hi im new to node red and mqtt i have a sonoff th flashed with tasmota and i am trying to get the temperature to show in node red dashboard. this is how i set it up and what i get
any help would be great
thanks in advance
martin
Place a function node between your mqtt node and your ui node and write the following.
var temp = msg.payload.DS18B20.Temperature;
msg.payload = temp;
msg.topic = "Temperature";
Return msg;
The mqtt reply is a javascript object. You fetch the value from the object as demonstrated above.
The ui node needs a numeric value to display correctly.
The msg in node red is also an object. Always consisting out of minimum a topic and a payload.
Topic = description
Payload = value
Or use a change node:
Or in the Value Format field of the gauge put
{{payload.DS18B20.Temperature}}
thanks so much for the help i was pulling my hair out .
martin
