Not able to install package "smartmeter"
Dear all,
i tried to install the npm package "smartmeter".
If I install it directly on the webinterface or via CLI I'll get the following errors.
But I cannot interpretate, how to solve this problem.
Maybe do you have any suggestions?
Thank you very much for your efforts.
Kind regards,
Julian
root@node-red:~# npm install node-red-contrib-smartmeter
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm ERR! code 1
npm ERR! path /root/node_modules/@serialport/bindings
npm ERR! command failed
npm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
npm ERR! prebuild-install warn install No prebuilt binaries found (target=18.12.1 runtime=node arch=x64 libc= platform=linux)
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp info using node-gyp@9.3.0
npm ERR! gyp info using node@18.12.1 | linux | x64
npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
npm ERR! gyp info spawn /usr/bin/python3
npm ERR! gyp info spawn args [
npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
npm ERR! gyp info spawn args   'binding.gyp',
npm ERR! gyp info spawn args   '-f',
npm ERR! gyp info spawn args   'make',
npm ERR! gyp info spawn args   '-I',
npm ERR! gyp info spawn args   '/root/node_modules/@serialport/bindings/build/config.gypi',
npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
npm ERR! gyp info spawn args   '/root/.cache/node-gyp/18.12.1/include/node/common.gypi',
npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
npm ERR! gyp info spawn args   '-Dvisibility=default',
npm ERR! gyp info spawn args   '-Dnode_root_dir=/root/.cache/node-gyp/18.12.1',
npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
npm ERR! gyp info spawn args   '-Dnode_lib_file=/root/.cache/node-gyp/18.12.1/<(target_arch)/node.lib',
npm ERR! gyp info spawn args   '-Dmodule_root_dir=/root/node_modules/@serialport/bindings',
npm ERR! gyp info spawn args   '-Dnode_engine=v8',
npm ERR! gyp info spawn args   '--depth=.',
npm ERR! gyp info spawn args   '--no-parallel',
npm ERR! gyp info spawn args   '--generator-output',
npm ERR! gyp info spawn args   'build',
npm ERR! gyp info spawn args   '-Goutput_dir=.'
npm ERR! gyp info spawn args ]
npm ERR! gyp ERR! build error
npm ERR! gyp ERR! stack Error: not found: make
npm ERR! gyp ERR! stack     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:10:17)
npm ERR! gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:57:18
npm ERR! gyp ERR! stack     at new Promise (<anonymous>)
npm ERR! gyp ERR! stack     at step (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:54:21)
npm ERR! gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:71:22
npm ERR! gyp ERR! stack     at subStep (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:69:33)
npm ERR! gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/which/which.js:80:22
npm ERR! gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/isexe/index.js:42:5
npm ERR! gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
npm ERR! gyp ERR! System Linux 5.15.74-1-pve
npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
npm ERR! gyp ERR! cwd /root/node_modules/@serialport/bindings
npm ERR! gyp ERR! node -v v18.12.1
npm ERR! gyp ERR! node-gyp -v v9.3.0
npm ERR! gyp ERR! not ok
npm ERR!     /root/.npm/_logs/2023-01-06T07_41_00_907Z-debug-0.log
I was able to solve this problem by installing in debian build-essential package.
Afterwards it was possible to install this npm package.
Just to note that this requirement is mentioned on the instructions for installing on Debian based systems.
