Converting MQTT Payload to Dashbard gauge
my name is Steffen, and I am new to Node Red and this board.
I am also not very used to this JSON stuff. Actually I am very blind. Maybe anyone can help me.
I got an MQTT message payload string which looks like this
"{"value": -161}"
How can I change it, so that a dashboard gauge can handle the value as int. So I am interested in the -161 only. it can have positive and negative values up to int32 range. I would like to use a function block or direct entry in dashboard gauge If possible.
I am sure, this is very simple, but I don't get it...
thanks in advance,
Steffen
if it’s coming from MQTT it will be a string as you noticed. So use the JSON node to convert it back to a javascript object.
If you use a debug node after the JSON node you should see msg.payload.value is -161
Most nodes in Node-RED expect the important information to be in msg.payload
so you can then use a change node to Move msg.payload.value
to msg.payload
Thanks a lot. This worked.
