Shorten message
Hi guys,
i got the following msg from Kodi over MQTT
"{"val": "Titel"}"
and i just want to see the titel on the Dashboard without the rest.
My function works but its not flexible
Thanks in advance
Select output a parse object in the mqtt node.
then access the value at msg.payload.val
Use a JSON node to change the string to a JS object OR set the MQTT node to parse JSON
Then simply use msg.payload.val
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
Thanks guys, now it works :slight_smile:
Both answers where perfekt and super fast!
