after updating Nodered to V3.1.3 in Docker (19.03.15) I could not more install the
node-red-contrib-smartmeter V0.6.3
Any ideas why?
Here the logfile:
> node-red-docker@3.1.3 start
> node $NODE_OPTIONS node_modules/node-red/red.js $FLOWS --userDir /data
1 Feb 17:19:16 - [info]
Welcome to Node-RED
1 Feb 17:19:16 - [info] Node-RED version: v3.1.3
1 Feb 17:19:16 - [info] Node.js version: v16.20.2
1 Feb 17:19:16 - [info] Linux 4.9.0-19-amd64 x64 LE
1 Feb 17:19:19 - [info] Loading palette nodes
1 Feb 17:19:22 - [info] Dashboard version 3.6.2 started at /ui
1 Feb 17:19:23 - [info] Settings file : /data/settings.js
1 Feb 17:19:23 - [info] Context store : 'default' [module=memory]
1 Feb 17:19:23 - [info] User directory : /data
1 Feb 17:19:23 - [warn] Projects disabled : editorTheme.projects.enabled=false
1 Feb 17:19:23 - [info] Flows file : /data/flows.json
your credentials.
1 Feb 17:19:23 - [warn] Encrypted credentials not found
1 Feb 17:19:23 - [info] Server now running at http://127.0.0.1:1880/
1 Feb 17:19:23 - [info] Starting flows
1 Feb 17:19:23 - [info] Started flows
1 Feb 17:20:17 - [info] Installing module: node-red-contrib-smartmeter, version: 0.6.3
2024-02-01T17:20:18.242Z Installieren : node-red-contrib-smartmeter 0.6.3
2024-02-01T17:20:17.365Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-smartmeter@0.6.3
2024-02-01T17:20:19.698Z [err] npm
2024-02-01T17:20:19.699Z [err] WARN
2024-02-01T17:20:19.700Z [err] config production Use `--omit=dev` instead.
2024-02-01T17:20:33.979Z [err] npm
2024-02-01T17:20:33.980Z [err] WARN deprecated har-validator@5.1.5: this library is no longer supported
2024-02-01T17:20:34.302Z [err] npm
2024-02-01T17:20:34.303Z [err] WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
2024-02-01T17:20:34.387Z [err] npm
2024-02-01T17:20:34.388Z [err] WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
2024-02-01T17:20:43.633Z [err] npm
2024-02-01T17:20:43.634Z [err] ERR! code 1
2024-02-01T17:20:43.634Z [err] npm ERR! path /data/node_modules/@serialport/bindings
2024-02-01T17:20:43.645Z [err] npm ERR!
2024-02-01T17:20:43.646Z [err] command failed
2024-02-01T17:20:43.646Z [err] npm ERR! command sh -c -- prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
2024-02-01T17:20:43.646Z [err] make: Entering directory '/data/node_modules/@serialport/bindings/build'
2024-02-01T17:20:43.646Z [err] npm ERR! make: Leaving directory '/data/node_modules/@serialport/bindings/build'
2024-02-01T17:20:43.647Z [err] npm
2024-02-01T17:20:43.648Z [err]
2024-02-01T17:20:43.648Z [err] ERR! prebuild-install warn install No prebuilt binaries found (target=16.20.2 runtime=node arch=x64 libc=musl platform=linux)
2024-02-01T17:20:43.648Z [err] npm ERR!
