Hi, I'm starting to play with the Dragino end node on the HELIUM network. The device was successfully connected, a copy/paste of the payload decoder from the Dragino repository was also made and data is displayed correctly.
I want to use the same payload decoder in a function on Node-RED.
Can anyone help? Thx!
Here are some images and data that need to be decoded (I found some questions about decoding in the forum and I made a buffer parser to decode the content, I got the data (buffer) but I want to make the function output as JSON on HELIUM due to some specifics).
Payload decoder:
//LSN50 Decode
if(port==0x02)
var decode = {};
var mode=(bytes[6] & 0x7C)>>2;
decode.Digital_IStatus= (bytes[6] & 0x02)? "H":"L";
if(mode!=2)
decode.BatV= (bytes[0]<<8 | bytes[1])/1000;
if((bytes[2]==0x7f)&&(bytes[3]==0xff))
decode.TempC1= "NULL";
else
decode.TempC1= parseFloat(((bytes[2]<<24>>16 | bytes[3])/10).toFixed(1));
if(mode!=8)
decode.ADC_CH0V= (bytes[4]<<8 | bytes[5])/1000;
if((mode!=5)&&(mode!=6))
decode.EXTI_Trigger= (bytes[6] & 0x01)? "TRUE":"FALSE";
decode.Door_status= (bytes[6] & 0x80)? "CLOSE":"OPEN";
if(mode=='0')
decode.Work_mode="IIC";
if((bytes[9]<<8 | bytes[10])===0)
decode.Illum= (bytes[7]<<8 | bytes[8]);
else
if(((bytes[7]==0x7f)&&(bytes[8]==0xff))||((bytes[7]==0xff)&&(bytes[8]==0xff)))
decode.TempC_SHT= "NULL";
else
decode.TempC_SHT= parseFloat(((bytes[7]<<24>>16 | bytes[8])/10).toFixed(1));
if((bytes[9]==0xff)&&(bytes[10]==0xff))
decode.Hum_SHT= "NULL";
else
decode.Hum_SHT= parseFloat(((bytes[9]<<8 | bytes[10])/10).toFixed(1));
else if(mode=='1')
decode.Work_mode="Distance";
if((bytes[7]===0x00)&&(bytes[8]===0x00))
decode.Distance_cm= "NULL";
else
decode.Distance_cm= parseFloat(((bytes[7]<<8 | bytes[8])/10).toFixed(1));
if(!((bytes[9]==0xff)&&(bytes[10]==0xff)))
decode.Distance_signal_strength= (bytes[9]<<8 | bytes[10]);
else if(mode=='2')
decode.Work_mode="3ADC+IIC";
decode.BatV= bytes[11]/10;
decode.ADC_CH0V= (bytes[0]<<8 | bytes[1])/1000;
decode.ADC_CH1V= (bytes[2]<<8 | bytes[3])/1000;
decode.ADC_CH4V= (bytes[4]<<8 | bytes[5])/1000;
else
else
else
else if(mode=='3')
decode.Work_mode="3DS18B20";
if((bytes[7]==0x7f)&&(bytes[8]==0xff))
decode.TempC2= "NULL";
else
decode.TempC2= parseFloat(((bytes[7]<<24>>16 | bytes[8])/10).toFixed(1));
if((bytes[9]==0x7f)&&(bytes[10]==0xff))
decode.TempC3= "NULL";
else
decode.TempC3= parseFloat(((bytes[9]<<24>>16 | bytes[10])/10).toFixed(1));
else if(mode=='4')
decode.Work_mode="Weight";
decode.Weight= (bytes[9]<<24 | bytes[10]<<16 | bytes[7]<<8 | bytes[8]);
else if(mode=='5')
decode.Work_mode="1Count";
decode.Count= (bytes[7]<<24 | bytes[8]<<16 | bytes[9]<<8 | bytes[10])>>>0;
else if(mode=='6')
decode.Work_mode="3Interrupt";
decode.EXTI1_Trigger= (bytes[6] & 0x01)? "TRUE":"FALSE";
decode.EXTI1_Status= (bytes[6] & 0x80)? "CLOSE":"OPEN";
decode.EXTI2_Trigger= (bytes[7] & 0x10)? "TRUE":"FALSE";
decode.EXTI2_Status= (bytes[7] & 0x01)? "CLOSE":"OPEN";
decode.EXTI3_Trigger= (bytes[8] & 0x10)? "TRUE":"FALSE";
decode.EXTI3_Status= (bytes[8] & 0x01)? "CLOSE":"OPEN";
else if(mode=='7')
decode.Work_mode="3ADC+1DS18B20";
decode.ADC_CH1V= (bytes[7]<<8 | bytes[8])/1000;
decode.ADC_CH4V= (bytes[9]<<8 | bytes[10])/1000;
else if(mode=='8')
decode.Work_mode="3DS18B20+2Count";
if((bytes[4]==0x7f)&&(bytes[5]==0xff))
else
decode.TempC2= parseFloat(((bytes[4]<<24>>16 | bytes[5])/10).toFixed(1));
else
decode.TempC3= parseFloat(((bytes[7]<<24>>16 | bytes[8])/10).toFixed(1));
decode.Count1= (bytes[9]<<24 | bytes[10]<<16 | bytes[11]<<8 | bytes[12])>>>0;
decode.Count2= (bytes[13]<<24 | bytes[14]<<16 | bytes[15]<<8 | bytes[16])>>>0;
if(bytes.length!=1)
return decode;
else if(port==5)
var freq_band;
var sub_band;
if(bytes[0]==0x01)
freq_band="EU868";
else if(bytes[0]==0x02)
freq_band="US915";
else if(bytes[0]==0x03)
freq_band="IN865";
else if(bytes[0]==0x04)
freq_band="AU915";
else if(bytes[0]==0x05)
freq_band="KZ865";
else if(bytes[0]==0x06)
freq_band="RU864";
else if(bytes[0]==0x07)
freq_band="AS923";
else if(bytes[0]==0x08)
freq_band="AS923_1";
else if(bytes[0]==0x09)
freq_band="AS923_2";
else if(bytes[0]==0x0A)
freq_band="AS923_3";
else if(bytes[0]==0x0F)
freq_band="AS923_4";
else if(bytes[0]==0x0B)
freq_band="CN470";
else if(bytes[0]==0x0C)
freq_band="EU433";
else if(bytes[0]==0x0D)
freq_band="KR920";
else if(bytes[0]==0x0E)
freq_band="MA869";
if(bytes[1]==0xff)
sub_band="NULL";
else
sub_band=bytes[1];
var firm_ver= (bytes[2]&0x0f)+'.'+(bytes[3]>>4&0x0f)+'.'+(bytes[3]&0x0f);
var tdc_time= bytes[4]<<16 | bytes[5]<<8 | bytes[6];
return {
FIRMWARE_VERSION:firm_ver,
FREQUENCY_BAND:freq_band,
SUB_BAND:sub_band,
TDC_sec:tdc_time,
Data for decoding (msg.payload):
DkAAyAA5GQAA//8=
Picture from HELIUM (script,script validator, payload input and payload output):
