":"ab223f70ef9714e4","name":"debug 92","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":880,"y":1180,"wires":[]},{"id":"6dea868ecd29d75f","type":"debug","z":"ab223f70ef9714e4","name":"debug 93","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":1140,"y":1180,"wires":[]},{"id":"94993c411838482b","type":"debug","z":"ab223f70ef9714e4","name":"debug 94","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":1180,"y":960,"wires":[]},{"id":"ca29b1fcd817a3a8","type":"ui_group","name":"Zähler Gesamtlaufzeit","tab":"1df1d979d4e318b9","order":2,"disp":true,"width":5,"collapse":false,"className":""},{"id":"1df1d979d4e318b9","type":"ui_tab","name":"Betriebsstundenzähler","icon":"fa-clock-o","order":7,"disabled":false,"hidden":false}]
The individual 3 phases L1 L2 L3 work, but I can't get it to work as a sum.
Thanks for the help
Many greetings
Roland
You can use $moment() in a JSONata expression in a change node.
In this example i show how to format and adjust timezone offset.
        "id": "1d473eaa4ce9c254",
        "type": "inject",
        "z": "da8a6ef0b3c9a5c8",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 120,
        "y": 4660,
                "75857019892df4bc"
        "id": "75857019892df4bc",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "$moment($$.payload).tz(\"Europe/London\").format(\"Do hh:mm:ss\")",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 280,
        "y": 4660,
                "cc13905ef6e7f8ca"
        "id": "cc13905ef6e7f8ca",
        "type": "debug",
        "name": "debug 231",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 450,
        "y": 4660,
Expression
$moment($$.payload).tz("Europe/London").format("Do hh:mm:ss")
Output
"9th 05:19:33"
Hello E1cid,
Thanks for the quick answer.
but I don't think it works quite the way I need it to.
I have set the printout to
$moment($$.payload).format("hh mm ss")
I mean, it's being calculated incorrectly.
3x 1h:45m = 5h:15m but 6h 6m is displayed.
I don't want to convert a date or timestamp, but to sum up running times
That's not what you asked.
You need to present example data and what you expect as output. Note data should be copyable or presented in inject nodes as inputs. An description of how these message/s arrive would also be help full.
From 4 days ago, may help you.
Hello E1cid,
sorry, maybe my english is not good enough, but i mean i described it like this.
I record the operating time of the 3 phases. I use the node hourglass for this. The elapsed time is output in milliseconds.
Then I would like to add the three determined times together and form a sum, which also still works. With the calculated sum in milliseconds, the operating time should now be output. In the format number of days, number of hours, number of minutes, number of seconds. I have problems converting the milliseconds and then displaying them.
This works for the individual phases L1 etc. This is probably because the correct information (for example, elapsed.time.hours) already comes from hourglass.
I have already specified the flow, it is about the millis to time conversion function. For example, 7095097 ms should be converted into 0d 1h 58m 15s.
Sorry again for the misunderstandings and the effort.
I hope someone has a solution for me.
here is is an example function.
let days = Math.floor(msg.payload / 86400000);
let hours = Math.floor(msg.payload / 3600000) % 24;
let minutes = Math.floor(msg.payload / 60000) % 60;
let seconds = Math.round((msg.payload % 60000) /1000);
msg.payload = `${days}d ${hours}h ${minutes}m ${seconds}s`;
Good morning E1cid,
I think I'm better off with that one.
Thanks for the support!
Many greetings
Roland