2024-02-01T17:20:43.648Z [err] gyp info it worked if it ends with ok
2024-02-01T17:20:43.648Z [err] npm ERR! gyp info using node-gyp@9.1.0
2024-02-01T17:20:43.649Z [err] gyp info using node@16.20.2 | linux | x64
2024-02-01T17:20:43.649Z [err] npm ERR! gyp info find Python using Python version 3.11.6 found at "/usr/bin/python3"
2024-02-01T17:20:43.649Z [err] ERR! gyp http GET https://unofficial-builds.nodejs.org/download/release/v16.20.2/node-v16.20.2-headers.tar.gz
2024-02-01T17:20:43.649Z [err] npm ERR! gyp http 200 https://unofficial-builds.nodejs.org/download/release/v16.20.2/node-v16.20.2-headers.tar.gz
2024-02-01T17:20:43.650Z [err] ERR! gyp http GET https://unofficial-builds.nodejs.org/download/release/v16.20.2/SHASUMS256.txt
2024-02-01T17:20:43.650Z [err] npm ERR! gyp http 200 https://unofficial-builds.nodejs.org/download/release/v16.20.2/SHASUMS256.txt
2024-02-01T17:20:43.650Z [err] npm ERR! gyp info spawn /usr/bin/python3
2024-02-01T17:20:43.650Z [err] gyp info spawn args [
2024-02-01T17:20:43.650Z [err] npm ERR! gyp info spawn args '/usr/local/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
2024-02-01T17:20:43.651Z [err] gyp info spawn args 'binding.gyp',
2024-02-01T17:20:43.651Z [err] npm ERR! gyp info spawn args '-f',
2024-02-01T17:20:43.652Z [err] ERR! gyp info spawn args 'make',
2024-02-01T17:20:43.652Z [err] npm ERR! gyp info spawn args '-I',
2024-02-01T17:20:43.652Z [err] npm ERR! gyp info spawn args '/data/node_modules/@serialport/bindings/build/config.gypi',
2024-02-01T17:20:43.652Z [err] npm ERR! gyp info spawn args '/usr/local/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
2024-02-01T17:20:43.653Z [err] ERR! gyp info spawn args '/usr/src/node-red/.cache/node-gyp/16.20.2/include/node/common.gypi',
2024-02-01T17:20:43.653Z [err] npm ERR! gyp info spawn args '-Dlibrary=shared_library',
2024-02-01T17:20:43.653Z [err] npm ERR! gyp info spawn args '-Dvisibility=default',
2024-02-01T17:20:43.653Z [err] ERR! gyp info spawn args '-Dnode_root_dir=/usr/src/node-red/.cache/node-gyp/16.20.2',
2024-02-01T17:20:43.653Z [err] npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/local/lib/node_modules/npm/node_modules/node-gyp',
2024-02-01T17:20:43.653Z [err] npm ERR! gyp info spawn args '-Dnode_lib_file=/usr/src/node-red/.cache/node-gyp/16.20.2/<(target_arch)/node.lib',
2024-02-01T17:20:43.654Z [err] ERR! gyp info spawn args '-Dmodule_root_dir=/data/node_modules/@serialport/bindings',
2024-02-01T17:20:43.654Z [err] npm ERR! gyp info spawn args '-Dnode_engine=v8',
2024-02-01T17:20:43.654Z [err] ERR! gyp info spawn args '--depth=.',
2024-02-01T17:20:43.654Z [err] npm ERR! gyp info spawn args '--no-parallel',
2024-02-01T17:20:43.655Z [err] ERR! gyp info spawn args '--generator-output',
2024-02-01T17:20:43.655Z [err] npm ERR! gyp info spawn args 'build',
2024-02-01T17:20:43.655Z [err] npm ERR! gyp info spawn args '-Goutput_dir=.'
2024-02-01T17:20:43.655Z [err] ERR! gyp info spawn args ]
2024-02-01T17:20:43.655Z [err] npm ERR! gyp info spawn make
2024-02-01T17:20:43.656Z [err] gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
2024-02-01T17:20:43.656Z [err] npm ERR! make: printf: Operation not permitted
2024-02-01T17:20:43.656Z [err] ERR! make: *** [bindings.target.mk:116: Release/obj.target/bindings/src/serialport.o] Error 127
2024-02-01T17:20:43.656Z [err] npm ERR! gyp ERR! build error
2024-02-01T17:20:43.656Z [err] npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
2024-02-01T17:20:43.657Z [err] ERR! gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:201:23)
2024-02-01T17:20:43.657Z [err] npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:513:28)
2024-02-01T17:20:43.657Z [err] ERR! gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:293:12)
2024-02-01T17:20:43.657Z [err] gyp ERR! System Linux 4.9.0-19-amd64
2024-02-01T17:20:43.657Z [err] npm ERR! gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
