I have a DataLogix Scanner and I am using TCP/IP node to read barcode data from the scanner and trigger the scanner at IP and Port 51240. This is working fine but according to the manufacture you use port 1023 for changing what saved configuration on the scanner you want to use and same port for "Entering Host Mode" which allows you to change the configuration file used. The problem is this requires Ascii commands with string values for file name of the config file on the scanner I want to change and this is not working for me.
flows (5).json (3.4 KB)
Its not working and I am not getting a rely like the instructions say I should.
I am not sure how to send these Ascii commands that the scanner is looking for. Any ideas on what I am doing wrong?
You dont actually send ESC and <LF> ...
... you should be sending the ASCII equivalent codes
also, as the device is supposed to respond, you should use the TCP Request node, like this...
100% untested - but should get you closer to a solution
Demo Flow...
[{"id":"f47c01500424c2da","type":"debug","z":"7c13b8452619581b","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1398,"y":1024,"wires":[]},{"id":"79dd3d36b4c1d8a1","type":"tcp in","z":"7c13b8452619581b","name":"","server":"client","host":"192.168.1.50","port":"51240","datamode":"stream","datatype":"utf8","newline":"","topic":"","base64":false,"tls":"","x":1140,"y":1024,"wires":[["f47c01500424c2da"]]},{"id":"d1f99ee1e6c3b126","type":"inject","z":"7c13b8452619581b","name":"A: Exit Host Mode","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"A","payloadType":"str","x":922,"y":768,"wires":[["ef2cd4b1e7de0fc3"]]},{"id":"ef2cd4b1e7de0fc3","type":"function","z":"7c13b8452619581b","name":"Generate MODE command","func":"//A == Exit Host Mode\n//B == Enter Programming Mode\n//C == Enter Host Mode\n\n\nconst ESC = '\\x1B';\nconst MODE = \"A\"; //A == Exit Host Mode\nmsg.payload = `${ESC}[${MODE}`;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1192,"y":768,"wires":[["94e0163bdde35c75"]]},{"id":"bce4cad9ea51bfb3","type":"inject","z":"7c13b8452619581b","name":"B: Enter Programming Mode","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"B","payloadType":"str","x":888,"y":800,"wires":[["ef2cd4b1e7de0fc3"]]},{"id":"e7eacbeafbae0d4f","type":"inject","z":"7c13b8452619581b","name":"C: Enter Host Mode","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"C","payloadType":"str","x":922,"y":832,"wires":[["ef2cd4b1e7de0fc3"]]},{"id":"94e0163bdde35c75","type":"tcp request","z":"7c13b8452619581b","name":"","server":"192.168.1.50","port":"1023","out":"time","ret":"buffer","splitc":"0","newline":"","tls":"","x":1372,"y":832,"wires":[["94892378cca31021"]]},{"id":"94892378cca31021","type":"debug","z":"7c13b8452619581b","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1402,"y":880,"wires":[]},{"id":"5adef4ee2d63b1b8","type":"inject","z":"7c13b8452619581b","name":"Change Scanner to Config1","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"CHANGE_CFG Config1","payloadType":"str","x":904,"y":896,"wires":[["721a64f983d3a9e5"]]},{"id":"721a64f983d3a9e5","type":"function","z":"7c13b8452619581b","name":"Add LF","func":"// \\n is the escape code for a new line (LF) in JS\n// \\r is the escape code for a carraige return (CR) in JS\nmsg.payload = `${msg.payload}\\n`;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1132,"y":896,"wires":[["94e0163bdde35c75"]]},{"id":"8b2ecb1161cadae9","type":"inject","z":"7c13b8452619581b","name":"Trigger Scan","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"T","payloadType":"str","x":954,"y":976,"wires":[["1bcf0218d03d5834"]]},{"id":"1bcf0218d03d5834","type":"tcp out","z":"7c13b8452619581b","name":"","host":"192.168.1.50","port":"51240","beserver":"client","base64":false,"end":false,"tls":"","x":1354,"y":976,"wires":[]}]
Thank you, I will give it a try
Add a debug to the output of "Generate MODE command" and "Add LF"
Check the debug sidebar - do they look correct?
In your screenshots, dont you see the "A" in every one of the commands? Doesnt that make you think there is a problem with the flow?
In the function Generate MODE command change the line...
const MODE = "A"; //A == Exit Host Mode
... to ...
const MODE = msg.payload;
Yes I have to look at the function node to see why the B or C are not showing up when injected but I am not sure how to get the ascii ESC to show up instead of the ? mark.
Thank you.
ESC is a non printable character.
If you want to be certain the correct ASCII codes are being generated, convert the string to a buffer in the function by adding msg.payload=Buffer.from(msg.payload, 'utf8') just before return msg
In the debug you will see a buffer with 3 values. The are the ASCII values of ESC [ A (refer to an online ASCII table for the values)
I changed msg.payload; and now see the other letters but I'm a little confused here.. what is 'utf8" for and in the Generate Mode function node what does line 6 do, const ESC = '\x1B'; ?
in the ASCII table I am looking at the Decimal value for ESC is 27 but should I even be looking at decimal conversion?
Hexadecimal 1B is decimal 27
lol...sorry total newb here. Ill see if I can figure it out.
