Let the messenge from MQTT to dashboard
Hello
I am new to Node-red ,me and my partner use MQTT send a vumerical value to Node-RED and we want to let the numerical value show on dashboard.
But dashboard doesn't display normally
What should we type in the function to make JSON to num and then it work properly
Thank you guys
Here is my Dashboard problem
        "id": "f9fe2c2f01e99be8",
        "type": "tab",
        "label": "流程1",
        "disabled": false,
        "info": "",
        "env": []
        "id": "e535daf2d4fb1eb0",
        "type": "mqtt in",
        "z": "f9fe2c2f01e99be8",
        "topic": "voice",
        "qos": "2",
        "datatype": "auto",
        "broker": "a4935c13259d9e5d",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 230,
        "y": 220,
                "c454898996b32641",
                "4373f8d70e343e80"
        "id": "c454898996b32641",
        "type": "function",
        "func": "obj= JSON.parse(msg.payload);\nlet val= obj.sensorValue;\nmsg.topic = `insert into sensorvalue.value(sensorValue) VALUES (${val})`;\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 350,
        "y": 360,
                "ace86d2a958a4fd1"
        "id": "0ec410b85991ab2a",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 830,
        "y": 360,
        "id": "ace86d2a958a4fd1",
        "type": "mysql",
        "mydb": "fb4ddc1302d2bf5b",
        "x": 600,
        "y": 420,
                "0ec410b85991ab2a"
        "id": "4373f8d70e343e80",
        "type": "ui_gauge",
        "group": "2ef1b540c7ab0e2e",
        "order": 0,
        "width": 0,
        "height": 0,
        "gtype": "gage",
        "title": "gauge",
        "label": "units",
        "format": "{{value}}",
        "min": 0,
        "max": "500",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "className": "",
        "x": 620,
        "y": 200,
        "id": "a4935c13259d9e5d",
        "type": "mqtt-broker",
        "broker": "192.168.68.57",
        "port": "1883",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "birthTopic": "",
        "birthQos": "2",
        "birthRetain": "true",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "sessionExpiry": ""
        "id": "fb4ddc1302d2bf5b",
        "type": "MySQLdatabase",
        "host": "localhost",
        "port": "3306",
        "db": "sensorvalue",
        "tz": "",
        "charset": "UTF8"
        "id": "2ef1b540c7ab0e2e",
        "type": "ui_group",
        "name": "Default",
        "tab": "5e5688de16969c96",
        "order": 1,
        "disp": true,
        "width": "6",
        "collapse": false,
        "className": ""
        "id": "5e5688de16969c96",
        "type": "ui_tab",
        "name": "Home",
        "icon": "dashboard",
        "disabled": false,
        "hidden": false
First of all... Welcome to the forum.
I think we need more details from you in order to give you a sensible response.
Can you explain what is not working on the Dashboard?
Can you share the Node-RED flow you have created so far?
You can change the {{value}} to {{payload.sensorValue}}
and set the mqtt in node to a parsed json object
Thank you for helping me solve such a simple problem Thanks a lot
