You can also use a join and split node, for a low code option.
Also you can use jsonata in a change node.
here is a n example of both methods.
[{"id":"f60a5489.434a28","type":"change","z":"bf9e1e33.030598","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$spread(msg.payload)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":1580,"wires":[["d3e1018c.b2864"]]},{"id":"af64afa4.30bb3","type":"inject","z":"bf9e1e33.030598","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"one\":1,\"two\":2}","payloadType":"json","x":160,"y":1500,"wires":[["2f53cb88.fb56c4","f60a5489.434a28"]]},{"id":"d3e1018c.b2864","type":"debug","z":"bf9e1e33.030598","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":670,"y":1580,"wires":[]},{"id":"2f53cb88.fb56c4","type":"split","z":"bf9e1e33.030598","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"topic","x":310,"y":1500,"wires":[["d74eb6af.1c5d38"]]},{"id":"447566c0.b6d668","type":"join","z":"bf9e1e33.030598","name":"","mode":"auto","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":"false","timeout":"","count":"","reduceRight":false,"x":610,"y":1500,"wires":[["d3e1018c.b2864"]]},{"id":"d74eb6af.1c5d38","type":"change","z":"bf9e1e33.030598","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload[msg.topic]","tot":"msg"},{"t":"set","p":"parts.type","pt":"msg","to":"array","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":450,"y":1500,"wires":[["447566c0.b6d668"]]}]
JSONata expression in a change node
$spread($$.payload)
