I would like to display the table with the table-node in dashboard 2. I have a string as an input. It looks like:
Device1:battery low;Device2:communication error;Device3:temperature error
How can I automatically convert the string into a format suitable for tables?
It should look like:
"Device": "Device1",
"Message": "battery low"
"Device": "Device2",
"Message": "communication error"
"Device": "Device3",
"Message": "temperature error"
Best regards
What makes that string? Is it something you can control (so that it generates a valid JSON or CSV etc?)
That string comes out of my smart home system. I don't think that I can control it.
OK, if you cannot control or change the input data, then you could use a function node to split it up (there are other ways like JSONata) but here is an example in a function:
const inputString = msg.payload
const deviceMessages = inputString.split(';')
const result = deviceMessages.map(deviceMessage => {
const [device, message] = deviceMessage.split(':')
return {
Device: device.trim(),
Message: message.trim()
msg.payload = result
return msg
NOTE: I have not taken care of any edge cases or error handling!
Thank you very much. The script works exactly as I need it to.
