Hi everybody,
I have a small issue concerning decoding the payload of the Dragino LWL01 sensor.
The sensor gives off data, which I receive (as should) as a payloadstring. (take 0B 76 02 00 00 17 00 00 00, for example)
According to the LWL01 manual, the payload is translated into:
Size (bytes)
2 (status & bat)
1 (mod Always 0x02)
3 (total waterleak events)
3 (last waterleak duration in mins)9 bytes in total (10 in newer documents)
I use the function node with the following lines to decode in NodeRed:
let payloadData = msg.payload;
let batteryRaw = ('0x' + payloadData.substr(1,3)) & 0x3FFF;
let batteryDec = batteryRaw/1000;
let statusNow = ('0x'+ payloadData.substr(1,2)) & 0x40;
let Moddata = (payloadData.substr(4,2));
let totalLeaks = (payloadData.substr(6,6));
let lastleakduration = (payloadData.substr(12,6));
msg.payload = {
    data : batteryDec,
    Status : statusNow,
    Mod : Moddata,
    leaks : totalLeaks,
    duration : lastleakduration
Now the issue is that when I test the function node with the example payload, I can see every value (battery 2,934, mod 0x20, waterleaks 000017, time 000000) but not the most important value for me: the status (open/close, cq. leak / no leak).
Regardless of which payload I supply, the status always seems to be 0. (open, no leak).
Dragino has a payload example for TTN, but I have no idea how I should rewrite the status part into my own decoder in NodeRed.
For TTN they use (shortened):
function Decoder(bytes, port) {
  // Decode an uplink message from a buffer
  // (array) of bytes to an object of fields.
  var value=(bytes[0]<<8 | bytes[1])&0x3FFF;
  var bat=value/1000;//Battery,units:V
  var water_leak_status=bytes[0]&0x40?1:0;
  var mod=bytes[2];
  var alarm=bytes[9]&0x01;
  var leak_times=bytes[3]<<16 | bytes[4]<<8 | bytes[5];
  var leak_duration=bytes[6]<<16 | bytes[7]<<8 | bytes[8];//units:min
  if(bytes.length==10 &&  0x07>bytes[0]< 0x0f)
  return {
      BAT_V:bat,
      MOD:mod,
      WATER_LEAK_STATUS:water_leak_status,
      WATER_LEAK_TIMES:leak_times,
      LAST_WATER_LEAK_DURATION:leak_duration
Two other payload examples:
4BB80200001700000000 (closed, leak)
0B760200001700000000 (open, no leak)
If anybody can help me out...would be highly appreciated!
Thank you!
