Core uncaught exception stopping node-red?
I am using node-red with 4G modem. On a timely fashion (each day at 08:56 and 09:12) i get two consecutive events that might be related to ip lease renewal or similar by the network carrier.
Anyway, i get an uncaught exception ENETUNREACH at TCP.onStreamRead (internal/stream_base_commons.js:209:20), that ends with node-red exitting. Might it be a node-red core uncaught exception or a palette node issue...
may 01 09:12:25 Node-RED[3916]: 1 May 09:12:25 - [red] Uncaught Exception:
may 01 09:12:25 Node-RED[3916]: 1 May 09:12:25 - Error: read ENETUNREACH
may 01 09:12:25 Node-RED[3916]: at TCP.onStreamRead (internal/stream_base_commons.js:209:20)
may 01 09:12:25 systemd[1]: nodered.service: Main process exited, code=exited, status=1/FAILURE
may 01 09:12:25 systemd[1]: nodered.service: Failed with result 'exit-code'.
may 01 09:12:45 systemd[1]: nodered.service: Scheduled restart job, restart counter is at 3.
may 01 09:12:45 systemd[1]: Stopped Node-RED graphical event wiring tool.
may 01 09:12:45 systemd[1]: Started Node-RED graphical event wiring tool.
Surely I can live with that, I was trying to report a potential issue just to improve this fantastic too,l
Thank you all!
What version of node-red and nodejs are you running? You can see the node-red version at the bottom of the Menu dropdown and you can run
node -v to get the nodejs version.
Are you using the core TCP node or is it something else using TCP?
After some digging I've found out that the issue is in postgres module that uses the postgres node
Thank you!
It would be very good if you could raise an issue for that against the contrib node so the author has a chance to fix up the node& prevent crashing node-red.
