I'm not sure if the title correctly dictates what i need and i'm sorry if this something simple to do but i have no experience with javascript or coding and i'm fairly new to node red.
Here's an example of what i'm trying to accomplish,
I have the following payload:
"code":[
"352",
"353",
"354"
"number":[
447.1,
674.14,
493.78
"date":[
"31/3/21",
"1/4/21",
"6/4/21"
I would like to convert it to
"code":"352",
"number":447.1,
"date":"31/3/21"
"code":"353",
"number":674.14,
"date":"1/4/21"
"code":"354",
"number":493.78,
"date":"6/4/21"
Is there a node that can do this?
This might not be the most efficient but it does the trick. In a function node:
const x = {
"code":[
"352",
"353",
"354"
"number":[
447.1,
674.14,
493.78
"date":[
"31/3/21",
"1/4/21",
"6/4/21"
const out = []
Object.keys(x).forEach( entry => {
const e = {}
e.code = x[entry][0]
e.number = x[entry][1]
e.date = x[entry][2]
out.push(e)
msg.payload = out
return msg
Thank you,
This is in the right direction but not exactly what i need.
the result got me:
"code":"352",
"number":"353",
"date":"354"
"code":447.1,
"number":674.14,
"date":493.78
"code":"31/3/21",
"number":"1/4/21",
"date":"6/4/21"
The elements in the array get the values from the same original object.
Oops, so much for trying to rush. You will need to pick it apart a bit further then. All the elements are there, just not quite in the right order!
After 5 hours of searching the web, i finally found a way!
this is a link to the solution in case anyone ever needs it!
