Convert string in array to value
I am new to the forum. I'm Wesley, 38 years old and have been working on home automation for a while now. Recently I did an integration with node-red and the PLC. Everything is working well.
Now in Belgium the energy prices are rising enormously, there will be a capacity tariff. This means that you pay for the peaks that you cause.
I have extracted on a site the energy spot price per hour.
These are in a payload in an array
These values are "string" values separated by a comma. I have been searching for a week to convert these values to numbers. What have I already tried:
msg.payload = Number(msg.payload);
msg.payload = Number(msg.payload.vars["1"].value)
msg.payload = payload.replace(",", ".");
Nothing works :frowning:
(error NaN (not a number))
I have a value per hour, from this I want:
1: the average
2: the 5 highest values (hours are available in topic)
All thanks for the help
Hello Wesley,
your msg.payload is an array so in order to pick one element of that array and convert its nested payload to a number you have to do .. for example :
msg.payload = Number(msg.payload[1].payload)
the above is for converting the string of element in position 1
if you want to convert all your strings then :
msg.payload = msg.payload.map(el => Number(el.payload))
Your variable is in msg.payload[1]. payload
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
https://nodered.org/docs/user-guide/messages
(Off the top of my head)...
I suspect the value will need to have the comma changed to a decimal point
msg.payload = msg.payload.map(el => Number(el.payload.replace(",",".")))
opps .. missed that part .. you are right
Thanks in advance for helping me think.
If I use
then
do i use the "replace" then
TypeError: Cannot read property 'replace' of undefined
I collect the data as follows:
after Steve's post, I adjusted the payload
one of your values will be invalid.
Proof
when the payload contains [ { payload: '1,2' }, { payload: '3,4' }, { payload: null } ] you get error Cannot read property 'replace' of null
You could filter the array first
const filtered = msg.payload.filter(e => (!!e && e.payload != null))
const converted = filtered.map(el => Number((el.payload + "").replace(",",".")))
msg.payload = converted;
EDIT: updated ↑ function to handle situation when payload is already a number
If I retrieve everything without trying to convert I have the values below:
I may be wrong (don't have much node red experience yet) but I don't think I have any invalid values?
if i filter the array:
You have changed the data format. The code we offered won't work now.
Change code to...
const filtered = msg.payload.filter(e => e != null)
const converted = filtered.map(el => Number((el + "").replace(",",".")))
No succes :frowning:
Ok copy and paste the payload (of good data) using the copy value button that appears under your mouse when you hover over the payload in the debug window.
surround your data with three backticks to prevent corruption...
like this
We are only seeing part of your Function node code with that screenshot ..
did you change msg.payload further up or is msg.payload arriving at this Function as you shared in your 1st post ?
can you share the Flow instead of images ?
Here is proof if you send an array of strings in msg.payload it does work...
and here is proof in node-red...
Demo flow...
[{"id":"3dc90c37ee504bc4","type":"function","z":"eb81e71f9edd709c","name":"filter and convert","func":"\nconst filtered = msg.payload.filter(e => e != null)\nconst converted = filtered.map(el => Number((el + \"\").replace(\",\", \".\")))\nmsg.payload = converted;\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1700,"y":400,"wires":[["47f532c32e1e1cc0"]]},{"id":"f8a71f9cef66afb7","type":"inject","z":"eb81e71f9edd709c","name":"your data","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[\"192,36\",\"225,00\",\"213,72\"]","payloadType":"json","x":1480,"y":400,"wires":[["3dc90c37ee504bc4","96e556112cd78945"]]},{"id":"96e556112cd78945","type":"debug","z":"eb81e71f9edd709c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1560,"y":440,"wires":[]},{"id":"47f532c32e1e1cc0","type":"debug","z":"eb81e71f9edd709c","name":"result","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1850,"y":440,"wires":[]}]
Verry strange, now it's working :smiley:
thanks a lot!!!!!
